Question about Lexmark X1270 All-In-One InkJet Printer
I can't print
My computer says you need put the driver
    President:
  • 414 Answers
Follow the link and select either xp or vista drivers.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:537:0:0
Mark
Posted on Apr 23, 2009
I installed Windows 7 on my computer and since the installation my MX700 has refused to respond
You need an updated driver that works with Windows 7. Go to the following link, click "Software & Drivers", then select "Windows 7" from the drop down menu. You will want to install the first item on the list for networked printing, or the second item if you don't need networked printing.
May 05, 2011 | Canon MX700 Office All-In-One InkJet...
Printer wont print how can we reset so that it prints from everyones machine
make sure that the ip address sub net mask is first correctly put in the machine yhen if you go to your computer bring up the command c promt then type on the c: ping followed by the ip address of the machine if you get 4 replys with no drops it can see the machine
you can set it up to print to all the machines you will need to down load the printer driver from the konica minolta web site www.konicaminolta.com if you dont have the print driver it is best to have an it person do this as the driver should be loaded on to the main server then you will need to go to each computer select the driver from the server and install it on to each computer you could load the driver on each computer one at a time but this would be longer to do
Feb 01, 2011 | Konica Minolta DiALTA Di200 Copier
Everything was working perfectly with my HP CM1015, I now have a new computer Windows 7 32 bit Home Premium and Microsoft Office Professional 2010. All my folders have been copied on to my new computer...
First here is the lnik to the drivers:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1846081&prodTypeId=18972&prodSeriesId=1846080&swLang=8&taskId=135&swEnvOID=4062
However when you go to print go into the printer driver properties and confirm the driver is set to print in color. Most HP color machine drivers have a automatic and manual option with the driver, which allows or restricts printing in color.
Oct 21, 2010 | HP LaserJet CM1015 All-In-One Printer
I have a HP Deskjet 6122 Printer and I need a driver for Windows 7 that I can load on a flash driver to put on another computer
Windows: "Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are resident/included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Feb 14, 2010 | HP DeskJet 6122 InkJet Printer
Printer is printing foreign looking characters all on its own. No print jobs are being sent to the printer. Printer is set to DEC mode and the macro has been reloaded several times. As soon as you put the...
It sounds like data is being received by the printer from an outside source.
Try disconnecting the printer from the computer system so it is a free standing printer. Power the printer ON and put in ONLINE if you do not get strange characters printing the print job is definitely from the computer system some place.
If you do not get the print jobs printing when the printer is disconnected from the computer system, it could be that the print jobs are being sent from the wrong driver or print queue on the system, you may need to try to identify who is sending the rogue print jobs.
Feb 10, 2010 | TallyGenicom LA800+ Matrix Printer
My MP730 will not print from the computer. It
The print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 min then turn the print head around with the nozzles down.Hold that for every color of 5 min.Then put the print head in hot water with the nozzles down.Left it water about 15 min and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Nov 27, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Cannot print from computer. printer will print test pages, though
How the printer is connected to PC Via USB or using Network Cable. If it is connected Netwrok cable than printer configuration page and on netwrok configuration there will be IP Address if this is valid IP Address than reinstall drivers and upgrade the Firmware of the printer.
If Printer is connected USB than try different USB Cable and try different USB Port on the computer
If USB port on the computer is working fine and check in Device Manager if the printer has detected as unknown device or not detected at all.
If detected as unknown device than reinstall printer driver if not detected at all than USB Port on the printer is faulty you need to set up hardware repair of the printer.
Oct 16, 2009 | HP Color LaserJet 3500 Printer
How to connect my epson stylus c60 to my computer
What Operating System do you have? ie; Windows XP, Windows Vista?
  1. Do you have the instructions and Print Driver for the printer?
  2. Do you have the printer cable to connect to PC?
  3. If you have 1,and 2 then
  4. Put the Disk that came with the printer into the computer.
  5. It should start up if not you will need to go to my computer and look for the drive you put the disk into and click on it and then Select the Run.EXE file
  6. Follow on screen instructions
  7. Once prompted connect the printer cable to the printer
After all drivers are installed you should be able to print from your PC.
Hope this helps
Jul 05, 2008 | Epson Stylus C60 InkJet Printer
How do you set up wireless printing w/the canon PIXMA MX700?
Hi Coach!
Here is a tutorial that will explain most of the basic steps to sharing your printer. It will walk you thru how to set it up.
With the Canon, MX700, on each machine you connect to the printer, you will have to have the driver CD. When XP asks for the drivers, just put the CD, and XP will find it drives it need. This whole process will go smoother, if you use a printer cable and not the USB. If you need the drivers, you can get them on the Canon site.
Good luck,
http://www.pcstats.com/articleview.cfm?articleID=1596
Jan 06, 2008 | Computers & Internet
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
