Question about Filter Queen Majestic Canister Vacuum
Vacuum gets hot loses suction and turns off
I have a majestic canister vac 4 years old have changed all the filters not sure if i changed the cellulose filter correctly tho [it had this problem before i changed the filters] nothing is plugged canister and hoses all cleaned out i don't want to buy another vacuum but i can't find a tech in my area please help thanks
  • tsosin Apr 23, 2009
    i changed all three filters it gets hot you can smell it then it loses suction and turns off i almost think something got in the motor i do have birds any other ideas?
    it doesn't sound any different than normal the speed seems the same how about if dust got in the motor?would that cause it and how do you clean it out
    Problem Solver:
  • 7 Answers
You need to replace your silencing filter on the inside. I recommend calling Health Mor at 800-344-1840 and having their Tech. walk you through replacing that filter. It should have been replaced at about 2 years. It catches the carbon off the motor, but if dust is getting through it can clog it and cause your motor to overheat.
Good luck,
FQ Master
888-637-4692 in Iowa
Your Filter Queen Authorized Service & Supplies
Posted on Jun 16, 2009
  • 116 Answers
You have replaced all three filters?
if its turning and sucking with all new filters you have a glog somewhere
Posted on Apr 23, 2009
  • erickg
    erickg Apr 23, 2009
    if its in the motor i think you would hear an unusual noise. unless bearings are bad and running slower?
  • erickg
    erickg Apr 23, 2009
    dont think dust in motor is possible since it would have to go through all those filters still think you have a clogged suction.
Will run for a few minutes, then red light comes on canister an unit shuts off.
That's the thermal cut off circuit. If the motor gets to hot it trips and shuts it off. When it cools down it will turn on again but it is generally an indicator of one of the following; the cone filter needs changed or the inner filter ring that sits above the motor inside the unit is shot. One is an easy change the other requires dis-assembly, better carried out by a vac tech if you aren't comfortable taking it apart. In the meantime remove the cap out of the top of the vacuum, that will let it exhaust heat better but I strongly recommend getting that filter ring changed.
Nov 27, 2015 | Filter Queen Majestic Canister Vacuum
My canister motor shuts off after a few minutes and a red light comes on
Filter queen vacuum head has no power
More information needed. When you turn on the vacuum do you hear the motor running? Is the problem that there is no suction at the head? Is there suction at the canister when the hose is removed? I would first check to make sure that there is no obstruction in the hose. Have you checked the filters to see if they are clean?
Sep 11, 2014 | Filter Queen Majestic Canister Vacuum
Decreased suction for filterqueen vacuum
Put a broomstick or such down the hose, something may be stuck. Look inside with the bag out, is there a screen before the motor?
Dec 01, 2013 | Filter Queen Majestic Canister Vacuum
Filter queen vac 2 years old suction poor cleaned hose canister and filter
Hi, Did you change both the cone and the filter on the top lid? If so, ther may be a leak in the machine breaking the air tight vacuum. When you put it together make sure its in properly and tight. Let me know if this does not help, I will look at something else. Chris
Feb 09, 2011 | Filter Queen Majestic Canister Vacuum
How often is it necessary to change the filter one on a Filter Queen Majestic?
The best thing to do to both, keep your Majestic suction and air flow strongest, and keep from pulling dirt & dust from being pulled past the filters which can cause damage to the motor, and charcoal filter, replace the filter once a month. If you use it longer than that it will both loose suction and will cause your Medipure or Enviropure "charcoal" filters to wear out prematurely. Mark the change date right on the filter or on your calendar to help keep track.
Dec 20, 2010 | Filter Queen Majestic Canister Vacuum
The red light by the on and off switch turned on . what does that mean
usually it indicates a low suction issue. Wether the hose is clogged, or either one or all 4 filters need to be changed. Usually the cone and the circular filter above the plastic cone should be replaced.
Good luck,
Mark
Nov 07, 2010 | Filter Queen Majestic Canister Vacuum
My vacuum made a funny noise, the red light was on and so I turned it off. There are small sparks now when turned on
Sorry. It sounds like the suction motor is bad. The best thing to do is take it to a reputable vac shop.
Joe
Oct 25, 2009 | Filter Queen Majestic Canister Vacuum
How to change upper filters?
Open the vac as though to change the cone and remove the plastic inner cone with the slotted screw at the bottom.. Underneath you will find a 5" disk , likely coated with fine dust.
That is the one which needs to be changed. Around that disc will be three more screws holding the upper housing onto the vac. These ones are accessible from inside, if changing the motor.
Below the handle of the vac there is a serial number ring and three screws in an offset triangle. If you remove these and the rubber cover for the toe switch, the vac housing will come off. This will reveal the `foam or cotton ``muffler``. You can replace it or wash and dry it if foam. It acts as a muffler more than a a filter....
Oct 17, 2009 | Filter Queen Majestic Canister Vacuum
Suction problem
first thing you need to do is replace the disc filter benieth the conical shaped shroud. also there is batting in the upper part of the vacuum tat should be replaced once every 4 years as well as it gets clogged with carbonfrom the motor. this increases the air flow through the vacuum keeping the motor cool and increasing your suction as well. the disc filter benieth the conical shroud should be replaced every 6 months under normal use and every 3 months under really dusty situations, and if vacuuming up fine talk powder every month. also check for a clog in the hose by hooking the hose up to the blower port on the top of the vacuum.
Sep 15, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
406 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
