Question about RCA HD52W59 HDTV Projection Television
Does the Comcast remote work in IR and UHF? Infrared and UHF(able to go thru walls or floors.
I installed a Russound remote IR system and coould not get the Comcast Cable box to work. It runs at 56K when other devices run ar 40K and that is what mose IR system do. Russound makes a IR Remodulator 56K kite and now everything works great.
If you are using a different IR system the Russound kit should still work.
Go get'em!
Posted on Nov 03, 2009
    Problem Solver:
  • 16 Answers
Comcast remotes are not both... They only have IR. If you want to go through walls you will either have to purchase an aftermarket universal remote or purchase an IR sensor with an extra long cord and place the sensor on with in view of where you are changing channels, then plug the IR sensor into the back of the cable box... However not all cable boxes have an IR sensor port.
Posted on Jun 24, 2009
  • RCA Master
  • 3,866 Answers
Depends on the converter box but chances are yes its has both communications.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 23, 2009
My receiver remote 40.0 uhf 2g quit working. can I reprogram 6.o ir/uhf pro #132578 to replace it?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Dec 26, 2014 | DISH Network Televison & Video
How to program the UHF remote 153638 to link with the 106240. UHF/IR
you have to go to menu and look for the IR/UHF settings for the remote control and have it change to UHF, so that it would work for both remote!
Jan 24, 2014 | DISH Network IR Remote Control
Recent IR20.0 remote problem developed after 2 years without any issues. The remote no longer communicates to my 722k dvr reciever while my LG Tv is turned on. I have Hdmi run directly from reciever to my...
Hi Robert, my name is Cheri Torres and I work on the Social Media Team at DISH. It sounds like your remote is experiencing IR(Infrared) interference from your LG TV. You can resolve this issue by converting your TV1 remote to UHF(Ultra High Frequency) instead of IR. In order to do this you will need a UHF remote, the 20.0 remote is only an IR remote. Please email me directly at Cheri.Torres@Dish.com with your account number or phone number on the account so that I can look into getting a UHF remote sent out. Thank you.
Cheri Torres
Social Media Representative
DISH L.L.C.
Apr 08, 2012 | DISH Network IR Remote Control
#1 remote in IR Mode, #2 remote in UHF mode, dual HD receiver model 722; #2 remote works perfectly, #1 remote works for a while then stops working. Have to hold the remote within an inch of the IR on the...
bp22911,
It sounds like it may be an interference issue with the IR. Some LCD TV's can cause interference with an IR signal which will cause problems with the remote. Something you can try to fix is disabling the Auto Back-Lighting feature on the TV itself and see if that helps. If not, the easiest way to fix would be to make the TV1 remote UHF.
This would require a 21.0 remote as a 20.0 is IR only. Look on the back of the remote at the top to see what model you have.
With a 21.0 go to System Information. On the back of the remote inside the battery cover is a switch that says IR And UHF and make sure the green 1 is showing. Flip it to UHF and press Record 3 times. The Primary Address should now have UHF in it. Try the remote and see if it works.
If it doesn't or you continue to have problems you can post here or email me at thomas.faust@dishnetwork.com
Tommy Faust
DISH Network
Apr 13, 2011 | DISH Network IR Remote Control
HOW CAN i RESET SAT CODE FOR DIH REMOTE CONTROL FOR DIFFERENT DISH BOX
nmg55
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
http://www.dishnetwork.com/SupportSection/remote-setup
Remotes and receivers models:
222 -
21.0 IR / UHF Pro
222k - 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k - 21.0 IR / UHF Pro
Ray Calo
DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
My remote control only works for tv on & off and volume but not to change dish channel
I experienced this problem as well. I have a dual receiver and had issues turning channels on TV2; but counld easily access the volume. After reading the Dish manual, I learned that my TV1 and TV2 remotes connect through different signals (IR = infrared for TV1; and UHF= ultra-high frequency for TV2).
Check your remote to see if there is a UHF logo at the very bottom (under the Dish Network logo). The UHF remote sends ultra-high frequency radio signals to a UHF antenna which is connected to the back panel of the receiver. Make sure that you receiver is properly dusted and then check to make certain that the UHF antenna located on the back of the receiver is positioned straight-up. When the antenna is not correctly positioned it can cause problems with your remote signals.
Oct 06, 2010 | DISH Network IR Remote Control
DISH Network UHF/IR Remote Control: switch 21.0 remote from uhf to ir...
There is a key in the bottom that has number 2 on it . Turn the key over to number1 and slide the button under the battery cover if needed from a to b or vise versa
May 18, 2010 | Universal Remote Control DISH Network...
I threw my dish remote against the wall and a small white piece of plastic jumped out after falling apart? how do i fix it?
If you have a IR/UHF remote then the littel white peice go to the switch that tells the remote to send UHF or IR signals. This little white peice will fit on the end or the green board at teh very bottom of the remote, it will slide into place allowing the colored tab to move it back and forth to enable and disable UHF and IR frequencies. These remotes are built very tough, i would say you threw it pretty hard lol. You may need a replacment if you continue to have issues.
Dec 06, 2009 | DISH Network IR Remote Control
Why want the remote recognize my directv HR22 remote
Hi. A lot of DirecTV remotes actually use UHF, which is a form of RF. The Harmony remote can only send and capture IR (infrared) commands. Make sure you have your DirecTV device set to receive IR, and if you have an IR remote, or can set your remote to IR, then it will work.
Dec 04, 2009 | Logitech Harmony One LCD Touchscreen...
Dish network UHF remote works intermittently.
If you extend the small antenna that is on the back of the receiver by using a short cable and a barrel connector to get the antenna out of the entertainment center or out from the TV this will help alot
May 30, 2009 | Universal Remote Control DISH Network...
RCA HD52W59 HDTV Projection Television Logo
1,414 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
