Question about Ricoh Aficio 350e Printer
Ricoh aficio 350's will not print
It says on my display screen for my Ricoh Aficio 350 to empty my toner bottle and i changed the toner and restarted the printer and it still says the same thing. What do i do?
  • JDTec
    JDTec May 11, 2010
    is this a 350e or 350s?
    There is a toner waste bottle in these units that need to be emptied. On the 350e it is on the left behind the door next to the paper trays. Open the drawer and about the middle you will see the waste toner bottle.
    Let me know if this is your model.
    Joe
I believe it say "empty waste toner". The waste toner is located within the transfer belt unit, which is the brown belt on the inside of the left cover when you open it.
You will see on the left side (towards front of copier) a small brown lever to release the belt assembly. Lift up the lever, then lift the belt unit from the top and pull out.
This gets pretty messy, so be prepared.........
to remove the belt from the housing, remove the 2 springs on the left and right sides, this will allow the belt unit to swing upward once you release the black locking tab on one end (the NON-GEARED end i believe)
Remove the belt and DO NOT tip the unit or you'll really have a mess. Mind the gear on the end, because it will simply slide off. Try to touch the belt as little as possible and be careful not to damage it.
You'll now see a rubber blade, and underneath that is the storage compartment for waste toner. Get a large plastic bag, and start dumping...there is a lot in here and it will be very messy, so be careful, and consider using some gloves.
once emptied. Clean unit with DRY rags, reassemble, and reinstall.
That should do it.
Please rate my solution :)
Posted on Apr 23, 2009
  • Anonymous Apr 23, 2009
    CORRECTION....the belt is inside the "RIGHT" cover
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
I have a ricoh aficio MPC2050 copier V2295900860 and it is saying that the waste toner bottle is full and needs to changed how do i do this and where is the waste toner bottle located.
Hello!
Your machine have 2 waste bottles.
The bottle 1 is placed in the front door. (See the picture). You can empty it or replace it.
(is less expencive to empty it)
The secund waste bottle is in the left. See this picture
Now, you just need to make sure what waste bottle is mentioned in the display.
Hope this helps
Sep 12, 2011 | Ricoh Aficio 450 Copier
Ricoh aficio 2105 waste toner full indicates even if it was already empty, cleaned the bottle sensors still indicates full, how am i going to reset it?
Make sure the 2 waste toner are empty.
You have 2 bottles of waste.
1- Next the papaer trays
2- Next the development Unit
May 25, 2011 | Ricoh Aficio 2015 Copier
The display panel on my Ricoh Aficio 1232C says, "Toner Bottle - 1 is full". What does this mean and what should I do? Rob Buckler
open front door ull see 2 bottles marked 1 and 2 pull it out and empty the waste toner
Be aware its very messy.Idealy u should have a replacement one.
Nov 30, 2010 | Ricoh Aficio 1232C Color Copier
The display panel on my Ricoh Aficio 1232C says "Used Toner bottle - 1 is full". What does this mean and what should I do? Rob Buckler
used toner bottle is full so you have to take it out and empty it. open the front cover, you will see one bottle in the middle and one lower down with 1 and 2 written on it. pull it out and empty it and fit it back.
We have a Ricoh Aficio 350 copier that is quite old but has worked well through the years until now. It keeps displaying ADD TONER and runnng after we have already put in a new cartridge. Under add toner,...
take the toner supply unit out. toner supply unit is one where toner bottle fits and vacummed clean the unit. the toner unit is blocked. i am a Ricoh technician.
Sep 23, 2010 | Office Equipment & Supplies
How do i change the toner colection bottle for a Ricoh aficio 350 copier?
There is no toner collection bottle for the 350, used toner is stored in the transfer belt unit. It must be pulled from the machine disassembled then empty used toner reassemble and put back in machine, a counter must also be reset, cant remember which sp code this is though.
Sep 16, 2010 | Ricoh Aficio SP C410DN Laser Printer
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Ricoh Aficio SP C410DN "set toner cartridge correctly"
It sounds like the part the toner bottle slides under to lock in place is broken. you could try and fold some paper and tape it to the toner to hold it down.
Mar 26, 2009 | Ricoh Aficio SP C410DN Laser Printer
181 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
