Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears garage door keypad/remote programming problem
I need a little help with a Sears garage door opener and it's devices.
For years I had a functioning keypad and remote door opener. A few months ago I added a button in my car and now the keypad doesn't work - but it's more bizarre than that.
If I clear out all the codes from the opener (hold SRT button for about 6 seconds), I can get either the keypad or the remote to work, whichever I do first. But the other one seems to get locked out.
I can get the car button programmed using the remote, but not with the keypad (which I took off the wall to work with).
I've tried all combinations of programming sequences and the one in the manual (hold device button and push SRT button simultaneously) works for the first attempt (after deleting all the codes), but not subsequent attempts.
All the devices seem to work, but not simultaneously. Any help would be appreciated.
Thanks.
Steve I have a Model 139.53615SR Vintage (7/91) and need re-programmng instructions. No manual available from the previous homeowner and don't know the previous keypad code. Can anyone help me?
  • 3 more comments
  • Mr Gas Can Apr 23, 2009
    I have the exact same problem, i can only program one thing in, the car one or the keypad one. I cant find anything on this topic
  • AFowler May 17, 2009
    I too have this problem. It was working fine until I changed the keypad code today. Now, only the keypad works. I can't get the remote to work on this door, but it still works on mydoor that doesn't have akeypad.
  • mez760 May 20, 2009
    I have the same problem I can only get my remote to work on its own, once I try to program the keypad it won't let me. I clear the codes and link the keypad that works but then the remote doesn't, is there a special pattern or order they should be programed I've tried it every which way and nothing seems to work.
  • Anonymous May 23, 2009
    I have the same problem - remotes work, then the keypad does not! I am going in circles. Need help.
    Robert
  • Run Run May 24, 2009
    I program my remotes but then I cannot program my keypad. Is there something I need to do first?
    President:
  • 3,197 Answers
The button you added in your car is an earlier technology that is not compatible with the rolling code technology.
Posted on Jun 01, 2009
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Programing garage door opener
Hold the button on the remote and press and immediately release the smart/learn button. Do this for each of your remotes.
For the keypad press and immediately release the smart/learn button. Walk over to your keypad and key in your 4 digit code and press enter.
If these instructions don't work you have a bad logic board.
Dec 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Model 41a4315-7c wont program remotes but will work with single wall button. has worked for years
That number you are giving is the part number for the logic board and if you cannot program your remotes is the part you will need. It is expensive.
Aug 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote entry code
This multi code device can be programmed. Make sure the battery is good. Linear.com has all the manuals and directions for coding in. make sure and get the model number of the opener and the keypad. Thanks BB
Mar 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remotes won't open garage door, keypad will
If you look were the small wires attach to the opener there should be a red program button and instructions on how to program remotes.
Feb 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hi All,
I had the same issue recently and here's what I found out (through a LOT of research) and the solution (yes, there is one!):
As described by many, when you can't get both the remote and the wireless pad to work together it means your garage door opener can accept both rolling code and billing code technology, BUT not at the same time. When you reset all codes (normally by pressing a button on the opener for a period of time e.g. 6 seconds or more), you erase all codes and remote "pairings". Then when you follow the manufacturer's procedure to pair again (which could be the wireless key pad first OR the remote first), the first pairing determines the technology for all subsequent pairings. Example: if your first pairing/programming was with the wireless keypad, and if it was rolling code technology (normally the case for newer models), then the garage opener will only recognize and accept rolling code for subsequent pairings. If your remote(s) are older (billion code technology) then the opener won't even recognize the signal (e.g. led won't blink when trying to pair/program).
And vice versa if you start with your remote after erasing all programming (then your keyless pad won't work).
But here is a potential workaround! For newer wireless keypads (e.g. clicker from chamberlain), you have an option to select the type of opener you are using as you do the initial password set up (normally indicated by a number e.g. 1 for models built after 1995, 2 for models built between 1997 and 2004, etc). Each choice is associated with a technology in the background (e.g. either rolling code or billion code). If you are programming your wireless keypad first after erasing all codes / programming, if you chose the "recommended" option for garage opener, chances are it will be rolling code and that means you won't be able to program your older remotes (billion code) after that. So how can you chose the option that will match your remote???
Here's what you do: start by pairing / programming your older remote first after erasing all codes / programs. That sets the technology (e.g. billion code). Then, go ahead and program your wireless keypad, but you may have to go through the process several times by trying the different options until you find one that works!
For me, I had to try 4 options before making it work. Options 1 through 3 (mind you, options #2 was the exact match for my garage door opener model but it would cause the problem discussed here e.g. wireless keypad would work but not the remotes) would not even be recognized by the opener in this procedure (LED would not blink), but it did work once I hit option 4.
I hope this will help you with your problem. Let me know if it's not clear. Cheers!
Jun 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,568 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
