Question about Kenmore 63252 Microwave Oven
I cleaned the inside of the microwave with soap and water and now it will not heat
  • ldanyus Apr 25, 2009
    Yes, the panel lights up the light comes on when you try to heat someting and the turn table turns. We just don't et any heat at all
  • Steve Allison
    Steve Allison May 11, 2010
    Does the display still come on?
  • Kenmore Master
  • 5,568 Answers
There are normally two different fused circuits; one for the low-power electronics and another for the magnetron circuit which will be much higher amperage rating.
Pull the plug from the wall and allow the unit to sit for at least several hours; there are components inside that can keep a charge capable of giving you a nasty shock. Removing the back panel shouldn't require more than a Phillips screwdriver and once you have access, look for a fuse holder. These can vary in size but should be easy to recognize.
Unless you have a multimeter at home (everyone should- they are cheap and simple <$20 US) you will just have to buy replacement fuses and I recommend you buy two.
If the replacement(s) fail, the problem is too involved to cure without technical skills.
Posted on Apr 25, 2009
EGGS SPLATTERED INTO MICROWAVE EMA301D2PS ELECTROLUX; HOW TO CLEAN IT?
Put a bowl of water with a couple of slices of lemon in it. Put it on low power (no convection) and heat the water up to a simmer. Turn off the microwave and leave the door closed for 10 minutes. Open the door and clean with dish soap and water, or for tough marks something like Comet or Mr Muscle Kitchen cleaner as all the dirt will be soft.
Dec 23, 2015 | In Microwave Ovens
I have a Miele h5080bm microwave oven. How can I clean the grease of the roof and sides of the microwave?
You can put a microwave safe bowl of water in the oven and heat it to boiling, stop the microwave, then leave the bowl of water in the oven for about 10 to 15 minutes. The steam will loosen the dirt and grease and then it can be wiped with a damp sponge. More stubborn grease my need dish soap on the sponge and a little more elbow grease. Rinse it well with a clean sponge or dish cloth and warm water.
Feb 15, 2013 | Microwave Ovens
How do I clean the stainless steel interior of my electrolux icon microwave
Hello - Interior cleaning after convection, mix or broil cooking:
Spatters may occur because of moisture and grease. Wash immediately after use with hot, soapy water. Rinse and polish dry. Harder to remove spatters may occur if oven is not thoroughly cleaned or if there is long time/high temperature cooking. If so, you may wish to purchase an oven cleaner pad with liquid cleaner within it-not a soap filled steel pad-for use on stainlessor porcelain surfaces. Follow manufacturer's directions carefully and be especially cautious not to get any of the liquid cleaner in the perforations on the wall or ceiling or any door surfaces. Rinse thoroughly and polish dry. After cleaning the interior thoroughly, residual grease may be removed from the interior ducts and heater by simply operating the oven on 450 F for 20 minutes without food. Ventilate the room if necessary.
Interior cleaning after microwave cooking:
Cleaning is easy because no heat is generated to the interior surfaces; therefore, there is no baking and setting of spills or spattering. To clean the interior surfaces, wipe with a soft cloth and warm water. DO NOT USE ABRASIVE OR HARSH CLEANERS OR SCOURING PADS. For heavier soil, use baking soda or a mild soap; rinse thoroughly with hot water. NEVER SPRAY OVEN CLEANERS DIRECTLY ONTO ANY PART OF THE CONVECTION MICROWAVE OVEN.
Nov 09, 2012 | Electrolux E30MO65GSS Convection Microwave...
Unable to eliminate odour from previous cooking despite the fact that I wipe the microwave with a soapy cloth & then with a clean cloth each time to Microwave is used
  1. Fill a plastic bowl with 1 qt. of warm water. Add 2 tbsp. of liquid dish soap and 1/4 cup of chlorine bleach to the water. Thoroughly mix the solution.
  2. Dampen a clean cotton rag in the solution. Wipe all inside surfaces of the microwave with the soapy rag to remove food debris and stains. Scrub stubborn residue with a nylon scrub brush.
  3. Moisten another cotton rag with warm water. Wipe the microwave surfaces with the rag to wash away soap and loose food debris. Thoroughly rinse the inside of the microwave.
  4. Dry the microwave's interior surfaces with paper towels. If odors remain in the microwave, fill a microwave-safe bowl with 1 cup of cool water. Add to the water 2 tbsp. of baking soda, half of a chopped lemon (including pulp and rind) and four whole cloves.
