Question about Toshiba Televison & Video
Set up digital set top box
I have 6yr or so tv & want to plug in a set top box but don,t have button for av channel on remote toshiba ct 90119 remote number can u please help me thx trish
  • nannababe Apr 24, 2009
    tried tuning in but no picture on any of channels suggested thx for the hint no trouble with other tv just that this remote has no av button
  • nannababe May 07, 2009
    hi fixya tried all but using indoor aerial is this my problem for not tuning into digial as i can,t tune tv no probs with other tv with av wat am i still doing wrong do i need other cables as i give up thx
    Brigadier General:
  • 10,406 Answers
Either tune your TV to channel 2 or 3 or (on some TV's) to 91.
Then, connect the COAX-output from the set-top-box to the COAX-input on your TV, or connect the "output" Red/White/Yellow RCA-jacks on the set-top-box to the Red/White/Yellow "input" RCA-jacks on your TV.
Posted on Apr 23, 2009
  • ikkenom Apr 25, 2009
    How are you connecting the set-top box?
    COAX CABLE -> SPLITTER -> TV
    and
    COAX CABLE -> SPLITTER -> Set-Top Box -> AV-out -> AV-in-on-TV
    or
    COAX CABLE -> Set-Top-Box -> COAX CABLE -> COAX-in-on TV?
    In the latter case, just leave the TV on Channel 3.
    All the channel-tuning will be done by the Set-Top-Box,
    i.e., no need for 'A/V' button on the TV's remote.
  • ikkenom Apr 26, 2009
    If you are connecting COAX-output from the Set Top Box
    then, with the Set Top Box turned on,
    access the TV's "menu" and run the "auto-program" ("auto-channel-scan") function.
    Your TV should detect just *ONE* channel (namely '2' or '3'),
    because the Set Top Box always outputs _only_ to one channel.
Button to scan in channels
The CT-90326 remote was included with several Toshiba televisions, including the 42HL800A. You can't directly scan for channels with a single button on the remote. First make sure that the TV is set to the TV input. (Use the Input button on the remote (top left) or the TV (lowest button on the left side as you face the screen).) Next press Menu (the second lowest button on the TV or the button at the lower left of the Left arrow button). Use the Left or Right arrows to select Setup (with the gear icon) and press OK. Use the Up/Down arrows to select Auto-Tuning and press OK. Use the Up/Down arrows to reach the line to select the type of channels to search for a signal. Then use the Left/Right arrows to select Digital channels, Analog channels or both. Go down another line to set the bandwidth of your broadcasts. Again use the Left/Right arrows to select the correct one. Go down one more line to Start Scan and press OK.
These details are in the manual for your TV. The manual for the 42HL800A is available from Toshiba's product support download page: http://www.mytoshiba.com.au/support/televisions/led-backlit-tv/hl800a/42hl800a/download . The direct link to the manual is http://www.mytoshiba.com.au/file/download/resource/file/19610/toshiba_32av80032%2040lv80026%2032el80032%2042hl800_om%20(au).pdf .
I hope this helps.
Oct 02, 2016 | Toshiba CT-90326 Remote Control
I have a Toshiba 19CV100U TV and a Toshiba CT-90275 remote control. My problem is that the dash button doesn't work so I can't put in digital channels. How do I fix this?
If your Toshiba TV does not have digital conversion built in, you will have to install a converter box and separate remote.
I have no idea what a "dash button" is or controls.
Oct 17, 2014 | Televison & Video
Describe your instructions Toshiba 29JZ5DA Problem I can't change it over to TV viewing I think it might be on AV but don't have a remote - have to change manually - help?
You'll need the remote to switch between the inputs and normal channels. You should be able to pick one up cheap online, just search for CT-90119.
Apr 04, 2011 | Televison & Video
Hi I have a Toshiba CT-90326 Television. How do I disable the Audio Description on it? Thank you
Hello Clare,
CT-90326 is actually the model number of the remote control rather than the TV. It doesn't really matter as the correct button on the remote is more relevant than the actual TV.
The Audio description is a feature of the closed-caption/subtitle settings on your TV. You should be able to switch off the audio description by pressing the "SUBTITLE" button on the top row of the remote control. Each time you press this button it will cycle between ON and OFF.
If this doesn't work, it's probably because you are using a cable/satellite/digital receiver. If this is the case, look for a button on your cable/satellite/digital receiver remote control marked "CC" "CCD", "SUBTITLE".
Please try the above and then reply to me from within this page. Please state the model number of the TV and any cable/satellite/digital receiver you are using if/when replying.
Thanks,
BElectric
Jan 28, 2011 | Toshiba Televison & Video
I changed the cabling between my Phillips tv and set-top box a few times and I lost the signal. The signal is from UPC, it's piped tv. They said to locate the av channel on the tv and this would restore...
The only way to change the source for the 28PW8608/05 is to use the remote. On the original remote, just below and to the left of the power button is the button you need. The image on it is a square with an arrow going into the square from one side. The inputs should go TV, EXT1, EXT2, (EXT3 on some models), Front). Depending on the set top box, you may need to enter the setup menu and set the digital source for the input (Press together Fast Rewind and Stop > Setup > Digital Source) or the decorder (next option in Setup).
If you do not have the original remote, you will need universal remote with an input or source button and to find the code that matches the function. Some codes may only operate the basic functions. (The lowest end universal remotes often lack this feature.) A universal remote that can be programmed via a USB connection with a computer will be the fastest to set up.
I hope this helps.
Dec 29, 2010 | Philips 32PW6506 32" TV
Weve got a toshiba tv model 289s4A & want to plug our ps2 into it, cant find how go get the av channel on the tv. We have connected the av cables but when you change channels on the tv, theres no...
If you have the remote, look for the source button. It should allow you to toggle the settings.
Otherwise they are usually after channel 2 as in Hdmi, Av1, AV2 etc..
Good luck
Dec 09, 2010 | Toshiba Televison & Video
How do you add digital channels without a remote for an RCA LCD TV?
have you fitted a set top box?
the set top box is the device that picks up the digital signals and displayes them on your AV selected channel. the channels are changed via this device not the TV
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Televison & Video
Took toshiba off comcast control and now ct-90157 won't work
We found the manual at home and was able to program the t.v. to recognize all the channels from cable and store them.
Jan 26, 2009 | Toshiba CT-90157 Remote Control
Set up av on Toshiba CT-871
Must Have been dirty connection tried a second tv it worked when back to the original it worked ???
Nov 15, 2008 | Toshiba Televison & Video
Remote control code to program for directv receiver
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Dec 27, 2006 | Toshiba CT-90157 Remote Control
Televison & Video Logo
279 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
