Question about Acer Aspire 9500 Notebook
White stripe on acer notebook lcd - Acer Aspire 9500 Notebook
2 Suggested Answers
SOURCE: my acer aspire4310 notebook suddenly displays a white screen
I have an ACER extensa 5630 laptop with the same white screen problem. I found the wiring connecting the LCD and mother board was the problem. Several ground wires from the LCD were wrapped, but not soldered, around another wire from the microphone which then goes to the connector for the motherboard. You will need to remove all the tape wrapped around the wires starting from the motherboard connector to about 3 inches back.
Posted on Oct 24, 2009
White stripe on monitor
I suggest try to isolate the problem of the machine. Try loading to BIOS and see if the white stripe on the monitor exist, If happens that it have the white stripe it means its already a hardware, it could be a problem with the LCD or the cable connector from the LCD to the Motherboard.
May 09, 2011 | Toshiba Satellite P105-S6104 Notebook
My Toshiba P105 has a vertical white stripe on its monitor. Any help is appreciated.
A vertical white stripe means a portion of the lcd has failed...it will continue to get worse as time progresses. The ONLY way to fix it is to swap the lcd out with a working one. It isn't a loose connection, etc.
Mar 18, 2011 | Toshiba Satellite P105-S6104 Notebook
I have 2 whitw stripes about 2inch wide on my
It is probably just a stuck pixel. As long as the stripes are white it can probably be fixed easily. Read the article below and see if it resolves your problem
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Dec 29, 2009 | HP Pavilion dv9000z Notebook
The display on my acer 4330 is not working
Hi friend,
You should check your power...then if display wont come on screen you need to contact computer hardware eng. they repair it...
Dec 20, 2009 | Acer Aspire 3000 Notebook
I'm also experiencing same sort of white screen problem.
To determine if the LCD screen or the video card is faulty, connect an external monitor to the video connector on the laptop. Power up the external monitor first and then the laptop. The video should divert automatically to the external monitor and if you get a normal image then the video card is OK and the fault could be the LCD screen or the video cable. Reseating the video cable and connector on the motherboard could fix yout problem.
Jun 14, 2009 | Acer Aspire 4315 Notebook
White screen problem while starting Acer Notebook 4710
i think this is ur lcd problem ,u need to replace lcd
Jan 20, 2009 | Acer Aspire 3680 Laptop
Acer 5670 screen has dark transparent vertical stripe
you will need to check the display cable and if that is ok, you will need to replace the display panel... You're getting a short on the circuit board causing rows of pixels to be blocked out
Here's your display on ebay...
http://cgi.ebay.com/NEW-ACER-ASPIRE-5670-15-4-WXGA-GLOSSY-LCD-SCREEN_W0QQitemZ320249932106QQihZ011QQcategoryZ31569QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Jun 13, 2008 | Acer Aspire 5670 Notebook
My acer aspire4310 notebook suddenly displays a white screen
If you have blue strip running down vertically from top to bottom then normally there is a problem with LCD or a loose LCD cable.But what I recommend you to test more is tha,t if you tab at the back of your screen ...does this problem occur ???
Incase it does,then its a loose LCD cable problem.You still need
a qualified person who knows how to open the monitor to repair inside.
And again for the White screen it can also be both cases I mentioned above
ByeBye,takecarfe
Apr 22, 2008 | Acer Aspire 5610-4648 Notebook
I had the same problem but I was able to solve this problem. It was a connection problem between the lcd and the motherboard. I have bought contact spray and sprayed a little bit of it on the lcd connector. Since then everything is fine.
Oct 31, 2007 | Acer Aspire 5050-3242 Notebook
Acer Aspire 9500 Notebook Logo
230 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
