My laptop inspiron 6400 just fall from a table and now I when I power it on just the dell screen appears got freeze and won't go up to windows
  • JDTec
    JDTec May 11, 2010
    A fall like that can damage alot of sensitive components. The first thing to do is to reset the memory.
  • 700 Answers
Yeah you should first reseat the ram module. Or have it clean with soft eraser only its edge connector. But first you should power it it down completely, disconnect from any power source and disconnect it battery.
If this doesn't help. Boot your unit in DOS mode by starting it in a bootable drive. If you got a command prompt. You might consider the corruption of files in your harddrive or it actually gets damaged by the fall.
Posted on Apr 23, 2009
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Im getting error code 2000-0146 on my dell inspiron n5010 after a shock small fall my computer will not start anymore
According to Dell, it appears that your hard drive has failed due to the shock of the fall. See below:
http://en.community.dell.com/support-forums/laptop/f/3518/t/19269780.aspx
Sep 18, 2011 | Dell Inspiron 6400 Notebook
A thin vertical blue line has appeared across the screen of my Dell Inspiron 6400 laptop. How do I clear it?
A simple way to check also is to hook it up to an external monitor and see.
plaese tell me after chacking.
Sep 10, 2010 | Dell Inspiron 6400 Notebook
My laptop dell inspiron 6400 does not display battery meter in the screen means that there is no drivers how can i solve my problem?
you need to follow this steps:
on the desktop right mouse click on it , should appear a menu, chose properties and then screen saver, on that screen chose power then just tick the option to see the battery metter
Jun 12, 2010 | Dell Inspiron 6400 Notebook
My Dell Inspiron laptop boot up freezes
RUN CHECK DISK AND IF IT STILL WONT BOOT RESTART AND BEFOR THE WINDOWS LOGO COMES ON PRESS F8 AND CHECK START IN SAFE MODE THEN RUN CHECK DISK
Nov 12, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 freeze after startup
do a system restore before it started doing it.
Nov 08, 2009 | Dell Inspiron 6400 Notebook
Inspiron 6400 buttery does not charge with Windows 7 !!!
Try looking it up in the power options menu in the control panel. There must be some battery settings you can check.
Aug 20, 2009 | Dell Inspiron 6400 Notebook
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Screen turns black Problem
Could you please run the diagonistics on the computer?
Turn on the computer. When the DELL logo appears, press <F12> immediately. Select Diagnostics from the boot menu and press <Enter>.
NOTE: If you wait too long and the operating system logo appears, continue to wait until you see the
Microsoft Windows desktop. Then shut down your computer and try again.
b Press and hold the <Fn> key while powering the system on.
Make a note of any errors that you get after running the diagnositcs on the computer.
Mar 08, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
David Payne
David Payne
