Question about Asko T781 Electric Dryer
Asko T780 Dryer Vibrating/Grinding noise
It sounds like my dryer is driving down a washboard country road. I've read several posts on this. I've taken off the fan cover, and cleaned it. There is not a single piece of lint in there. Yet, my dryer continues to make this obnoxious vibrating/grinding noise. The noise seems to be getting worse. Any suggestions??
    Genius:
  • 1,198 Answers
Sounds like a bad roller. You'll have to remove the drum to get at them. Even a free one may make noise at speed. Use high temp grease. Also check roundness. And don't forget the belt tensioner roller, just don't get any grease where the belt touches.
Posted on Apr 23, 2009
My dryer is starting to sound noisy
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 23, 2011 | Asko T781 Electric Dryer
Loud vibrating noise after warming up
heatman101
May 10, 2010 | GE Profile Harmony DPGT750EC Electric...
I have an ASKO T760 Dryer that continually overheats and then shuts down. I have had a service tech out twice - once to clean the vent and element housing and a second time to clean the "thermister" but...
Check the sensor inside the condenser unit "cage". I read that you can clean inside the little cage with a toothpick. I'm having the same trouble, and plan on trying this before I throw in the towel and purchase a new dryer.
Dec 30, 2009 | Asko T780 Dryer
My asko T760 dryer shuts down after a few minutes. It starts again after hitting reset button on back. I read a similar problem was fixed by cleaning the sensor behind the safety cap fixed the problem, but...
Remove bottom panel. The condenser unit is on the left side. Open the section by undoing the clips, and look inside the little "cage". That's the sensor. Remove any lint using a toothpick and you should be good to go!
Nov 28, 2009 | Asko T780 Dryer
My belt is broken and I can't find a replacement
In your town, a appliance repair shop would have it, on line ...www.repairclinic.com
Aug 08, 2009 | Asko T780 Dryer
My t712c asko dryer is making some loud noises.
heatman101
nfgnc
May 04, 2009 | Asko T712C Dryer
ASKO T780 dryer automatically shuts down after aprox. 20 minutes
Check sensor for fluff. We have asko tumble drier and have had to clear this of fluff many times. Take bottom panel off, as if removing filter to clean. Located on left hand side is a plastic cover, grey, secured by one security head screw. Once screw is out carefully remove circular cover uncliping clips. Inside is a sensor with a plastic cage around it, about size of one pence piece, clean fluff out with toothpick for example. This should do the trick. Good luck.
Feb 13, 2009 | Asko T780 Dryer
Disabled neighbor was given an ASKO T780 dryer, but it doesn't heat up. What could the problem be so I might be able to fix it for him?
most likely if the dryer does everything except heat up the heating element is bad if you take it apart it will be directly behind the holes inside the dryer
Jan 15, 2009 | Asko T781 Electric Dryer
RESET BUTTON TRIPS
if i read everything there is another reset button in the center of the back of this model that needs to be reset.There are also 2 areas lint can build up. front lint trap and somewhere else. Good luck
Apr 11, 2008 | Asko T780 Dryer
Asko T780 Stopping after a few seconds.
It sounds like you have a condensing dryer. These condense the water into a pan in the back, and then the water is pumped down the drain. If you are getting an overflow, it means the pan is full of water and the controller is shutting it down to prevent it from leaking on the floor. Most likely cause is a bad drain pump, which is a bit of a bear to change as it is in the back behind the rear wall in the lower right hand corner. The other option is that the drain line could be pinched or clogged, especialy if the unit was moved just before the problem started. Hope this helps!
Mar 12, 2007 | Asko T780 Dryer
Asko T781 Electric Dryer Logo
777 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
