Question about HP Wireless Optical Mouse
Help me make this wireless mouse work!
I just bought the HP wireless optical mobile mouse and can not get it to work! I have replaced the batteries, pressed the connect buttons simutaneously, switched usb ports and restarted the computer. I checked the device driver - all good. The red light is on, and the blue backlight on the whell flashes very slowly. The user guide said this was a sign of low battery, so i changed the batteries, but still, nothing! Please help or I may have to resort to a baseball bat!
  • Anonymous May 04, 2009
    I have the same problem.... Plug in the USB receiver, the green light flashes a couple of times...then nothing. Worked fine until I tried on my wifes laptop. Now won't work at all.... have tries holding connect button etc, no
  • j9pop May 07, 2009
    Exact problem the others describe.
I had the same problem and after hundreds of tries i push the button on the receiver and quickly the red connect button on the optical mouse for about 5 seconds and it work... i don´t know if it´s a final solution but this time it work´d
Posted on Oct 30, 2010
Hp wireless optical mobile mouse was working before but just didn't work again.
try changing the batteries and use it near the comp
if it still doesn't work try using it on a different surface
Feb 09, 2011 | HP Wireless Optical Mouse
Bought a HP wireless optical mobile mouse and it worked once then stopped. It came with no software, what do I do?
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable))
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware make sure you have the correct mouse selected also under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Feb 01, 2011 | HP Wireless Optical Mouse
Wireless mouse won't connect hp wireless optical mobile mouse
press the connect buttons on the mouse and the reciever
Dec 27, 2010 | HP Wireless Optical Mouse
I bought the mouse but it does not work. hp wireless optical mobile mouse
Check that the receptor end is firmly placed in the USB port.
Bring the mouse close to the receptor and see if works then.
Check if you put batteries in the mouse.
Check the battery enegy levels.
Aug 16, 2010 | HP Wireless Optical Mouse
Try changing the batteries or charging if it is rechargeable or try re-syncing using the syn button.
Nov 26, 2008 | HP Wireless Optical Mouse
Hp optical ps/2 3 button wireless mouse
have you tryed to reconnect it?
I supose you put the same type of batterys in? same voltage and so on. it might be that the mouse doesnt get enought power.
Apr 30, 2008 | HP Wireless Optical Mouse
HP 3 button wireless optical mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Oct 04, 2007 | HP Wireless Optical Mouse
HP Wireless Optical Mouse Logo
856 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
