Question about Imperial IFS40 Deep Fryer
My imperial IFS-40 is burning the door
The burners lag and then the fire starts to wave forward like it does not have enough pressure to push the flame into the tubes the flame is burning the door of the fryer i have another imperial fryer right beside it and it runs just fine they are in a french fry truck and run on propane.the product is an imperial IFS-40
  • 118leth Apr 25, 2009
    thank you your the second person today to tell me to clean the baffles i will do so and let everyone know how it turned out
  • 640 Answers
Is this fryer propane?It sounds like the baffles in the tank are clogged.If you remove a burner shine a light in the baffle,if you see alot of soot use a shop vac and clean it out.Let me know.
Posted on Apr 24, 2009
Make sure the unit is leaning toward the fron and the back is higher.
Posted on Jun 30, 2009
Deep fryer catching on fire
From the video it appears many things could be wrong. The baffles and burner tubes could be clogged, the burner itself can be clogged, the flue is blocked, or this unit is using the wrong type of gas, ie: propane on a natural gas fryer.
Recommended steps for troubleshooting.
1. Verify proper gas type. Natural or Propane.
2. Check Burners, tubes, and baffles, clean all soot and debris from them.
3. Check for and remove any obstructions from the flue.
Apr 27, 2013 | Kitchen Appliances - Others
Late combustion on ifs 40 deep fryer. How do I fix this?
check if the unit receives standard gas pressure as rated on nameplate.
Mar 14, 2011 | Imperial IFS40 Deep Fryer
Soot build up
Flame is Orange? If so, propane is "choked", not enough air. Remove burners, clean each burner hole with a same size metal dowel (coat hanger works well) flush out inside of burner with garden hose, hi pressure air through all holes to dry. Replace burners ONLY after also cleaning chambers and chimney (garden hose and long brush). Do not forget to clean pilot light area too.
Most Imperials are pre-set air intake. Check gas pressure if able, 3" NG, 10" LPG. Good Luck
May 12, 2010 | Imperial IFS40 Deep Fryer
RED HOT FLUE EXHAUST
Hello. Yes this is normal for this type of fryer, meant more to cook the product, as efficiently as possible, and guzzle gas pretty good. If the orange is near the bottom of the flue, that is pretty good, there is , or should be insulation on the outside of the flue, or if the air gap is large enough, no insulation at all. Not getting near the exhaust pipe is advisable, or you will be burned. The gas pressure is important thought, if the burners are over/under pressured, it will affect the burn enough to damage, and shorten the life of the fry vessel. Call a local authorized servicer and have a check up, will not be free, but will save expense of something not being correct, most places, you pay an hour to check it good enough.
Hope that helped, and thank you.
May 05, 2009 | Imperial IFS40 Deep Fryer
Fryer IFS 40. Burner not getting on.
If the pilot light stays lit then there is no problem with the thermocouple. What you have is a problem with the thermostat or the gas valve operator. try jumping the thermostat wires and see if the gas comes on. If so simply replace the thermostat.
Dec 14, 2008 | Imperial IFS40 Deep Fryer
Imperial deep fryer model: IFS-40
Sounds like the pilot is dirty,if you have propane gas this is your issue,replace the pilot either way.
Aug 22, 2008 | Imperial Kitchen Appliances - Others
Imperial IFS40 Deep Fryer Logo
375 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