  5. Place a microwave-safe plate on the microwave turntable. Set the bowl on the plate.
  6. Heat the microwave on high for three minutes. Operate the microwave according to the manufacturer's directions. Keep the bowl in the microwave for 15 minutes.7
  7. Remove the bowl from the microwave. Wipe the microwave's interior surfaces with clean paper towels to remove steam moisture.
  8. Leave the microwave door open overnight to completely air out any remaining odors.
  • Sep 05, 2012 | LG LTM9000 Microwave Oven
    Sharp 1200w microwave seems to be tripping lightly (can hear clicking noises)and cause heating to be irregular
    Clean the food off the inside top of the microwave Now,Or that noise you are hear will stop along with the microwave. The food gets on the Formica Squire which is how the micro waves heat your food. 1st unplug the Microwave then spray the inside of the unit with something like Fantastic or something strong and use glove so you don't burn you hand,Also if you have a scrub brush use it,And clean all the soap out and raise very well.
    May 02, 2012 | Sharp Microwave Ovens
    What can I do to clean my advantium oven besides soap and water? It just doesn't clean the baked on grease on the inside. Help!
    Eay Off oven spray. Just spray it on and wait about 15 minutes. Then wipe off the grease with a bounty! It's that essy!
    Apr 07, 2011 | GE Advantium 120 Convection/Microwave Oven
    How to clean GE Advantium???
    Get a stainless steel "brillo pad" at the grocery store.
    When you get home ... put a microwave safe container with water inside it ... in the oven. do not heat for more than 2 minutes!!!!! The resultant steam will soften the gunk. Use the stainless steel cleaner pad gently to remove the goop.
    I hope this helps you
    a
    Sep 23, 2009 | GE Advantium 120 Convection/Microwave Oven
    Panasonic nn-s558ba microwave won't power on
    Lee,
    Have Landlord replace unit after verifying that outlet has power.
    In the future, follow manufacturer's cleaning instructions and DO NOT
    run microwave without something in it (even a microwave safe cup of water).
    Larry Hanson EH&S Specialist
    Apr 04, 2009 | Panasonic NN-S558BA/WA Microwave Oven
    Microwave oven not heating thoroughly
    u need to clean the cavity inside the microwave .. step to clean that .. put a cup of water nearly half filled( 30 ml ) and start microwave for five minutes .. after that just open microwave and clean from inside with clean cotton cloth .. this will surely help ..
    Mar 23, 2009 | Kenmore 63683 Stainless Steel 1200 Watts...
    Deep hard core cleaning
    From GEAppliances.com: Microwave - Cleaning Recommendations To minimize the possibility of electric shock, unplug the microwave from the power supply before attempting any maintenance or cleaning. Spills and spatters clean up easily with a damp, soapy paper towel or sponge. It is best to clean soil as soon as it appears. Baking soda and water may also be used. If the food has cooked onto the interior, heat one cup of water on full power for three minutes. The heat and steam help to soften the food. After the three minutes, allow five additional minutes stand time then clean as usual. A non-abrasive scrubbing pad cleaner works well for stubborn stains. You may use mild dish washing liquid or cleaners specifically listed for cleaning interiors of microwave ovens such as MicroBryte® (wx10x3030) or Microwave Oven Magic®. We do not recommend using other detergent based cleaners because they can cause the plastic parts to crack. You may purchase microwave interior cleaner by calling our parts department at 1-800-626-2002, on-line from GE Parts or from your local grocer. For stainless steel interiors of microwave/convection models, we recommend a plastic, soap-filled scouring pad. Rubbing gently with this pad will help remove soil. For the door surfaces (both interior and exterior) We recommend you use only mild, non-abrasive soaps, or detergents applied with a sponge, or soft cloth. For the control panel Wipe with a soft, damp cloth. Dry immediately with a soft cloth. Do not spray any solution directly onto the controls Important: Commercial Oven Cleaners, abrasive cleaners, or cleaners containing ammonia or bleach (can make the plastic brittle) should not be used on any part of the microwave. -- From me - Maybe local restaurants in your area would have some tips? Otherwise, try a Google search for keywords: cleaning stainless steel oven
    Aug 05, 2007 | GE Advantium 120 Convection/Microwave Oven
    Kenmore 63252 Microwave Oven Logo
    Top Kenmore Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
