SOURCE: Audio Amplifier JVC Model A-GX3
If the service manual is not available on the JVC websites then you should just Google search "JVC A-GX3 service manual" There are many websites that archive manuals. You'll probably have to pay for a copy. Why can't you disassemble the unit and see the output transistor numbers first? More importantly how do you know this is the fault?
SOURCE: panasonic surround sound system model # sa-ht95
Error code ' F61 ' on most Panasonic models indicate that the built-in diagnostics has sensed a fault at the output stage. This would normally refer to a failed output amplifier IC (?P/N RSN704D66P?). In some instances, the fault could also be triggered by:
Options then are:
Good luck
SOURCE: I need schematic diagram for
Added a link for the manual with wiring diagram and spec's on pages 61, 62, 63 may be of assistance you here.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/133/133DF802.PDF
Hope it helps, good luck with it.
