Question about Belkin F8T061 Consumer Headset
F8t060xhdst conectivety to PC issuse
I am trying to get my headset to work with msn messenger under vista. I have got the bluetooth connection, however I can get it to workI also have a Belkin FST060 and it is connected to my Windows XP SP3 through a Belkin USB, however it doesn't see any services. Not sure how to fix this. I want to use it with Skype on my system.
  • 11,896 Answers
1) Buy a Bluetooth version 1.1 or version 1.2 dongle with Class 1 reach ("up to 100 meters"). The brand of the dongle is not important (as long as it is not Sony Vaio!), but it is very important to check the specs of the dongle to make sure it supports "headset" services. You should go for Bluetooth version 1.2 if possible, as it has better headset support and is less susceptible to WLAN interference.
My dongle uses the Widcomm drivers and as far as I know, all Widcom drivers from version 1.4.2.10 and up support headsets. Alternative drivers are from BlueSoleil, but I don't know much about them (search the Forum for tips on BlueSoleil!).
2) Download latest drivers for the dongle from the producers' website (if avaliable).
3) Make an XP back-up point (just to be sure).
4) Install the dongle using the latest drivers for your dongle according to the manual and then reboot. In most cases, Bluetooth is NOT working correctly now - the Widcomm Bluetooth "B" icon in the system tray (lower right of your screen) is red. You might also see a white and light blue "B" icon, but that is the Microsoft Bluetooth (bad!).
F8t060xhdst conectivety to PC issuse - non_ms_bt.gif This is how your Bluetooth icon should look when you have completed the steps below - compare with the MS Bluetooth icon:
ms_bt.gif This is the Microsoft Bluetooth icon - follow the steps below to disablF8t060xhdst conectivety to PC issuse - non_ms_bt_red.gifc="http://i.fixya.net/uploads/images/non_ms_bt_red.gif" alt="non_ms_bt_red.gif" class="h_mi" /> The Widcomm Bluetooth icon is red when the Widcomm driver needs a manual update (follow the steps below).
Added note September 2005: Many Bluetooth dongle producers are now aware of the troubles with Microsoft drivers and have added functions in the drivers that do automatically disable the MS BT drivers, so you might be lucky that everything works fine (white non-MS BT icon) right after installing the drivers. If not continue to the next step!
5) Go through "Start" > "Settings" > "Control Panel" > "System" > "Hardware" > "Device manager" and then expand "Bluetooth devices". You will most probably see two different Bluetooth drivers - one from Microsoft and a "Generic" or "CSR" (or other) driver.
6) Disable the Microsoft driver - DO NOT remove! This is the problem with XP SP2 - Microsoft Bluetooth drivers will allways be installed and will override Widcomm drivers, but they have no support for headsets! If you remove the driver, it will reinstall again if/when the dongle is reconnected, so do only disable. Hopefully one day soon MS drivers will support and work with headsets and the Bluetooth headsets will finally just be "plug and play"...
An ALTERNATIVE step 6 (more complicated but technically better) is posted by Kevoh92 in this thread: http://forum.skype.com/viewtopic.php?t=14646[/i]
7) Right-click on the "non-MS" Bluetooth driver and choose "Update driver...". Click along in order to get to where you can manually select the driver for your dongle (the "Have disk..." option). Point to the file called "btwusb.inf" on CD or in downladed driver files and update with this driver. Reboot only if necessary. Bluetooth "B" icon in your system tray should be white now - if that is the case, then non-MS Bluetoth is now woF8t060xhdst conectivety to PC issuse - non_ms_bt.gif PC and you're half-way through!
non_ms_bt.gif This is how your Bluetooth icon should look - now you're ready to play! :wink:
Note: The Microsoft Bluetooth icon will always remain visible in the control panel (root directory), but that is no problem!
8 ) Activate Bluetooth on your PC and pair with your headset according to the manual (quite simple but it takes a few steps). Experience shows that it is a good idea not to activate the "audio gateway" profile, but only the "headset" profile. If you know that you need other profiles for e.g. file sharing over BT or other stuff, then do activate those profiles, but keeping it to a minimum will surely minimize the risk of setup errors!
9) Close Skype completely, restart Skype and then choose "Bluetooth Audio" as sound input and output in Skype.
10) Connect your headset from the PC (Right-click on BT icon on the lower right of the screen, choose "Fast connection" > "Headset" and then choose your headset). Receive the incoming call on the headset itself (press "accept call" button when you hear a repeating sound in the headset). If the Bluetooth "B" in the system tray goes green, you're nearly there! Your headset is now in "call" mode so it does consume battery at the highest rate (my Logitech still has power for 6 hours in this state). All audio on your PC now goes through the headset.
11) Make a test call to Skype profile "echo123" and do a test recording.
12) If your hear audio and your own recorded testcall, you're done!
Posted on Apr 23, 2009
  • Nate Stansfield
    Nate Stansfield Apr 23, 2009
    MAKE SURE YOU HAVE THE LATEST DRIVERS INSTALLED than:
    Pair your headset with your computer.
    This depends on both the bluetooth driver and the headset. On your
    computer, if you right click on the bluetooth icon in the system
    tray, you should have an option like 'Add device' or 'Bluetooth
    Configuration Wizard.' It will probably give you the option to choose
    the device you want to use or choose the service you want to use. You
    should be prompted to have your computer search for the new device. At
    that point put your headset into pairing mode--you'll have to check
    your manual or online for how to do this, it's generally holding down
    some combination of buttons to make the light change color / flash
    differently. When the computer recognizes the headset in pairing mode,
    it may ask you to type in a passkey. This is a four digit number and
    again, you may have to check your manual--it'll be the same as it was
    to pair the headset with your phone, and is generally 0000 or 1234.
