Question about Olevia LT32HVM 32 in. LCD Television
Four digit code for AT&T u-verse remote,,,tv is an ILO
I am looking for the four digit code to program my remote to the AT&T Uverse system. I have a ILO tv. No luck using the AT&T web site. Odd brand TV, I guess
  • 1 more comment
  • calvinfraker Apr 23, 2009
    That code did not work. Thank you
  • Anonymous Apr 23, 2009
    no it did not work
  • Anonymous May 19, 2009
    Nope !!!!
    Problem Solver:
  • 6 Answers
I think the code is 1342 let me know if this will work.
Posted on Apr 23, 2009
How to Program an At&T Uverse Remote Control?
Turn on your U-verse TV, press Menu on your U-verse remote ,
select Help, Information, and then Remote Control Setup. Next,
select your remote control from the TV onscreen list. Refer to
your specific remote for TV/device setup options. Select Top Ten
Brand Setup, Automatic Code , Learning Mode, or Manual Setup.
Oct 19, 2016 | Televison & Video
PROGRAM MY UVERSE REMOTE TO TCL TV
0174,0179,0173,1070. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jan 21, 2014 | Televison & Video
I have an ilo tv and it is stuck on a blue screen when it is turn on and says composite in the top corner. i've purchased a new universal remote that has some ilo codes but none worked. when i do a...
Hello
It is very difficut to get a substitute remote control for your ILO TV. Anyway try these codes with your present remote control. These codes are with AT&T U-verse remote for ILO TV. The codes are:
1412, 1435, 1436
If these codes does not work with your ILO TV, buy one AT&T U-VERSE remote control. It will match for it. OK.
Jun 17, 2011 | iLO 3200 32 in. LCD Television
I have tried to program a At&t U-verse remote to my Apex LD3249. Have tried all codes from At&t U-verse list. None work.
On uverse i got my apex to program by doing the search of codes. There is a code you can enter then hit a button to sequence through all codes by hitting power i believe. when tv turns off you know you have the right one. I am having the same issue on directv now since it does not have this option.
Jan 18, 2011 | Apex Digital LD3249 LCD TV
Trying to program my At&t Uverse remote to my
Sherwood Receiver/Amplifier 5027 Sherwood Receiver/Amplifier 5027
always press the mode key of the device they want to control before pressing any other key
Power on the device
  1. Press and hold the appropriate Mode key (TV, DVD or AUX) on the remote control.
  2. Without releasing the chosen Mode key, press and hold the OK key simultaneously.
  3. Release both the Mode key and the OK key at the same time.
    All the Mode keys should flash twice.
    1. Enter the four digit setup code by pressing the number keys (0-9) on the remote control.
    2. The Mode key will flash three times indicating correct entry and return to normal operation.
    • When an invalid code is entered, the selected Mode key will give a long flash to indicate that the Member has not entered the setup code correctly. Start over beginning at step 3.
    • Should the remote control time out before the Member completes the code setup, they will need to start over.
    1. Point the remote control at the programmed device and press the Power key once.
    2. The device should turn off.
    • If it does not turn off, repeat steps 2 through 6 trying each code for the brand until the correct code is found.
    1. Repeat steps 1 through 7 to program other devices if needed.
    2. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the Member's U-verse TV Receiver again, have them press the AT&T Mode key.
    Sep 05, 2009 | Sherwood RX-4109
    Att uverse codes/Cisco dvr box
    is ipn 330hd the model number for the cisco scientrific atlanta box
    Apr 28, 2009 | Televison & Video
    Att uverse remote won't work with other devices
    Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to helpme@att.net, and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
    Apr 04, 2009 | Televison & Video
    U-Verse remote for Digital Lifestyle
    I use my Directv remote to change the channel. What you have to do is go the your direct tv remote go to setup then go to remote then look for tv brand Citizen then follow the direction the menu tells you to do. It works fine. You can use Tv Brand Citizen, Concerto, Luxman They work with any u-verse remote 4 digit code 0056 5 digit code 10056
    Aug 13, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
    Olevia LT32HVM 32 in. LCD Television Logo
    1,150 people viewed this question
    Top Olevia Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Jaime Hernandez
    Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
