Question about Canon I960 InkJet Photo Printer
Changed ink cartridge, now printing with green hue
The photo magenta cartridge needed changed, put in a new one and all photos are printing with a green hue to them, what would cause this, photos were printing fine until cartridge changed and all cartridges are in the correct places
  • 8 more comments
  • Anonymous Nov 14, 2007
    Same problem except with yellow cartridge.
  • Geddes Dec 07, 2007
    Now printing with a red hue.  Can't seem to get rid of it.
    Ideas?
  • Anonymous Dec 10, 2007
    Yes, I have the same problem. The photo magenta needed a new. It does not print any reds.....help!!
  • Anonymous Jan 03, 2008
    Mine is printing with brownish color. I have checked all colors and bought new ones that were low. Checked to make sure they were seated properly and still brownish tint.
    Awoo
  • Guitarzam Dec 07, 2008
    Same thing...changed out the Photo Magenta and now everything has a green tinge to it...arghhhh
  • Anonymous Dec 13, 2008
    Mine is printing in shades of red and pink. I've cleaned and deep cleaned and changed the cartridges and made sure the cardridges are fully seated. Nothing seems to help. Anything else I can do??? Solutions 1 and 2 do not work for me.
  • loosecanon Dec 25, 2008
    Same exact problem as above. What will get rid of the green hue over all the pix?
  • dormadomez Jan 11, 2009
    All of my prints have a green edge to them, always on the left side from top to bottom. I have done the recommended deep head cleaning but it still remains...
  • dragonsjaws Mar 02, 2009
    Changed ink cartridge, now printing with green hue on Canon i960..
    I also recently changed to Vista with current canon drivers for Vista..
    and now this! This printer printed perfectly beautiful photos until Vista ... i believe this is the problem. Any solutions?
  • Anonymous Mar 22, 2014
    lost instruction book, just need to put in new print cartridge and forgot how
Most of the time this happened to me, I noticed I knocked one of the ones next to it slightly loose. Just check and make sure they are all seated fully.
Posted on Sep 25, 2007
Check the magenta cartridge is it not dry or try to clean the magenta cartridge nozzle and see. bye
Posted on Sep 24, 2007
SOURCE:
Photos are coming out Orange
Clean your print head under the ink maintenance / cleaning. Then test print. All your colors should pass this test. Your magenta is not complete.
Nov 21, 2013 | Brother DCPJ315W AllInOne Inkjet Printer
PIXMA MP 600 PRINTER EVERTNING PRINTS GREEN
Usually I see that when you put in photo magenta when it should be plain magenta.Otherwise you need a new printhead.
Jul 03, 2009 | Canon Pixma MP600 Printer
HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
Canon Pixma MP830 printing red/orange hue on glossy photo paper
are you using geniune canon glossy paper??? it is designed for the printers and really is the best for the machines
Apr 08, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon i9900 isn't printing photo magenta
Use denatured alcohol to soak the print head. Then use suction to draw the alcohol back thru to the foam ports where the ink cartridges rest. Continue until the alcohol runs clear. Then use water and then repeat with alcohol. Allow to dry and re-install in printer. Use new ink cartridges when re-starting printing.
Dec 31, 2008 | Canon i9900 InkJet Photo Printer
Canon i9950 prints green on photo paper
I had the same problem. Having checked other websites I came across the following which narrowed down the problem to the Photo Cyan / Photo Magenta ink tanks, and replacing the Photo Magenta one (although it was not empty) has successfully resolved the problem. Eveidently ink from the original one was not flowing and so caused the syan cast. (I experimented by subsequently removing the Cyan one which produced prints with Magenta cast)
TEXT OF POST I FOUND:-
That post is labeled "Cannon (sic) S9000 Print Head" and concerns a greenish hue error in all print quality levels OTHER THAN plain paper. In other words, all output designated as Photo Paper Pro, Glossy, High Resolution Paper, etc., results in output with enormous and unacceptable levels of green hue. All output designated as "Plain Paper" whether the output actually is on plain paper or photo paper pro, turns out well.
This problem is not unique to the S9000, as I experienced it identically with the S820 and predictably can occur in any printer with the six cartridge print head.
It is a frustrating problem because you know that the printer is physically capable of printing WITHOUT the hue (as it proves to you each time you choose a "plain paper" paper setting.)
Troubleshooting by reinstalling and updating the printer drivers, and uninstalling/reinstalling the ZoomBrowser EX, replacing the ink cartridges, and deep cleaning are all blind alleys.
A call to Canon support solved the problem for me with this simple and important revelation:
The Plain Paper setting is unique in its use of only 4 of the 6 cartridges. In the Plain Paper setting, only the black, cyan, magenta and yellow cartridges are utilized. The Photo Magenta and Photo Cyan are not utilized. In all higher resolution settings, i.e., in all other settings, all 6 cartridges are utilized.
It follows that if one's problem disappears when not using these two Photo cartridges (i.e., when printing at the Plain Paper setting), then the problem lies with these cartridges.
(In my case, I'd loaded a plain "Cyan" cartridge in the "Photo Cyan" slot during earlier trouble shooting and had forgotten to replace it with the proper Photo Cyan cartridge.)
Problems with magenta hues would admit of the same solution.
Hope that helps anyone else out there tearing out their hair trying to troubleshoot this. "
Dec 10, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Green tint on photos
perform deep cleaning and nozzel cleaning from the printer properties
May 16, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Green hue to photos
Canon, in its infinite wisdom, markets two sets of inks with the "part" number 3e. One of these, labeled simply with the color, is suitable for the i560 printer. The newer inks, labeled as "Photo" + the color, are not. Silly me. I just looked at the number and bought the wrong stuff.
Apr 24, 2008 | Canon BubbleJet i560 InkJet Printer
Too much green
It is unlikely that the sudden appearance of a green hue is due to the printhead or drivers going belly up. If the images on photo paper are OK when using the plain paper setting but have a severe green/blue hue when using the higher photo settings it is likely that the photocyan cartridge has been contaminated with cyan ink. Throw the contaminated PCyan cartridge away and fit a guaranteed photocyan cartridge (OEM or compat). Carry out a deep clean and run several plain papers through on a high photo setting. The green hue will gradually disappear.
Dec 06, 2007 | Canon PIXMA iP8500 InkJet Photo Printer
Canon I960 InkJet Photo Printer Logo
536 people viewed this question
Clive
Clive
old marine
old marine
Ekse
