Question about Olympus Camedia C-350 Digital Camera
Lens only comes half way out
When I slide the lens cover open, the lens only comes 1/2 way out, then goes back in and starts beeping and won't let me take any pictures
I had a problem that may be related to yours. From time to time, whenever I opened the cover, the lens wouldn't work properly. It would make a grinding noise and then when I took pictures they would all come out out of focus. After much fiddling about, I eventually discovered that if I set ALL RESET to FALSE on the SETUP menu, it returned to normal. Possibly this could fix your problem. Otherwise maybe its a battery problem. My camera sometimes refuses to take pictures when the battery is low.
Posted on Nov 09, 2007
  • major_easy Nov 09, 2007
    Woops, made a mistake. I actually meant that I had to set ALL RESET to TRUE to fix it.
On our panasonic DMC - SZ6, the lense cover won't open when turned on
Lens covers are delicate things. A bit of dust or dirt inside and the the springs can't do their job. When cleaning doesn't work, to repair this I remove the lens cover and shorten the springs by cutting off a bit and then reattaching them. A small bit of mollyd to lubricate helps too. never use oil or silicone.
Oct 31, 2017 | Panasonic Lumix DMC-TZ3 Digital Camera
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
The slide at the back of the phone won't let the camera work
Possible that the switch on micro switch which triggers from the slide cover is damaged and so does not switch on. You might need to remvoe to find this fault and replace the switch, set the alignment once again or refix the switch .
Jun 06, 2012 | Sony Ericsson Cyber-shot C905 Cell Phone
It the lens slides out half way and makes a beep noise and goes back in
Hello
The lens gears might be damaged or out of calibration need to be handled by Samsung support nearest you or claim the warranty if it has.
Some time the low battery gives the same problem
Good Luck, and do rate the solution if helped
Dec 22, 2010 | Samsung SL202 Digital Camera
Regrding Olympus Stylus 500.. When turned on the lens cover opens half way twice then closes with a green flashing light and beeping sound.
Have just solved similar problem with mine. Problem turned out to be that the lens cover was very slightly dented in. It didn't really look dented at all, but just wasn't quite symmetrical and was a bit more recessed on the side away from the shutter button. This was causing it to rub on the case when it tried to slide. (Mine had been not sliding completely shut for a while before it stopped opening properly too).
To fix it I undid two small cross head screws which let the front panel be prised off. On mine, with the front panel off, the lens and lens cover mechanism all worked perfectly, as the problem was that the lens cover was rubbing on the front panel. If yours is still broken with the front panel removed, then your problem is not the same as mine...
I used a small screwdriver to push out the metal bar on which the top of the lens cover slides, pushing on the right hand end of the bar to slide it left and out through the USB connector compartment door. That lets the top of the cover come off the bar and move freely. To take the cover off, it has to be detached from the arm which moves it. There is a pivot trapped in a slot in the arm, but once the cover is off the bar at the top, it can be moved down so that the pivot reaches the bigger hole at the bottom end of the slot in the arm. This lets the whole lens cover come off the camera.
I then used a screwdriver to gently push out the middle of the cover until its shape was more symmetrical. (I'm not sure a screwdriver was ideal for this, as there are now tiny lumps in the cover where I was pushing it).
Putting it back together was the reverse of taking it apart, although you can test whether it's fixed or not before doing up the screws holding the front panel on.
Apr 28, 2010 | Olympus ? Stylus 500 Digital Camera
I switch the camera on. I get 3 beeps and it shuts down.
The problem is of zoom lens motor which operates lens cover along with zoom, and it needs replacement with new part, and camera will start working fine again.
Thanks for using fixya
Jul 26, 2009 | Samsung Digimax S600 Digital Camera
Cover over lens doesn't open properly.
This is a common fault and is caused by dirt/dust/sand particles interfering with closing/opening of the lens cover ( btw before you do anything else try blowing out with compressed air ). Solution :
1) repair yourself route ( if brave and skilled enough) : remove screws and fron cover compltely. Unsolder six thin wires on the left hand side of the circuit board. When front cover is removed blow out sand /dust from the lens cover which is now quite accessible.
2) send to repair outfit route . Note that this is not an expansive repair which does not require installation of spares. So perhaps you should send it in.
Jan 14, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Dec 12, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Olympus Camedia C-350 Digital Camera Logo
73 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
