Question about Panasonic DMR-E85H DVD Recorder
DMR-E85H Problem I went to watch some recordings the other day to find out the digital display panel was blank. I thought maybe the unit came unplugged. I looked it all over and it had not. I pulled the powercord off of the unit and out of the wall recepticle, and then plugged it back into both. The display came on and read "Please wait". After leaving it like this the rest of the evening and the entire next day and evening, I look at it today and it still read "Please wait". I tried turning on the power, and nothing. I tried to open the disc door, and nothing. What could this be?
  • Anonymous Dec 07, 2008
    power supply failure
A BIG thank you for this fix idea. My 3+ year old DMR E85H was acting a bit wacky...with lots of please waits, then self checks....then wouldn't shut off at all. It finally died completely.
Opened it up after it died and found those same capacitors bulging and/or leaking. Up until now, it had always performed nearly flawlessly.
Replaced the capacitors and I am happy to report the unit works again. Overall difficulty on a scale of 1 to 10, with 10 being the hardest? I'd give it a 2.5 at the highest. The hardest part was sourcing the capacitors. I couldn't get anything locally. Had a buddy in Chicago get them for me and he got the last one at that place.
Posted on May 04, 2008
  • Ed
    Ed May 04, 2008
    Oh, yea, forgot to mention I found this site that really shows what's involved and gives some great tips: http://vassfamily.net/projects/DMRE85H/d...
To those of you that posted your solution to this problem, I say thanks!
I have some electronics skills and as soon as I pulled the cover off I saw the capacitors blown out, but seeing the comments made me a little more confident that I could repair the problem. I installed two 100mfd / 25V caps and it powered.
Thanks to the one who posted the pics, confirmed my thoughts.
FYI the only mode I made to the process is I also added heat shrink tubing to the leads on the caps as extra insulation.
Thanks again guys.... the I-net is the best solution ever made.
Posted on Dec 09, 2008
Ed
So far so good. Thanks for all your help! I replaced 4 of the 680mfd caps (2) 10v (2) 16v with (4) 1000mfd 16v caps. All is up and passed self test. Have not hooked up for final testing yet. Fan did not come on right away but 5 minutes later was running. Keep in touch let me know if if gets past the 90 day parts and labor warranty...
$10.90 total cost for 4 caps and Solder.
Kevin
Just took a 3 year old Samsung lcd monitor in to a TV shop, $175 for same type of problem no power up. Should have looked under the hood first.
Thanks to this forum my $600.00 DVR is working again
I have never tryed anything like this before but it was easy
8 to 10 screws to get the cover off and the harddrive out
then I took the whole thing to a place here in calgary alberta called active eletronics
they sold me the capacitors, a pack of 5 for $5.00
then I took it to a small eletronic repair shop and they put them in for me wile I waited "about 5 min."
charged me $20.00
If it had not been for all the info I found here I would have chucked the DVR
Thank you Thank you
Don
Posted on Sep 20, 2008
I fixed my DVD Recorder, it turned out to be a power supply issue. There were two capacitors that failed in the power supply (the power supply is located under the hard drive holding bracket). I easily observed the failed capacitors because they appeared slightly bloated, with a slight leakage of substance on the top. By replacing them with spares de-soldered from a functioning but useless electronic device, I was able to completely restore my unit. So, with a basic knowledge of DC Circuits and fair soldering skills, I have resurrected my recorder. I have read similar issues, and it seems to be a design flaw. The "Please Wait" message is caused by the hard drive not spinning up. Most people would naturally assume this is a bad hard drive, but even bad hard drives spin up (they just make lots of bad noises if they are failing). The issue was that the power supply was not delivering the proper power to the hard drive. Don't replace your hard drive, you will lose your recordings. Test the power first. If you are not comfortable or electronic circuit savoy, then you can get your unit fixed for a flat rate of $130 by Panasonic. There is a special number to call: 1-888-439-2676 Panasonic Service Center 1590 Touhly Ave Elk Grove Village, IL 60007 Another post had this number, 1-847-468-5543, but when I called them, they gave me the above information. Good luck. Considering the unavailability of any other units like this on the market, and the high price of buying one used, I think that $130 flat rate is fair (not great) deal. I also replied this same answer to another similar post: http://club.cdfreaks.com/showthread.php?t=204006
Posted on Sep 28, 2007
Hi My Panasonic DMR-E85H Won't let me record to the Hard Drive it is displaying NO REC message on the Display ? Any ideas are most welcome .
