Question about Dell Dimension 4600 PC Desktop
I have a dell 4600 that I got from my daughter . which I had to re-install and It has a password in the bios for the set up and my daughter dont know
I have a dell 4600 and I need a master password to get in the setup bios, so I can reset some of the devices
  • 728 Answers
Hi katmbutts;
Before attempting to bypass the BIOS password on a computer, please take a minute to contact the hardware manufacturer support staff directly and ask for their recommended methods of bypassing the BIOS security. In the event the manufacturer cannot (or will not) help you, there are a number of methods that can be used to bypass or reset the BIOS password yourself. They include:
    • Using a manufacturers backdoor password to access the BIOS
    • Use password cracking software
    • Reset the CMOS using the jumpers or solder beads.
    • Removing the CMOS battery for at least 10 minutes
    • Overloading the keyboard buffer
    • Using a professional service
Please remember that most BIOS passwords do not protect the hard drive, so if you need to recover the data, simply remove the hard drive and install it in an identical system, or configure it as a slave drive in an existing system. The exception to this are laptops, especially IBM Thinkpads, which silently lock the hard drive if the supervisor password is enabled. If the supervisor password is reset without resetting the and hard drive as well, you will be unable to access the data on the drive.
Backdoor passwords
Many BIOS manufacturers have provided backdoor passwords that can be used to access the BIOS setup in the event you have lost your password. These passwords are case sensitive, so you may wish to try a variety of combinations. Keep in mind that the key associated to "_" in the US keyboard corresponds to "?" in some European keyboards. Laptops typically have better BIOS security than desktop systems, and we are not aware of any backdoor passwords that will work with name brand laptops. WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords Award BIOS backdoor passwords:
ALFAROME BIOSTAR KDD ZAAADA ALLy CONCAT Lkwpeter ZBAAACA aLLy CONDO LKWPETER ZJAAADC aLLY Condo PINT 01322222 ALLY d8on pint 589589 aPAf djonet SER 589721 _award HLT SKY_FOX 595595 AWARD_SW J64 SYXZ 598598 AWARD?SW J256 syxz AWARD SW J262 shift + syxz AWARD PW j332 TTPTHA AWKWARD j322 awkward AMI BIOS backdoor passwords:
AMI AAAMMMIII BIOS PASSWORD HEWITT RAND AMI?SW AMI_SW LKWPETER A.M.I. CONDO PHOENIX BIOS backdoor passwords: phoenix, PHOENIX, CMOS, BIOS MISC. COMMON PASSWORDS
ALFAROME LKWPETER BIOSTAR lkwpeter biostar setup biosstar SETUP CMOS Syxz cmos Wodj OTHER BIOS PASSWORDS BY MANUFACTURER Manufacturer Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX TMC BIGO Toshiba Toshiba TOSHIBA BIOS Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot IBM APTIVA BIOS Press both mouse buttons repeatedly during the boot Then There is Password cracking software The following software can be used to either crack or reset the BIOS on many chipsets. If your PC is locked with a BIOS administrator password that will not allow access to the floppy drive, these utilities may not work. Also, since these utilities do not come from the manufacturer, use them cautiously and at your own risk. Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturer's documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop. Remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position. Removing the CMOS Battery The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time. Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all. IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set. If you reset the BIOS password, but cannot reset the hard drive password, you may not be able to access the drive and it will remain locked, even if you place it in a new laptop. IBM Thinkpads have special jumper switches on the motherboard, and these should be used to reset the system.
Overloading the KeyBoard Buffer On some older computer systems, you can force the CMOS to enter its setup screen on boot by overloading the keyboard buffer. This can be done by booting with the keyboard or mouse unattached to the systems, or on some systems by hitting the ESC key over 100 times in rapid succession. Jumping the Solder Beads on the CMOS It is also possible to reset the CMOS by connecting or "jumping" specific solder beads on the chipset. There are too many chipsets to do a breakdown of which points to jump on individual chipsets, and the location of these solder beads can vary by manufacturer, so please check your computer and motherboard documentation for details. This technique is not recommended for the inexperienced and should be only be used as a "last ditch" effort. I hope this helps, Don't forget to leave a rating. Mark
Posted on Apr 23, 2009
    Brigadier General:
  • 10,406 Answers
I presume that you have a "desktop", not a "laptop" system.
