Question about Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot 2720
It turns off and immediately restarts itself every minute or less. Doesn't matter if my car is idling or rolling or if I'm programming "Where To" instructions. I disassembled the GPS adapter plug, but saw nothing abnormal, and reassembled it securely. If you tell me to test the cigarette lighter, how do I do that? Thank you.
  • 363 Answers
First check the socket a cigarette lighter! You could borrow one if you've lost yours because they are all the same size. If it works then read on.. Most cigarette lighter ADAPTERS I've seen have an LED on them to tell you it's making good contact. If it has got an LED but it's not illuminating then unscrew the black cap at the tip of the adapter and check the fuse. If the fuse is blown replace it with one of the same rating. If that was no help at all then try resetting the Garmin. Unclip the face place and press the reset button. Now try turning it on. Hopefully I have given you at least one thing new to try! :) Regards, SparkGap
Posted on Sep 25, 2007
  • Martin B
    Martin B Sep 25, 2007
    Oops the first bit should read
    "First check the socket WITH a cigarette lighter"
My audio stopped working on my Garmin 2720
try depleting the battery until empty. that worked for my nuvi 760.
May 23, 2009 | Bennett Marine BENNETT DVD GARMIN...
Garmin 2720 lost sound
It sounds like the audio power amplifier is failing in the unit, it's kinda classic for an audio amplifier to fail when it gets hot, then work again when it cools down.
I'd suggest deleting the language you're using, then reload v7.2 firmware and the language. No reason why this should work, but it doesn't cost anything. If not you're looking at a $250 Garmin flat rate repair.
Dec 22, 2008 | Garmin StreetPilot 2720 GPS Receiver
Garmin GPS 2720
Unfortunately, Fixya is not associated with Garmin. We can only answer device questions and can't speak for the company.
Unfortunately, the unit cannot be upgraded. Garmin provides both in and out of warranty repair service if the unit is having a problem. The 2720 sells for $49 on Amazon, so it probably is not worth your while to have fixed.
The 2720 is known to have issues unfortunately, it is pretty lowly rated on Amazon.
Mar 23, 2017 | Garmin StreetPilot 2720 GPS Receiver
Hard reset
I was told that you turn off the unit, hold down the FIND key and turn it on while holding. Keep pressed for about 10sec. then release.
Jul 25, 2008 | Garmin StreetPilot 2720 GPS Receiver
System missing
Well, for the 2730 which is basically the same, you turn off the unit, hold down the FIND key and turn it on. Hold for about 5 seconds and release. It should reset the unit.
Unlock Code
When updating the maps, you need to be registered with Garmin. All the numbers came with the unit. If you turn over your Garmin 2720, there will be a number flanked by "*". That is your unit ID. When you register, you must provide that ID. From the site, you can update your maps and you shouldn't need the 25digit key. It's programmed into your unit.
Jul 01, 2008 | Garmin StreetPilot 2720 GPS Receiver
GARMIN STREET PILOT 2720
Is the power connector fully seated on the GPS unit?
Dec 11, 2007 | Garmin StreetPilot 2720 GPS Receiver
Restarting while in use
Mine just started doing the same thing. I took apart the speaker power cord, but don't see anything wrong with it. I thought I saw the unit turn off/on one time when I moved the cigarette plug back and forth, but as I said the wires are fine. I have the power cord apart right now and have 12 volts hooked up to the wires directly and the unit has been sitting here for 30 minutes without resetting.
Oct 17, 2007 | Garmin StreetPilot 2720 GPS Receiver
Shuts off itself
My 2720 just starting doing that today. used it fine for past 4 days on a trip, now it is acting up. Less than 1 year old
Sep 03, 2007 | GPS
Garmin StreetPilot C330 GPS Receiver Logo
52 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
