Question about Refrigerators
Westinghouse RP423 Freestyle fridge cooling failure
Westinghouse Freestyle RP423 fridge is not cooling at all. Fidge light is working, thermostat relay clicks, no compressor noise whatsoever, 240VAC fine as measured at (what appear to be) the compressor terminals
  • 4 more comments
  • herman985 Apr 24, 2009
    Hi Sea Breeze,
    Indeed, the motor makes no sound whatsoever, and gives every indication (audible-wise) that it is not turning over. As such, the compressor is not working either i.e. not hot or warm, or anything really.
    A possible cause might be the defrost switch. From what I can determine, it appears that the defrost cycle timer/switch is combined with the thermostat inside the fridge compartment, but I find it difficult to say whether it might be stuck in defrost mode, or whether the compressor motor has simply failed. Any advice on what to look for?
    Thanks
    Forgot to add, no fan of any kind is evident (although I assume they must be there), and I certainly can't hear one working either on top of the compressor or behind the evaporator.
  • herman985 Apr 25, 2009
    Thank you for the reply. Actually I’m in New Zealand, not
    the UK, but the voltage is the same, 240, not 120VAC
    Prior to reading your last message, I’d already gone ahead
    and traced the fault to the thermostat/defrost switch unit. I bypassed the
    switch and, as a result, the compressor/motor powered up and worked just fine.
    Your advice on testing the motor is useful though, so thanks for that.
    So the problem is definitely in the thermostat/defrost cycle
    switch unit, and I’m assuming that it is stuck in the defrost mode. I could
    easily remove the switch unit, but for, what would appear to be, the
    temperature sensor wire. This wire cannot be disconnected i.e. it comes
    directly out of the switch unit and runs behind the evaporator plate at the
    back of the fridge. So it looks like I’m going to have to carefully move aside
    the evaporator plate to see if that wire can be removed.
    All the other electrical wiring, including what would appear
    to be a 20 K-Ohm heating loop for the defrosting, can be unplugged from the
    switch unit.
    Any further recommendations for testing the switch unit in
    any form or manner? Thanks Sea Breeze.
    Indeed, Sea Breeze, a diagram would be very useful.
    Here is what I could find in terms of fridge identification:
    On fridge Door: Westinghouse Freestyle
    Inside the fridge: Model code RP423BQ-RWZ  serial no 90340 263   Made in Australia by Emall Ltd.
    The combined thermostat/defrost cycle switch also has a
    number; it’s somewhat hard to make out but it appears to read as:
    Danfoss EN60730-2-1-25T65 (it mentions it’s a 240VAC unit)
    Now, the only part on this switch unit that could possibly
    rotate (apart from the obvious thermostat dial) is a very small allen key hex
    bolt, recessed into the back of the unit. And when I say small I mean small; I
    don’t have anything that fits it. Would this be the defrost timer adjustment?
    One further observation:
    After I had visually examined the switch unit (I’d moved it
    about a bit to read the serial number) I plugged the fridge back into the mains supply
    just to see if the fridge would magically start; to my amazement it did!
    However, the joy lasted only as long as it took for the fridge to cool down to
    the requisite thermostat setting. It then switched off, as it should have, but
    alas never came back on again later.
  • John Tripp
    John Tripp May 11, 2010
    The motor makes no sound like its trying to start? Lower fan and upper fan in freezer working? Touching the top of compressor is it hot to touch? Let me know, Thanks Sea Breeze
  • Anonymous Mar 29, 2014
    Westinghouse
  • Refrigerators Master
  • 4,655 Answers
I am going to assume you are in the UK. the voltage is higher than most household refrigerators here in the USA. Disconnect power to refrigerator and check continuity on two of the three terminals of the compressor at a time until you measure the resistance in the windings all the way around. The terminals should be marked R, S and C. (Run, Start and Common) you should get a reading with your multimeter all the way around. When you have done this and have the readings I want you to touch one end of your multimeter to the metal pipes or any clean metal outside the compressor and the other to one of the three terminals one at a time like you tested before. With your multimeter set up the same, see if you get a reading from metal housing to the three pins, or terminals c, r and s. You should get no reading. If you do, the compressor is a burn out and on the first test if you don't get a reading on the two at a time test between two post that is considered to be open or broken windings. The compressor does have an internal overload that may be open also. But if cool at time of test, and it shows up the compressor in bad. Let me know what you find...Thanks, Sea Breeze
Posted on Apr 24, 2009
  • John Tripp
    John Tripp Apr 25, 2009
    OK, we are going to need some different numbers to locate the exact Westinghouse Refrigerator. Don't take too much apart until I can find a diagram. Here is what I need in photo below. If it is the defrost timer then timer can be turned slowly clockwise and the refrigerator should come on. Model RP423 does not come up on my source listings. I did leave out that during testin compressor the wires must be removed from the compressor terminal post. But since you bypassed the defrost timer I think the problem is the defrost timer. Please let me know, Thanks, Sea Breeze
Fisher and paykel xrss 267BB fidge freezer
The system is either blocked or you have a gas leak but i would expect it is blocked and the only way to find out is to get a refrigeration engineer to check it for you, but explain the problem to him first and make sure he can help before you spend money.
Jul 19, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
How old is my fridge
most electrolux/ westinghouse products you can use the serial number to identify the production date ( eg: 345978 ) the first number represents the year( eg: 3 45978 )( 1993 or 2003 ) hope this helps
Apr 08, 2014 | Westinghouse Refrigerators
My Westinghouse freestyle fridge freezer is running but is not cooling the fridge at all.
there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Mar 19, 2011 | Refrigerators
Seems like my thermostat is not working correctly, this Westinghouse Freestyle fridge is not cool enough. Not sure how to check thermostat and also replace, if this one is faulty.
Call a fridgy, use a multimeter to see if the thermo contacts open and close or see below:
These parts need to be ordered in from Adelaide, that is where the large warehouses for Electrolux are. The part number for the thermostat is 1416543 @ $77.00 each,
the heater 1413084 @ $28.50 each. Allow about $18.00 for Postage and Handling
Feb 05, 2011 | Westinghouse Refrigerators
Im after a manual for westinghouse freestyle fridge RJ422T-R
You can go visit onlinand Google.www.manual for westinghouse freestyle fridge RJ422T-R
Oct 23, 2010 | Refrigerators
Westinghouse freestyle fridge. Fridge compartment not staying cold, freezer compartment working fine.
likely a malfunction somewhere in the defrost system, i.e., the defrost timer control, the defrost heater assembly, or the defrost bimetal thermostat
Mar 01, 2010 | Refrigerators
Westinghouse model RS663T - not cooling fridge or
IT IS THE DEFROST THERMO STAT REMOVE REAR COVER AND MELT ICE IT IS ROUND SILVER PART
Jan 31, 2010 | Refrigerators
Fridge freezer not cooling
(bad news) Repair man came today and said the compressor has died ;- (
(good news) Westinghouse will replace compressors less than 5 years old with a new one, just ring them with your serial number (inside front door) or supply a receipt and you only have to pay for the labour ;-)
Apr 12, 2009 | Westinghouse Refrigerators
My fidge wont cool down
Most likely a defrost problem..check the defrost thermostat, timer, heater, fan... if the fan in the freezer compartment running?? sometimes ice will form in the vents...check the easiest things first ..like the vents and drain tubes,,
Aug 20, 2008 | Refrigerators
Refrigerators Logo
1,759 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