Turn your computer off.
Disconnect the power-cable.
Remove the side-panel.
Look carefully on the motherboard for a small mostly-plastic jumper, connecting two pins (there will be 3 pins in a row).
Move the jumper from spanning the "first" and "second" pins,
to span the "second" and "third" pins.
Wait 10 seconds.
Move the jumper back to its original position.
Reconnect the power-cable.
Turn the computer on.
Can you now enter BIOS-setup mode, without a password?
If not, turn your computer off.
Look again on the motherboard for a different jumper,
and another "three-pins-in-a-row" orientation.
Repeat the above (jumper-movement, wait, move-back the jumper) process.
BIOS Password Reset
if ti is a bios password the only thing you can try is to open it up and remove the bios battery for a minute or so ..and see if it works..It does not work for all models but usually for most desktops works and for some laptops..It basically cutting bios power and make it forget all settings including the password..After that just reinstall the operation system ..
If you are not sure if it is a bios setting ..just try to reinstall using a boot-able disk with the operation system ..and if the boot order is not set to boot first from CD ..just try to press f12 to engage the boot menu and select it manually ..and press enter ..
Another way to fool it ..is to try and remove the hard disk ...and force it to boot from the disk cause the disk is the next inline ..and after it starts just plug the hard disk again ..and you have a chance to go on with the installing in this time ..
let me know what you have tried and what worked..
Dec 23, 2011 | Dell Inspiron 2200 PC Notebook
Dell 4600 clock battery location
The Clock/time is kept with the aid of a silver 3Volt button cell. This cell also provides power to the BIOS/CMOS. It is found on the computer mainboard.
If you do replace it, be sure to enter the BIOS to set the time and other settings that may need ot be set.
The button to push to enter the BIOS is usually delete or F12.
Keep Well!
damnor01
Apr 16, 2011 | Dell Dimension 4600 PC Desktop
Dell inspiron 630m bios password problem
usually the bios password is 0000 by default
Mar 13, 2010 | Dell Computers & Internet
Cannot install 17 inch monitor on dell dimension 4600
You have not installed your graphics card drivers! ----------
The drivers are here ---> Since I dont know which graphics card you have you will have to try each one... dont worry if the driver dosent find your card it wont install.
Do you know the full model number of your system , it is printed next to the serial number if you give me this number I can link you directly to the driver -----------
Jan 24, 2010 | Dell Dimension 4600 PC Desktop
How can i unlock dell latitude d420 bios password i bought the laptop at auction, now i'm screwed.
For that try password as "dell" or "DELL"
If it not works then you have to reset all settings of bios to factory defaults.
For that you need to open back side cover of laptop.
Open all screw in back side then remove cover then you find motherbord chipset .
Pull cmos cell from motherbord 15 minutes so all settings goes to factory defaults.
Let me know if you need more assistanse.
Thanks.
Sep 16, 2009 | Dell Latitude D620 Notebook
Wireless connection with Dell 4600
they sell USB wireless adapters, that should do nicely.
Don't forget to rank the advice!
http://www.aa1consulting.com
Jul 27, 2009 | Dell Dimension 4600 PC Desktop
How do I do the restore from Dell Recovery CD? I have a Dell Dimension 8110
In the BIOS, set it to boot from the cd-rom drive first, put the cd in and it should boot to do a recovery. If you need help, let me know. I could even do it for you if you like, if you ship the pc
Jun 06, 2009 | Dell Dimension 4600 PC Desktop
How to Unlock Dell inspiron 1520 Laptop Password
I is my understanding that you can contact Dell with the service tag, and express code and get the master password to clear forgotten passwords.
May 09, 2009 | Dell Inspiron 1501 Notebook
Dell 1525 Bios Lock Problem
Call or chat with the Dell technical support and they can provide you the Master reset password free of charge.
Apr 20, 2009 | Dell Inspiron 1501 Notebook
New Hard Drive over 128 GB on Dell 4600 - but only recognizes 128 GB!
Check that your motherboard supports the high capacity of HDD
Install the OS having the latest service pack combination.
Let me know if your problem is solved and rate me as FIXYA!
May 10, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
1,027 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
