Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Battery My battery is completely dead and, the light on the charger is not comming on at all when I insert the battery. Do I buy a new charger or new battery? I am doing everything right and the light still does not come on! EEK Help!
  • Jalpita Oct 21, 2007
    It was definitely the charger. I had to buy a new charger and battery, so I now have an extra battery. I am glad the problem is solved. Thanks for posting solutions!
A good way to check and see if your charger is working is to take a voltage meter if you have one and check to see if its putting out the volts it should be.  thats probably the quickest and easiest way to check out the charger and if it shows the proper voltage you can bet its the battery.
Posted on Oct 21, 2007
  • 34 Answers
Most likely the battery.
Posted on Sep 25, 2007
SOURCE:
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
My shaver is not recharging
Most likely, the batteries are dead and need replaced. You need two batteries and they can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-replacement-battery-aa-nimh-p-108.html
For installation videos, see links below
http://www.youtube.com/watch?v=D6jRpCnB8T4
http://www.youtube.com/watch?v=2oAnLpvdYqQ
Jan 07, 2014 | Braun 360° Complete 8985 Electric Shaver
Will not turn on
Thank you for your question.
This camera has no low battery indicator light. It also has a short battery lifespan. You may want to buy a new battery, charge it up and try it.
Here's where you can find the battery:
http://www.thediscountplanet.com/Store/search_results.asp?v_search=powershot&v_type=0&v_supplier=0&page=1&lowest=0&highest=9999999&map=0
If this does not solve the problem, check that your charger is working. If chargers go bad, the user thinks they charged the battery all night and the camera still doesn't work.
Many times, the battery goes completely dead because it hasn't been charged in months. In this case a new battery and charger may be purchased to solve the problem.
Feb 22, 2011 | Canon PowerShot SD1000 Digital Camera
Left key in ignition, maybe on auxiliary notch with radio mute on. 5 days later, won't start, appears to have a dead, and I mean dead battery. Will trickle charger bring it back to life? Options seem to be...
If the battery is completely dead you should buy a new one. Batteries get damaged when they completely discharge. Just put in the new one and start. You might have the emission light go on after a start from a dead battery. Reset it yourself with an OBDII tool or your dealer can reset it. You can drive there at least on your own this way.
Aug 09, 2010 | 2002 Porsche 911
Acer Aspire 5610Z dead battery & malfunctioning power adapter
But before you buy a new battery, You need to again repair the power plug where your adaptor's plug is inserted so that it will not create any problem later. There might be loose connection or sort wiring.. Good luck..
Apr 29, 2010 | Acer Aspire 5610 Notebook
Camera never used and won't turn on, battery fully charged.Ideas? Thanks, Deb
The fe-280 user manual notes hat it is possible to insert the battery "the wrong way round" in either the charger, or camera itself (whereupon its hard to extract).
An extract from the faq about it .....
The camera no longer powers on. What could be wrong?
The battery may be dead or underpowered.
If the battery is completely drained, the camera will not power on when the Power button is pressed. If the battery is nearly drained, the camera may briefly display a Battery Empty error message and then power off, or it may power on and then quickly power off without displaying the error. In either case, charge the battery using the LI-40C battery charger bundled with the camera.
Be sure to properly align the arrow on the bundled battery with the arrow on the bundled battery charger. It is possible to force the battery into the charger so that the arrows are not aligned. This is an improper orientation, and the battery will not be charged. For instructions on how to properly inset the battery into the charger, please see "How do I charge the lithium-ion battery?"
So in a nutshell, the first few steps to check are:
1) Are you sure the battery is charged correctly?
2) Have you inserted it into the camera body correctly?
3) Do you have a spare charged battery to check the camera with? (A photo store will do this for you sometimes, if you ask nicely).
Feb 25, 2010 | Olympus FE-280 Digital Camera
Is the red light on the charger suppose to stay on or blinking for the battery to charge?
It is supposed to stay on. If it is blinking then your battery has gone completely dead. You can force the charger to charge the battery by applying a voltage (AA battery w/ wires worked for me) across the charging terminals while inserting the battery. You'll have to take the charger apart for this.
May 17, 2009 | Vtech Cameras
I have a canon power shot SD1100 IS that is completely dead and i cant find the battery charger anywhere? any suggestions?
You can buy a new battery and charger online at overstock.com I did today for 15 dollars, hope it fixes my problem, and I hope you get your battery!
Dec 21, 2008 | Cameras
Laptop will not charge, the green light on power lead is on but my laptop wont charge it is a acer aspire 5315 with vista
Okay, It can be 1 of 2 problems here:
1. Your laptop battery is completly dead, this can be caused by the overcharging of the battery, You may need to buy a new battery.
2. The battery charger is set at a voltage that can keep the laptop running, but not charge the battery at the same time, try a different charger (universal)
Oct 20, 2008 | Computers & Internet
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
