Question about Toshiba SD6100 DVD Player
Toshiba sd6100 dvd player door won't open. Any ideas on what could be happening and what is the least destructive method of removing the DVD.
SOURCE: Toshiba SD 3960 DVD player
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
  • 15 Answers
SOURCE: toshiba dvd player not reading Taiyo yuden blank media
It is probably the player that is dirty or scratched, You will have to buy a lense cleaner kit usually no more than $30, similar to cleaning the heads on a vcr. If that does not work then you will prob have to get it professionly cleaned.
Posted on Mar 14, 2008
SOURCE: A DVD got stuck in the dvd player
unplug dvd player, hold down open button, then while continuing to hold down open button, plug dvd player back in.
Posted on Mar 16, 2008
SOURCE: DVD player does not read discs anymore
With some models of DVD player I know you can download a firmware update on your PC, load it to the DVD player and it wil fix some issues.
Finding those sites for download may be difficult though.
Posted on May 17, 2008
SOURCE: won't open...
Hey this is a great site!
I was having a similar problem with my Toshiba SD-K860. Bobbyj, thanks for the link to the SD-4900 service manual, it was extremely helpful even though it was a different model. I could not find an emergency eject pinhole, and leaving the unit unplugged for a while did not help (two suggestions found on other sites), so I simply took the whole thing apart, got the disc out, found the eject slider on the bottom of the tray, massaged the tray open and closed, and put everything back together again. The connections were solid and the belt was in tact so everything seemed to be fine. Once I reassembled and powered it back up it worked again!
I posted a more detailed solution on my problems to solve site, which is similar to this one:
http://problemstosolve.com/solved/toshiba-sd-k850-wont-eject-solved/
Posted on Jun 10, 2008
The door of my Toshiba sd-6100 dvd player will not open. There's a dvd inside and it will play but it will not eject. How can I open it manually?
Try unplugging the DVD player from the outlet for 2-3 minutes to reset the unit. If this doesn't help, the player probably needs to be serviced.
I hope this helps.
(if the unit is out of warranty, you could try opening the case and removing the DVD drive. There should be a manual ejection button hidden on the front of the drive. Unfortunately, doing this to get your DVD out voids the warranty, if it is still under warranty. Each manufacturer puts this button in a different place. On computer drives, the faceplate has a hole to indicate the spot. The ejection usually takes some force with a straightened paperclip (or small allen wrench).)
May 12, 2011 | Toshiba SD6100 DVD Player
MY TOSHIBA DVD PLAYER HAS SUDDENLY STARTED DISPLAYING IN RED ON THE TV SCREEN. THE TV WORKS FINE ON ITS OWN SO SUGGEST THEPROBLEM LIES WITH THE DVD PLAYER.
if this is connected with component wiring (red, green, blue for video) check that all 3 wires from DVD to tv are good it souns like one of those wires might have gone bad or got pulled out or moved by mistake. that would be the best place to start - if this doesnt help please write back with as many details as possible and i will try to give you more help
Mar 29, 2011 | Toshiba SD6100 DVD Player
How to use dvd's bought in india on a toshiba sd6100
you will need to make it region free
1. Power on the DVD player
2. Press the Open/close button on your remote control to open the drive tray; remove any disk and leave the tray open.
3. Press 2403960 then 9 for multi-region playback (or any region number 1-6 it seems). You will *NOT* see any displays indicating that you have entered any numbers! (After the hack when changing the region codes around the set region code will now display where it didn't on the first time hack).
5. The player is now region free !!!
Please vote for me if you found this useful
Mar 03, 2011 | Toshiba SD6100 DVD Player
How to change the region code on Toshiba SD6100?
Oct 01, 2009 | Toshiba SD6100 DVD Player
My toshiba SD 6100 dvd player is playing only blue screen
just tried with RCA or the hightdef. cables the one with Green bue and red.
Aug 24, 2009 | Toshiba SD6100 DVD Player
Toshiba DVD Player Freezes on a frame after playing a few minues
Have you manually cleaned the laser lens, by removing the outer casing and physically cleaning it with alcohol and a cotton cloth? Have you tried adjusting the angle of the laser lens?
Hope this helps you out.
Aug 18, 2009 | Toshiba SD6100 DVD Player
Our toshiba dvd player only displays movies in black and white
replace the mainboard this is a common problem with this dvd im afraid
Jul 18, 2009 | Toshiba SD6100 DVD Player
Toshiba SD6100 DVD Player Logo
534 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
