Question about ASUS Computers & Internet
Blank screen I changed the cpu setting in the bios now nothing comes up on the screen so I reset the cmos setting but still nothing can you help
  • cheryl1258 Apr 23, 2009
    Thank you but I fixed it I unplugged it from the wall took the battery out and moved the jumper, left it that way for an hour, then plug it in, put battery in, moved jumper back and it works fine now
  • 66 Answers
Well you might need a whole new cpu, you could have possible damaged it, so call your it guy that you can find on the asus site and see if they can help. You might have to send it in though...
Posted on Apr 23, 2009
Impossible to boot after changing BIOS settings. No BIOS reset jumber No removable battery Nothing in the documentation. How can I reset the BIOS of thie computer ? Thanks,
If not even the pressing of the Del key during POST brings the BIOS screen then you will have to dismantle the unit, disconnect the SDD and try to boot like that. If it fails even now then the BIOS has been corrupted beyond repair - you will have to send the unit for repair - a dealer or the manufactured will have to reload a new BIOS at a hardware level, with special tools and software.
Jul 09, 2011 | Jetway Mini-TOP HBJC600C99-52W-BW Intel...
Hi iv changed the bios settings on my acer aspire m5630 im sure i made the cd/dvd drive the main boot and the hdd the 2nd if there was no boot cd. i reboot my computer and now it starts up my cpu fan...
Do you know how to reset the cmos settings on your motherboard what to do is near the "coin" battery on your board there is a set of pins that if u short them using a jumper this will reset the cmos this should hopefully sort ur problem if not u may need to reflash your BIOS please repost i more help needed Ian
May 24, 2011 | Computers & Internet
Changed cpu multiplier from 17 to 19 now have blank screen on foxconn a88gmx, cant reset as cannot access bios
Try clearing the CMOS --- the down side is your lose all your setting --- the up side is you should be
able to access your BIOS
Clear CMOS Jumper: CLR_CMOS1 ( Located near CMOS battery )
The motherboard uses CMOS RAM to store the basic hardware information (such as BIOS data,
date, time information, hardware password...etc.). Clear CMOS data is the fast way to go back to
factory default when the BIOS settings were mistakenly modified.
The steps to clear CMOS data are :
1. Turn off the computer, unplug the power cord from the power outlet.
2. Remove jumper cap from pins 2-3, put it onto pins 1-2 to short them.
This will clear CMOS data.
3. Return the setting to its original with pins 2-3 closed.
4. Plug in the power cord to your computer and turn it on.
5. Go to BIOS Setup to configure new system as described in next chapter.
Clear Jumper on pins 1 & 2
1 ----
2 ----
Normal
(Default)
3 ----
CLR_CMOS1
  • Disconnect the power cable before adjusting the jumper settings.
  • Do not clear the CMOS while the system is turned on.
WARNING!
Jumper Diagram Definition Description
1-2 Set Pin 1 and Pin 2 closed
2-3 Set Pin 2 and Pin 3 closed
Feb 10, 2011 | Foxconn A88GMX AM3 AMD 880G HDMI Micro ATX...
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
CMOS checksum error defaults loaded
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
Press F2 to load default values and continue
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Sharp Actius PC-RD10 PC Notebook
Problem on start up
there should be a cmos reset jumper on the motherboard somewhere close to the bios chip. Given you didn't mention the actual model and brand of mobo i cannot be certain. Also you can remove the little watch battery for a few minutes and it too should reset the bios.
Aug 19, 2009 | Computers & Internet
Reviving the cpu
The boards I have seen were overclocked by changing the CPU speeds or the voltages going to the CPU. Change the setting back. When you get into the BIOS setup screen(A lot of them you get into by pressing the delete key when starting up) look for the "Default settings" After clicking on them,save the settings. Thsi wil bring you back to the  Safest board setting according to the board maker.
Feb 26, 2009 | Compaq Pentium III, 366 MHz (400138-001)...
Problem with my BIOS CMOS Setting
Its due to your default CMOS setup does not match with your CPU configuration especially with CPU speed.
  1. To fixed the above problem goto BIOS and navigate settings of CPU, speed etc. Set the speed with the proper value as per manual. And save the settings.
  2. Infuture when you will load default, at that time also set the CPU settings.
  • The CMOS battery might not be connected properly or may be its not producing enough power as per needed by board. So have a look with another battery. Also clean the connection point of the CMOS battery.
Good Luck
Iqbal
Apr 22, 2008 | Biostar P4M80-M4 Motherboard
Monitor on but not working properly
If you just built the computer..the motherboard will give you a warning that some hardware has changed. you have to connect your keyboard and go into the bios and make sure everything is right. To be safe select set to default factory settings , save and reboot the computer. This is to prevent the settings for a previous cpu be used for the new one.
Feb 24, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Computers & Internet Logo
50 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
