Steiner Tasco Offshore 54 Binoculars 7 x 50
Problem for Steiner Tasco Offshore 54 Binoculars 7 x 50
I see double one over the other about 20 degrees
By o2babright1 on Apr 23, 2009
my binoculars i see double one over the other about 20 degrees diagonalcan you help
Solution #1
posted on May 09, 2009
Not Rated)
mattress67
Rank: Guide
Rating: 100%, 5 votes
Up close to the eyepieces around the barrels are small screws that you can use to "collaminate" your binocs. The screws aren't meant to be accessed by the owner and most manufacturers cover them up with the material that surrounds the binocs. Of course the binocs in their current state are useless anyhow, so I wouldn't hesitate to peel up the material to look for the screws. If you do it carefully, you can reseat the material anyhow. Then once you locate the small screws, put the binocs on a stand or a table outside. Focus on something far away using one eye. Then using both eyes, you adjust the screw on the other eyepiece while looking through the binocs. Adjust until you get a single image. You can use loctite, or nail polish to "glue" the screw in the final position if it is really loose.
Was this helpful?
Yes
No
Popular Solutions for Steiner Tasco Offshore 54
Questions and Unsolved Problems for Steiner Tasco Offshore 54
Do you recommend Steiner Tasco Offshore 54 Binoculars 7 x 50?
Answer
Answer
one arm is loose; how do I tighten it?
Answer
Needs to be openened, cleaned, and lubricated. I had this done about 10 years ago and the company... (More)
Answer
I have a pair of 25x100 Orion binoculars. The metal bridge is broken. Is it possible to repair this.
Answer
humvee binoculars 8x21 dcf unable to adjust both sides at same time. only one side each time.
Answer
I just decided to look in this problem on my binoculars Jason 2000. In which I have a double... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Steiner Tasco Offshore 54...:
Top Binoculars Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Binoculars Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
