My Akai LCT42Z6TM TV does not have a coaxle
My ALCT42Z6TM TVkai does not have a coaxle input..it has HDMI.. how do I hook it to my cable which is coaxle''. Is there a splitter or special cable for this?
  • 2 more comments
  • Anonymous Apr 24, 2009
    Yes, dsacco86 you are correct it is a monitor. I am using a cable company. There is not a HDMI on my cable box. What may I route it through? Is there a cable that will work from the monitor (HDMI) to the cable box or the cable outlet (Coaxial)?
  • srdl48 May 11, 2009
    dsacco86
    I followed your instructions on my Akai LCT42Z6TM in reference on how to hook it up. THANKS so much!! I went to the cable company and traded my old cable box for a upgraded box with a DVI out put. I used a cable and hooked from DVI to HDMI. Now I have another minor problem. The monitor says no signal..The cable box is on. Will you please instruct me on what to do?
  • srdl48 May 13, 2009
    Thanks so much you are correct again !!!!!!!!!!! After hooking up the box DVI to HDMI there was no sound. I got tired of trying do many things. So I took that box back to the cable company and got one with HDMI output. The TV is now working. Yes I am subscribed to HD. Now I just need to figure out how to hook up the DVD player to it. And again thanks so much.
  • terry2beers May 11, 2010
    Do you have digital or analog cable.Or do you have a convertor box?Some cable companies support tvs such as your and some dont.you shoud have audio and video inputs rca style.input 1 2 3 etc if so a convertor can be purchased at most electroics stores.
    President:
  • 1,077 Answers
A converter box isn't going to fix this problem.
Your TV is a Monitor. It doesn't have a built in tuner. That's why it doesn't have a Cable/Ant coaxial port.
The TV needs a cable box for tuning or some other outside source box for receiving signals.
Are you using cable from the cable company or an antenna for reception?
Posted on Apr 23, 2009
  • 1 more comment
  • Devon Sacco
    Devon Sacco Apr 24, 2009
    Well, I'm hoping there is more than just a Coaxial output from your cable box.
    You have a very good TV for High Definition. 1080 screen.
    I'm sure if the current cable box gets hooked up to the TV right now, The picture wouldn't look very good. I'm sure the cable box can only put out a 480p signal for a 480 screen. I would call the Cable company and see if they can upgrade the box.
    Until then, what other outputs does your cable box have?
    If it only has the Coaxial output, then do you have a VCR?
    What outputs does it have? I'm thinking of use that as an adapter for the TV.
  • Devon Sacco
    Devon Sacco May 11, 2009
    I will help you the best I can. The cable company should have came out to your home and installed this for you, plus have everything working.
    1st question,
    Did they say you would have to subscribe to HD programming or something like that?
    2nd question,
    Does the new cable box have DVI output only?
    I wish the cable company gave you a box with HDMI output.
    The problem with the DVI is it only puts out a video signal. No audio.
    I'm sure the box has output for the Audio, but I'm not sure if your TV has the inputs for audio for the HDMI port.
    The HDMI takes Audio and Video in one cable alone.
    I'm hoping it has the YPbPr/YCbCr outputs. ( Basically, Component Video outputs. The Blue, Green, and Red jacks)
  • Devon Sacco
    Devon Sacco May 13, 2009
    I'm glad the problem is solved. I bet it looks great in HD now.
    The DVD player should be simple enough. let me know if you need help.
I need help setting hooking up my DVD player to my hisense tv
There are 3 options for connecting a DVD player to a television. HDMI, Component or VGA. The most common, and best, these days is HDMI which requires 1 cable, called a HDMI cable, between the player and television. These input / output sockets are clearly marked & there is usually about 3 of them on most televisions. HDMI 1, HDMI 2, HDMI 3. The next is component. These consist of 4 separate connections. RED, GREEN, BLUE & YELLOW. Again simply connect like to like. The third (VGA) are RED, WHITE & YELLOW. Same deal, simply connect like to like on player and set. Once one of the connections are made select SOURCE on the television remote and select the connection that you have made. Cheers
Dec 14, 2016 | Televison & Video
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
* HDMI
to "listen" to.
Oct 24, 2014 | Samsung PN60E6500 60-inch 3D Plasma TV
How do I cable this connection please?
It depends what input connection the second TV has available. You cannot directly daisy chain HDMI cable from Apple TV to the two TVs assuming both have HDMI input. But you can purchase an HDMI 1x2 splitter and connect the 3 up provided the 2nd TV also has HDMI. The challenge maybe the distance you can have between the two TVs. Max is 15 meter but you could cascade 2 units to create longer distances.
http://www.ebay.com/itm/HDMI-Splitter-Box-High-Speed-Full-HD-1X4-4-Port-Hub-Audio-Video-1080p-Amplifier-/191120909726#ht_2675wt_1337
Apr 28, 2014 | Televison & Video
Partial black screen on mulitple (but not all) inputs on panasonic plasma tv
Sorry but it's time to shop for another tv the cost of repairing would cost almost as much as a new unit.
Mar 18, 2014 | Computers & Internet
Can you help me hook up my old nintendo ( 1985) It is for my grandkids. I have lots of tapes and don't just want to throw this out. thanks
Hi if your tv has rca inputs simply plug yello,red,and white rca cables into the color inputs on tv if it has a coaxle "roung with threads and a hole" simply screw the coaxle wire to this and your alset.
Jan 31, 2010 | Sansui VRDVD4001 DVD Player/VCR
Help with Hitachi Audio Video Center (AVC80U)
okay so it doesn't need a remote control.............. The AVC08U should register immediately with the tv, the box itself has a bad HDMI out.
Dec 07, 2009 | Televison & Video
Help HDMI Splitter Doesn't Work!
The HDMI splitter is intended to take one source to two displays. You need an HDMI switch to take two sources to one display, a device you can tell which input to select.
Jun 06, 2009 | Toshiba 26HF85 26 in. Television
Just bought Samsung HT-tz515. how do I hook up my incoming cable television to teh system? I do not have a cable box. Can I get a splitter or other connection or do I need to get an intermediary such as...
simply buy an input selector, one with coaxle input along with rca or svideo or hdmi output then hook your cable coaxle to the input and run rca cable to the new system, very simple and works great
Aug 10, 2008 | Samsung Audio Players & Recorders
Hook up vcr
yes, you need to use an Audio/Video cable (red, white, yellow) to hook to the TV. I've never seen a VCR that doesn't have coax connectors for the antenna input and TV ouput, but maybe the new ones are starting to leave that out. Normally, you run the antenna or cable coax into the VCR's input, then run another coax from the VCR output to the TV's input (or use an A/V cable)
Dec 20, 2007 | Sharp VC-A420U VHS VCR
Televison & Video Logo
435 people viewed this question
Top Televison & Video Experts
Electro Med Services...
