Question about Scotsman Ice Machine, Cuber, 1930 lb. Unit, Head Only
My binsensor lingh is on but my bin is not full so my ice machine
How can i fix this problem my binsensor keep com on every is maked ice. and shutt y machine off. i have scotsman ice machine
  • 1 more comment
  • ongdao88 Apr 23, 2009
    yes HTB350
  • John Tripp
    John Tripp May 11, 2010
    The model number HTB350 comes up as the Modular Ice Storage Bin below ice maker. See what you have for the top section. And look at circuit board while the machine is beginning to drop the ice. Most times a light on board will be on saying door open or bin is full. If that happens it confuses the memory board.
  • John Tripp
    Do you have a model number for your Scotsman? Not sure if I can help but we can give it a try.
  • Scotsman Master
  • 4,654 Answers
I see you already said you bin sensor light was on. The drop door has a metal tab that waves over a sensor as it opens, if that part when it closes does not tell the board that door is shut the the board thinks the bin is full. I know you already know that but until I can talk to Scotsman on the phone or review their service manual for your model. One good thing about Scotsman is they are very helpful to their customers. Unless the machine is obsolete.
Posted on Apr 23, 2009
  • John Tripp
    John Tripp Apr 24, 2009
    Have you been able to get answers. If I can help you let me know. Thanks, JT
  • 100 Answers
BIN FULL LIGHT COMES ON WHEN YOUR PHOTO LENS HAVE SCALE BUILD UP ON THEM (HAVENT BEEN CLEANED/DESCALED IN A WHILE, ALSO WHEN CORRSION IS ON THE LEFT SIDE(RED/BLK) WIRE OR IT POPPPED OUT PLACE, BUT IF YOU HAVE A BIN STAT IN PLACE THAT ALSO COULD BE FAULTY... MODEL OF UNIT INFO I COULD GIVE MORE INFO
Posted on Dec 04, 2014
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 107 Answers
What is model of unit
Posted on Apr 20, 2012
Ice bin full does not shut down.
It really helps to know the model and make of the refrigerator. The full bin on some models have a bar that gets raised up and if the bin full, the arm gets raised high enough to open the circuit for ice production. When ice is used the bar lowers and a Microsoft in the controls shut starting the ice production again. If bar is missing it will keep making ice until you raise the bar to the off position.
If you have one of the new type ice machines, some of them use infrared sensors and thermometers and the like to sense ice production.
If you have a fairly new refrigerator, it may be still under warranty and for small fee a factory trained representative can analyse cause and replace broken parts under warranty. Warranty information will be in the information package that comes with the machine.
Hope this helps!
Apr 19, 2016 | Refrigerators
Won't make ice
The bin should fill up and the machine shut off in 24-36 hours from time it is turned on. If not the condenser coil may be dirty.
1.Clean the coil this should be done every year.
The bin brain may be partially restricted causing ice to melt faster.
1. clean out the drain.
The air flow to the condenser may be obstructed.
check to make sure there is nothing covering up the grill or coil.
Nov 29, 2013 | Scotsman DCE33PA1BC 15in Built-in...
Machine has stopped working and is in alarm
Possibly a stuck or defective ice level switch in the ice bin. It's supposed to cease the ice making when the bin gets full and then return the ice making components back on when the ice level drops to a certain level. Should be an easy fix if the switch is bad. The wires have push connectors on them.
Sep 06, 2017 | Kitchen Appliances - Others
Does dump valve shut off after making ice
is your bin line and dump line tied together if so it could be just ice melting. If not can you here water filling up constantly while machine is off? if so is it running over sump tray into ice bin. if dump valve was stuck open then machine will not make ice.
Jun 25, 2013 | Scotsman Kitchen Appliances - Others
Scotsman ice maker cme1356 remain on harvest
Check bin full sensors make sure that the wires are making good contact on the board and make sure they are working run your hand between them you should see the bin full light come on the board if not replace the bin full sensors. If the light comes on then replace the board.
May 25, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Should a scotsman ice machine automatically stop making ice once the bin is full
Yes, all ice machines have a means of automatic shut down when the bin is full. What is the model number of your machine and your bin?
Dec 16, 2010 | Scotsman Ice Machine, Cuber, 1930 lb....
Ice machine keeps going to "off" mode. detects full harvest but no ice made. also condenser fan doesnt seem to be working.
o[en bin and look at your sensors, more then likely they have a scaley build up. the sensors are located below the ice maker and before the bin. It looks like a button of sorts one on each side, you can use a tooth brush to clean them. This should fix the problem
Jul 16, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Bin Full light stays on all the time
This is usually an indication that the photo eyes are probably dirty. They "See" across the opening where the ice drops through. If they are dirty, it registers as a fill machine.
A bin stat can cause the same problem.
The eyes and sometimes be a major problem finding them getting to them. On smaller machines like this one, it's hard to get your hands on them.
Good Luck and hope this helps.
Jan 08, 2009 | Scotsman Freezer Clear Icemaker w/ Pump
Bin control
The bin control shuts it off when the ice bin is full. Without a bin control it should keep making ice and never stop.
Dec 27, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Scotsman Ice Machine, Cuber, 1930 lb. Unit, Head Only Logo
753 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
