Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Phillips Magnavox 60 inch Projection Tv
My Roomates and I just picked up this TV and were warned about some color issues. The problem is that the picture is somewhat foggy and has a reddish tint. We tried playing with the color options but only could make it worse. Is there anything we can do to make the screen normal? Thank you in response to this message.
  • 7 more comments
  • lymabean Nov 30, 2007
    my philips magnavox tv800 has a foggy picture and the colors are slightly amber/sepia toned.. adjusting the color and the red/blue control doesn't help.
  • Dandrake May 18, 2008
    The color has a greenish tint and doesn't change when tint is adjusted to the "red" side.
  • Anonymous Sep 26, 2008
    my 52 inches has red tints and fogg
  • kfarms Oct 07, 2008
    My 60" projection TV is all fuzzy around the edges.
  • ttime889 Oct 11, 2008
    the pictures has a very bad red tint and its foggy and the picture is pulsing
  • vela4constab Jan 24, 2009
    how do you reset auto lock
  • jrjmom Mar 29, 2009
    I have a 52 inch Phillips Magnavox Projection. About 6 months ago it began going dark with red allover the screen and white bluriness and has some blue as well. I don't know what to do, can anyone help?
  • rjvanwieren Apr 20, 2009
    The problem is that the picture is foggy and has a reddish tint. We tried playing with the color options but only could make it worse. Is there anything we can do to make the screen normal? Thank you in response to this message.
  • jameswatkins Apr 21, 2009
    we have had the same problem for 6 months. today the picture looks like it is convex. no straight lines and writting is curved on the screen.
I have a white glow around all the white letters and just all the white colors in general. What do I do ?
Posted on Sep 19, 2008
  • 92 Answers
The foggy tint is contamination in the crt open the back turn on the tv and look into the crts if they like snot is in them the coolent needs to be replaced
Posted on Oct 31, 2007
    New Friend:
    Problem Solver:
Hi my phillips magnavox 60" projection tv has an image problem. When the TV is turned on the picture shrinks and the color becomes hazy. Also the color convergence is also affected. When I turn the tv off and back on again, the picture fills the screen but shrinks again and does nt return to normal. Please help me !
Posted on Sep 08, 2011
  • afreddy Sep 08, 2011
    If your model# is 9p6040c104 then the repair kit will solve the problem. You can order the kit from TVrepairkits.com ( Shrinking and Expanding video or no video kit --cost $53.00 plus shipping. It comes with all the instructions to make the fix easy. Also if your video is cloudly and discolored then you should also purchase the Lens fluid kit--$ 69.00 It also comes with instructions on how to remove the old fluid and replace the new fluid. It is a lot cheaper than having a Tv repairman charge you an arm and a leg to fix the problem you can fix yourself. Just follow the instructions and good luck.
    New Friend:
Foggy picture is caused by lots of dust on top of lenses on the three color projectors which can be cleaned with a soft lint free cloth. Be sure and unplug TV! Take back off and while you're at it vacuum out all the dust around power supply (bottom of TV), might stop the pulsing when you turn TV on. Capacitors can still hold a charge and lenses will be hot so let the TV sit for a few hours before cleaning and vacuuming. Do not try and adjust anything inside of TV that's for a trained technician to do! Don't forget to plug TV back in after you finish cleaning and have everything back together.
Posted on Dec 05, 2010
    New Friend:
I have the same problem. Just ordered the coolant swap kit for about 70$ with shipping at tvrepairkits.com hope this works. I love my TV!
Posted on Nov 17, 2009
I have the same problem all the white looks like god is ascending from heaven on our screen and the picture looks washed out
Posted on Sep 29, 2008
That has got to **** major cohonas
Posted on May 28, 2008
2 Suggested Answers
SOURCE:
Slinteriors
  • 8617 Answers
SOURCE: Phillips Magnavox 60 inch Projection Tv
That model is famous for having bacterial contamination in the CRT coolant causeing halos, and dim pictures with bad overall color issues. You can look into the lens of the CRTs when the set is laying and if the coolant looks cloudy or has any growth there you will notice it right away, and changing the coolant will restore color, clarity and brightness.
Posted on Jun 15, 2008
Model ds31590 screen has a reddish purple tint whether it s on tv or video i have already tried to change all picture settings and set back to factory settings still has same problem,here is an example...
Chances are real good that your picture is showing its age. There are three color beams in the neck of the picture tube. When these electrodes are operating correctly the will produce an arc, that will produce the proper voltage for color correction. Much like the spark plugs in your car. When you have a fouled spark plug, you replace it. In the case of a TV, replacing the tube is the best way to correct the picture you are looking for. It would be to costly to do this of course. Another option is to rejuvenate the picture tube. Once again, rejuvenating the picture is last resort. Customers must be warned that rejuvenating may work or even in some cases destroy the picture tube. I want to remind you as well, the symptoms you describe will over work the main board as well. This TV is not feasible for repair. Thanks for asking and show a few hands of support!
Mar 26, 2011 | Sanyo DS31590 31" TV
The color is all red.
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Jan 01, 2010 | Hitachi 51F500 51" Rear Projection...
Hitachi RP CRT Gone Red On All Inputs!!!
SD TECH
Dec 23, 2009 | Hitachi 57F710 TV
Foggy picture
not worth it, likely been dropped and all the lenses etc are out, or just worn out from a hard life.
Oct 12, 2009 | Philips 9P5034C 50" Rear Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
DARK AND COLOR RED
It is more than likely a convergence issue rather than a color issue.
Jul 19, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Tv turns on with sound but no picture
Check the lamp, that can cuase that condition. If the lamp's glass looks foggy somewhat or it might be broken inside that will be the problem.
Rustym62
http://www.the-tv-dude.blogspot.com
May 03, 2009 | Televison & Video
Foggy Picture
dear friend your picture tube has a crack in it! probably in the back of it at the neck, or at the picture tube socket pins. it maybe leaking vaccum and taking on some air! have a local tv shop check the picture tube on a tester!
Mar 24, 2009 | Hitachi SSF420TR 20 in. TV/VCR/DVD Combo
Jun 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
10,404 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
