Question about Maytag MZD2766GES Side by Side Refrigerator
Fride not cooling on eather side..
Compressor cuts on for about 5 seconds then cuts off...power remains to compresor through the run capacitor...(both orange wires) wondering if no 134 in system and cycling the compressor off... or is there another control device in the circut...(blue wire)? posibly temp control...if so is it posible to jump the temp control to verify problem...
Thanks
    Guru:
  • 462 Answers
If your wondering how to check out your refrigeration compressor;
Modern Compressors have two operations that have to work together just to run. More items must be considered for them to work and work efficiently in systems. The 2 areas that must work together are electrical and mechanical. Either your compressor is broken inside or the motor and or start components are not working properly.
Electrical
Ohm the compressor terminals to ground and across to each other.
1. If any read anything to ground the compressor is bad. If not go on to the next step.
2.Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals. If you get only 2 readings don’t panic wait 24 hours for the motor to cool off for sure and recheck it. If still no reading then your compressor motor is open. A new compressor or replacement of the appliance is required. If you now get the 3 readings described make a diagram you feel comfortable with as to where the wires go to each component before removing anything, then continue:
3 Assuming the above checks out: Get a new *Start relay *start capacitor if so equipped relay *external overload and *run capacitor if it has one. In other words everything that is external and attached to the wires or terminals on the compressor or wiring per your diagram and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration.
*May or May NOT have this component:
*Start Relay:
MOST 99.999…% of refrigerators of the household type have a start relay of some kind and they vary in size shape and color. It plugs directly onto the compressor. SOME AC units but not all have one and it is different. These Resemble a box about 2”X2” X 3” with at least 3 terminals on it and these 3 terminals are marked 1, 2, & 5. Each of these will have at least 1 wire on them and there may be other terminals (4 & 6) as well that can be used with several wires on each.
* Start Capacitor
100% of AC and Commercial compressors that use a start relay (and remember some do not have one but those that do…) and only some domestic refrigerators use a Start Capacitor. At least 2 wires going to a black (usually) cylinder which is the start capacitor. Start Capacitors ALWAYS HAVE 2 or more Wires and ALWAYS HAVE TO HAVE A START RELAY.
*External Overload
MOST 99.9% of Household refrigerators, 80%+ of smaller commercial refrigerators, and most 90% of window unit AC’s but almost no central AC compressors Have an external overload. Those that do not have an internal overload. These vary in size and color and description a basic one is round 2 wires and generally black about quarter size USA AND IF USED ALWAYS MOUNTED ON THE COMPRESSOR with the other wires and terminals there.
*Run Capacitor
Some domestic refrigerators (can be a small rectangular box) medium and larger refrigeration and (99.999%... of all) AC central and Window units have a compressor that requires a run capacitor. These type units also have a fan motor that can require a run capacitor. These Capacitors always have at least 2 wires and often 3 or more if the capacitor also is wired to the fan motor.
If a compressor is tight due to linear expansion from heat a tip worth remembering is as something cools it contracts, except for water at freezing. A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours may have expanded parts from heat. About 1/2 the time it is ok after new start components are installed with a start capacitor and relay. The other 1/2 the compressor will be ok for a day or 2 then stop again. A “hard spot” in the movement of the internal parts in the compressor, and stopping on this hard spot it can’t overcome the “tightness”.
If you follow most of these steps above you will arrive at a correct diagnosis well over 90% of the time ( allowing for what is unusual or for misunderstandings)
30 years of doing refrigeration and this has not changed..
Please rate me as high as you can and ask me to clarify anything you don’t understand.
Posted on Apr 23, 2009
  • Maytag Master
  • 4,654 Answers
I believe your start relay and capacitor need replaced or the compressor is defective. Don't allow it to continue to try to start until we can find the problem. Let me know, Sea Breeze
Duo therm air conditioner that the compressor will not start
Hello,The freezestat should be closed.Try jumping that out .
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
Whirlpool refrigerator model ED5LHAXMQ10 AFTER A STORM WITH LIGHTINGS AND LIGHTS WENT OFF ITS NOT COOLING AND THE COMPRESSOR STARTS AND TURNS OFF IN LESS THAN 10 SECONDS.NOT COOLING IN FREEZZER OR...
You need to replace the overload/relay , on the side of the compressor . Pt # 2262185 . This part starts the compressor and keeps it running .
Aug 26, 2009 | Refrigerators
Constant clicking sound coming from power box amana fridge
When you heard the click and the compresor stops ,check if it's very hot , if yes the compresor is of on overload and this could happend because 1 the condenser coil is dirty ,2 the relay is bad or 3 the compresor has a problem .Also check if behind the kick plate there's a timer (some units have it there or next to the cold control ) that could cause a problem too.
Aug 23, 2009 | Refrigerators
Have a Bryant AC/Heat pump. Model# 661CJ030-A. Problem: Air conditioner not cooling,fan comes on,there is a click and a hum but compressor doesn't come on to cool. Does thermostat have anything to do with...
Found charge capacitor top ballooned replaced with a universal capacitor found at a local appliance repair shop system works like a champ capacitor is located behind the interior electrical panel after removing the side panel
Aug 19, 2009 | Bryant 463AAC008BA Air Conditioner
Ruud 10 compressor not working
First make sure there's power to the unit outside , if yes set the theermostat on cold ,auto and to the lowest degrees ,then look the outside unit contactor, it should be pulled in (sometimes it takes to 5 minutes beacause a time delay) , if not the problem is in the thermostat , but if yes and there's power on the other side of the contactor ,either the compresor running capacitor is bad or the compresor itself went bad .Try replacing the capacitor first (the cheaper option) and adding a startting booster in paralel with the capacitor ,if still the compresor doesn't start you nedd to replaced it.All this counting that the fan in the outside unit works ,if doesn't replaced it.
Aug 05, 2009 | Ruud Matching Split Air Conditioner
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
Jul 18, 2009 | Frigidaire FRS23R4A Side by Side...
Not cooling - sounds like something is trying to start then clicks off
Try first replacing the relay(located on the side of the compresor)wich the part won't cost more than $20.If doesn't work the compresor is stuck or burned and you need to replace it.
Apr 19, 2009 | Refrigerators
Refrigerator quit working.
for what you are saying check your voltage check if your compressor or check if condenser working you need the fan to cool the compressor down
Apr 07, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
Kichenaid refrig not keeping cold
Need to have someone with multimeter check the compressor and the capacitor. May be the start capacitor not allowing the compressor to run or continue running. Let me know, Sea Breeze
Mar 19, 2009 | KitchenAid Refrigerators
Maytag MZD2766GES Side by Side Refrigerator Logo
282 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
