Question about Samsung PCJ522R 52" Rear Projection Television
Picture is very yellow
Samsung PCJ522R its an old TV but i have not had any problems but here recently the pictures color has gotten very bad. The picture now is yellow and the other colors are not very bright. I have tried to adjust the color but it doesnt help. SHould i just trash it and get a new one. I really dont have the cash and would like to make this one last about another 8 months so i can pay cash for a new one.
  • benwest76 Apr 23, 2009
    thanks for the help i will check with a tec in my area.
  • 65 Answers
If this is an old 52 projection with bad color your oil in the tubes may need to be changed, focus & screen can be adjusted to improve picture. Changing oil is something a tech defintly has to do. Call a local tech & get pricing. Then u can weigh your options. Also tubes may be weak. If they need to be changed probably won't be worth it.
Posted on Apr 23, 2009
Samsung DLP tv white color turned to yellow
go into menu reset picture settings to default
red , tint or gamma is off
Nov 15, 2016 | Samsung Televison & Video
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
My 50” Samsung DLP (model HLN5065W1X) has 2 issues: 1. picture sometimes does not come on When starting up, the warm up lamp is on. Should take less than 30 seconds to come on. Sometimes takes minutes,...
It is a common problem for the Samsung DLP HDTV, the problem is that the color wheel is going to go bad. The only way to fix it is to replace the defective color wheel.
Jun 01, 2017 | Samsung PCJ522R 52" Rear Projection...
Vertical lines in picture
The machine is still under warranty from samsung so I would call 1-800-samsung to find the nearest service center. Problem could be caused by a bad main board, bad lvds cable or a defective t/con board or lcd panel.
Jan 22, 2010 | Samsung LN46B640 LCD TV
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
YELLOW PICTURE
Your blue crt could be bad.
Jul 21, 2008 | Samsung PCJ522R 52" Rear Projection...
How to discharge capacitor
Most projection set will discharge them selfs to a safe level just after you unplug it. But being there are litterly hundreds of capacitor in this set you might want to describe the problem you are having before you gut the set
Mar 19, 2008 | Samsung PCJ522R 52" Rear Projection...
No picture
you are into really technical problems. There is HIGH VOLTAGE in any tv using crt's. please be careful!!
you should contact a qualified service center and them do the repair.
Sep 21, 2007 | Samsung PCJ522R 52" Rear Projection...
How do I get my HD channels to work?
if the tv is an LCD then you may have power supply issues inside the tv causing all of the trouble.
if it is a projection tv then it sounds like you have multiple problems.
contact a service center for this problem.
Aug 29, 2007 | Samsung PCJ522R 52" Rear Projection...
Samsung PCJ522R 52" Rear Projection Television Logo
417 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