it's the same problem with panasonic dmr-e55 recorder ; must we slack them for another one !!! we need help seriously
Jan 13, 2013 | Panasonic DMR-E85H DVD Recorder
How do you re-tune the panasonic DMR E85H DVD Recorder. I have done exactly as it says in the manual and still it does not find any channels? Is it digital?
The tuner in the DMR-58H is a NTSC tuner (analog). Unless you have a low power station in your area, you will need a digital-to-analog converter box to record OTA stations. It can record analog cable without a box as well. (Digital cable will require a box.)
The manual for the DMR-E85H is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/DMRE85H.pdf .
I hope this helps.
(at least in my area there is only one station broadcasting an analog signal; it is a low-power transmitter and thus wasn't required to upgrade to digital with the rest of the stations.)
Mar 27, 2012 | Panasonic DMR-E85H DVD Recorder
Why won't dmr e85h pick up all the digital channels the tv attached to it will? Is it outdated technology? Do you need a digital set top box or completely replace the unit? Anyone...?
You most likely will need a set top box connected to this recorder in order to receive digital channels, Assuming the DVD recorder works besides this detail, you should not need to replace the unit. Only replace it if it DOESN'T work.
The DMR-E85H is a 2005 model so it is more than 5 years old.
Mar 13, 2011 | Panasonic DMR-E85H DVD Recorder
My Panasonic DMR-E85H DVD Recorder's hard drive has failed, can I replace it with one from the computer store?
yes thy are usually just common 2.5 standard drives.
dont exceed the storage capcity without checking the unit can address that value via its cmos.
Please rate my help ++++Thanks for using FIXYA
May 13, 2010 | Panasonic DMR-E85H DVD Recorder
Panasonic dvd video recorder dmr-e85h is dead
I had same problem. I replaced two bad capacitors on the power supply card. See http://vassfamily.net/projects/DMRE85H/dmre85h.html The capacitors I replaced were C1260 and C1261 slightly different from the one on "vassfamily.net". Everything works now for me...
Good luck.
Also for those interested, I found the "commands" listed on http://www.dxcc.com/dmr-e85h.htm useful when operating the DMR-e85h to correct problems.
Jul 26, 2009 | Panasonic DMR-E85H DVD Recorder
DVD Recorder frozen - please wait on display
You need to replace the STR-G6353 voltage regulator on the power supply board. Full proceedure with photos at this link: http://www.rbjtech.net/electrical/e85/e85.htm#0 I did this on my DMR-E85H and it now works like new.
May 30, 2009 | Panasonic DMR-E85H DVD Recorder
Connect panasonic dvr through converter box
dear sir i have panasonics dmr-e85h dvd recorder .
so i connect to emerson evc 1595 pal to ntsc to pal video convertor.and i convertor to pal video to ntsc video. but it colity is very bed. and picture is fickaring. so u solve my problems emidently.and some time dvdr- is not supprot to display.
Nov 25, 2008 | Panasonic DMR-E85H DVD Recorder
DMR-E85H works fine after replacing IC but ......
Quite many possibilities. Since you replaced the IC, I'd figure you have a little understanding of electronics and ESD procedures. You now need to troubleshoot the driver for the display. Do a little research with your DVM... make sure the display is getting V. Should the unit be a uP type system, you are probably looking at the uP display driver circuitry [all in one] being bad and no way around the replacement should you desire a display. Should the unit be slightly older, you may get lucky with finding a cap or transistor problem for the driver. Moreso trans than cap.
Wish it were here.. always easier to take a peak and find the problem when it is in front of me.
Oct 15, 2008 | Panasonic DMR-E85H DVD Recorder
Faulty Panasonic DMR-E85H
My dvd DMR-E85H frequently displays self check, then goes blank
for long periods before eventually starting.
May 25, 2008 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
2,570 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
