Question about Rockford Fosgate Punch 401S Car Audio Amplifier
Only one sub hitting
I have every thing wired right but I can unplug my left sub while their hitting and i cant tell a difference in sound, its like its not even hitting, my right sub is hitting hard though any suggestions?
  • blueextc3221
    blueextc3221 May 11, 2010
    Check the voicecoils with an ohmmeter (DMM set to 20 Ohm setting) to verify each coil is at the proper impedence.
    Remove as you put them back in the enclosure after testing - try it by attaching to amplifier.
    If you haev 0 on the DMM, your voicecoil is blown - and not repairable.
    Also be sure they are wired in phase - working together. After they are back in the box - before finalizing the wiring - use a cordless drill battery to "pop" the speakers and verify they are both going in the same direction... OUT when + is on + of battery and - is on - of battery.
    Problem Solver:
  • 13 Answers
You most likely have them wired out of phase. Try reversing the wiring on only one of the speakers.
Posted on Apr 23, 2009
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
When I connect my cables from the TRS outputs to my direct-field monitors, the latter seem to be unbalanced: one monitor plays more higher frequencies than the other
Plug in one a at time using the same input. Take the left speaker and the left input wire. Plug the wire from the mixer into the one speaker if it sounds ok then unplug the speaker and replace it with the right speaker. If it sounds ok replace the wire with the right wire. This will tell you that each speaker is working and each cable is working. If you switch speakers and they sound different then the possibility of a blown high end driver in one. If they sound ok each by it self but the high end suffers when they are both hooked up then the possibility of the speakers might be. Not sure what the sub has to do with the whold setup. Any further questions call me at the store.
Vito Vacirca Jr.
Pro Line Music
490 Lincoln Highway
Fairless Hills Pa. 19030
215-736-8055
servicedepartmentprolinemusic@comcast.net
www.prolinemusic.com
Jul 15, 2011 | M-Audio SBX10 Monitor Studio Sub
I have phase linear uv8, need to know how to get subs 2 work! Amp goes into protect mode when rca's r plugged in, there r 3 sets of preamp out puts 1 front left and front right, 2nd is rear left rear...
try testing the amp without speakers plugged in. Run the sub preamp out to the amp that you will drive the subs with, but don't wire up the subs yet. Test for protect mode kicking in.
Yes - unplug the rca ins from the amp. retest.
No - Problem lies within the sub wiring. What is the load on the amp (measure with an ohm meter)? If it is below 4ohms, chances are the amp can't dip that low. Give it more resistance by wiring it differently (series vs. parallel)
Bruce
May 05, 2011 | Kicker Car Audio & Video
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
Can you please tell me how to connect my kef psw
If your amp has a "sub out" jack, that's the best way to hook up this sub. You'll just need a single RCA (also called "phono") cable. Connect it to the Left input on the sub, which should also be marked as "mono"
If your amp just has speaker-level outputs, then connect the left and right main speakers from your amp to the sub's high-level inputs, and then run wires from the sub's high-level outputs to your speakers.
If you're running a surround-sound setup, use the front-left and front-right speakers for this hookup.
If this helps, be sure to hit the "thumbs-up" button for me!
If not, post back with the "Add comment" and I'll do my best to answer any questions you've got.
Jan 23, 2010 | Panasonic Audio Players & Recorders
Sub hits backwards, hi low level converter?
I ran into a similar problem installing a sustem in a Mazda RX8. He had BOSE speakers which operate at a different range. We had to purchase the Rockford 3sixty.
Apr 20, 2009 | Scosche Industries Scosche Slc4 Speaker...
My amp wont power both subs the same
you most likely mess up you wiring... im not sure what ohm resistance your subs are, but if its 2ohm or 4ohm you wire straight foreward one sub all positive wires to left positive, all negitive to left negitive, and the same with sub 2 to the right terminal. BUT if your subs are 8ohm then wire it with all positives from both subs to LEFT positive and wire all negitive wires to RIGHT negitive... and see if that helps and good luck!
Jan 12, 2009 | Pioneer TS-SWX310 Car Subwoofer
Wiring sub on home theatre
use the sub pre out and wire it into the left input on the sub.
Mar 08, 2008 | Audio Players & Recorders
How to
First of all, make sure your amp is bridgeable. There are a few ways to bridge subs. series: hook one wire from the negative on the left amp output (or whichever is labeled on amp for bridged)to left sub negative. left sub positive to right sub negative, then right sub positive to the amp positive output.(like a big loop through both speakers) parallel: both speakers get their own set of wires, both negatives go to the bridge negative terminal, and both positives go to the positive bridge terminal. Series-parallel: A combination of the two. say two speakers in series, and one hooked up alone, but all to the same amp outputs. Bridging your amp/speakers basically lowers the resistance of the circuit and makes more current flow, more power, louder, harder hit. In series, it also makes both speakers do exactly the same thing, instead of "stereo sound" or L/R differences. What you're probably looking to do is Bridge in parallel. That will drop the resistance of the circuit the lowest, allow the amp to put out the most amount of current to the speakers, and allow your bass to hit the hardest. If your amp only has one output, hook up the same way as above. Just see what resistance your amp is stable down to. If down to 1 ohm, no worries. if stable only to 2 or 4 ohms, you may want to bridge in series to be safe. That will cause the resistance to go up, and will not pull as much current through the amp. The whole time, just remember Bridgeing and higher current mean HEAT so watch your amp. I hope this helped.
Oct 31, 2007 | Pioneer TS-W301R Car Subwoofer
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Rockford Fosgate Punch 401S Car Audio Amplifier Logo
89 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
