Question about Samsung PCL5415R TV
TV turns off by itself
I have a Samsung PCL 5415R. When I turn on the TV its good for several mins then I hear a click and it goes off with the PWR red lite still on, cant control with remote (on or off). I unplug TV wait few seconds then plug back, TV comes on with a click sound. Sometimes it stays on for several mins and sometimes it good the whole nite. Few times when it goes off there is a continues clicking sound while its off. Can you help with this matter? Thanks.
  • rpetromc Apr 23, 2009
    Will try all that you have suggested. But in order to know where all these parts are I need a manuel or IPC can you refer me to a place I can purchase them. Again thanks.
  • 700 Answers
Thus the line connected to a surge protector or some kind of line protector. This can be consider.
Or if this is a crt type tv. This could be a fault on high voltage section. Horizontal output transistor or flyback. But check also for loose connection/solder crack. That clicking sound may be the relay in action.
hope i give some correct input.
Posted on Apr 23, 2009
Tv goes black and can still hear sound, then it will shut off, then turn back on. will repeat after 5 mins
Hey iterry,
I have the same TV with what seems to be the same problem (screen off, audio remains until turning off->on); posted in several places (including here) but yet to receive a conclusive advice.
Please check the following:
- Does the screen turn off exactly 5 min. later - or when high brightness frames come up (could be 1...2...15 min. into the run;you can check that by pausing on a dark frame for a while)?
- Try altering the set to 4:3, low definition (did mine through my UVerse menus) as well as manually reducing the brightness settings; see if this gives you longer screen activity (I often manage for several hours, until some stupid commercial has a few seconds of a bright-white screen).
If we are indeed both in the same boat, my findings thus far are:
This is not a lamp issue (changed, no difference); not a color wheel issue (changed a couple of months before this ****); probably not a temperature issue - though I'm still checking that.
I'm hoping it's the ballast; will soon check and LYK. Good luck.
Nov 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
PCL 5415R GHOSTING OF BLUE
It may be a problem with the ics, let me find schematics for your model
Apr 12, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung 50'' Plasma TV won't turn on anymore
If your tv is within the one year warranty period then call 1-800-Samsung for warranty repair. Look at your tv purchase receipt for the Purchase Date. You have one year from the date of purchase to get warranty repair.
Jul 08, 2009 | Televison & Video
Our tv turns green and shuts off every 5 min. or so
try plugging the cable line directly into the tv skipping the cable box,then let me know what happens
May 20, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
Samsung model pcl 5415r tv looks like its in 3d
If this set is new, a problem like this would be covered by warranty. If it is no longer under warranty, locate the convergence ICs which will be large black ICs attacked to a heatsink. Try resoldering the pins on these ICs first. If that does not resolve the problem, replace the ICs. These should be marked STKxxx.
Keep me posted,
Dan
Jan 12, 2009 | Samsung PCL541R 54" Rear Projection...
Lcd tv turns off after 5 mins, leave 2 mins comes on to stand by
Swollen ( bad ) caps in power supply first place to look.............T.
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung PCL 545R turns itself off ALOT
manual can be found on www.eserviceinfo.com
(you have to download all 3 rar files)
I have a PCL5415R exhibiting a similar problem, have not dug into it yet but my set also has convergence problems. I'm suspecting that I have a transistor going out somewhere as it will often turn off while trying to do the perfect picture function.
Mar 17, 2008 | Samsung PCL545R 54" Rear Projection...
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
Tv wont stay on
Check for CRT coolant leak on PCB.Clean spill, try again to verify.
Aug 19, 2007 | Samsung PCH521R 52" Rear Projection...
Televison & Video Logo
233 people viewed this question
Henry  Thomas
Henry Thomas