    3. Make the headset your Skype audio device.
    Once you're paired, the white bluetooth logo in the system tray will
    change color to green. The bluetooth headset should then be one of the
    devices you can choose in the Sound and Audio devices in Control Panel
    and in Skype. in the skype client select Tools -> Options ->
    Sound Devices, and choose the “Bluetooth Audio” for both audio in and
    audio out.
    4. Skype away.
    Before you make any calls you might want to call the Skype Testing
    Service (echo123) to confirm your audio is working properly, and adjust
    your volumes if necessary (you'll be able to control the volume within
    the Skype client and probably on your headset as well).
    These are meant to be general instructions--you can see other peoples' attempts here and here.
    When you’re doing this, keep in mind that when you're paired and the
    bluetooth icon is green, your bluetooth headset will be drawing power
    like you're talking whether you're talking or not. You can unpair it
    manually when you're not talking, but if you receive a call you won’t
    have much time to pair it back before answering. The .audio 910
    headset’s software recognizes when Skype calls start and stop and
    appropriately puts the headset in standby mode, thereby conserving
    battery life. But if you don’t want to shell out for a new headset when
    you have a perfectly good one, teaching it to work with Skype is a cool
    new trick.
Can't pair Samsung C3053 with Motorola bluetooth. I have followed the directions to use the Bluetooth messenger (whatever that is) and have gone to (in order) Menu, Settings, Messages, Bluetooth...
any one of the cell might have newer ver of bluetooth whicdh other 1 cannot recongonise.... try some other bluetooth headsets of own brand
Apr 10, 2010 | Cell Phones
Bluetooth
When you connect a headset (after pairing you double-click the headset's icon and click the headset service) you will hear a beep on the headset itself. When you "answer" this by clicking the appropriate button then the connection is finally established - only then the sound is routed through Bluetooth.
It seems you are doing this already. But the problem is that this only affects programs that start using sound after the connection is established, or programs that don't keep the sound channel open. I am not sure that MSN does it. You could exit MSN, connect the headset (confirm the sounds are coming through it by using Windows Media Player for example), then start MSN again and see if it makes a difference.
Aug 12, 2008 | Pioneer AVIC-F900BT Car GPS Receiver
The handset is unable to receive calls via Skype,nor am I able to make calls via Skype Handset says Disconnected
If you use windows vista, and installed windows live messenger, you wil have alway`s this problem, solution is, dont let msn start up with your pc.
The best way, under software remove msn messenger, and install again en dont let it start wen your pc start up. skype and msn dont working together.
i hope your problem is solved
Feb 08, 2010 | Logitech Cordless Internet Handset Phone
I could not install driver in vista
It is suppose to be plug and play. Vista advantage is you need not install drivers for most if not all external hardwares.
Try letting the system locate the phone itself.
Rate this please.
Apr 06, 2009 | Motorola Mobility PC850 Bluetooth Wireless...
Can't use VPC-CG9 as PC camera.
I don't know why this wouldn't work on Vista HP, but this excerpt from the manual suggests that your XP SP1 Pro would not work without the SP2 rollup:
"Please perform the following upgrades before connecting the camera to a computer.
-Upgrade Windows XP to SP2.
Install Windows XP SP2.
-Install Windows Messenger 5.0 or later version.
Download Windows Messenger 5.0 or later version, and install it.
-If using MSN Messenger, please install MSN Messenger 7.0 or later
version."
Perhaps if you are following the steps exactly in the manual and it still does not work, upgrading Messenger will magically help.
Mar 24, 2009 | Sanyo Xacti VPC-CG9 Digital Camera
I cant download hotmail messenger or msn. and i want to see automatically the msn messenger at my pc
What error message are you getting that is not letting you DL MSN Messenger? Try this link below! It should work. Under Windows Live Messenger messenger.png , right click on download, and open in a new window, and proceed with the install steps....
Feb 23, 2009 | Microsoft MSN Messenger Connect Service
My logitech webcam chat has no sond!!!!!!!!!! before when i recorded videos i had sound played when i recorded, and my mic works i tried it on another program and it works.
The information in this article applies to the following 3rd party software
MSN Messenger 6.x
MSN Messenger 7.x
Window Live Messenger 8.5
The information in this article applies the following platforms
Windows 98
Windows ME
Windows 2000
Windows XP
Windows Vista
Note: The information in this article is not product specific. For details regarding camera driver and operating system support please see article 3428
Step 1: Getting Started
Before we begin setting up the sound in MSN or Windows Live Messenger, ensure the following is complete:
  • Connect your camera and verify that it is working properly
  • If using headphones, verify that your device is connected and functioning
  • If using speakers, verify that they are functioning properly
  • If using a headset, verify that both the headphone and microphone are connected and working properly.
Step 2: Executing the audio and video setup procedure within the messenger application
This procedure will allow you to assign an audio input and audio output device, as well as assigning the video device of your choice to work with the messenger application. The following example uses Windows Live Messenger 8.5 however, the same procedure can be used for earlier versions of MSN Messenger 6.x and above. MSN Messenger users please skip directly to step 4 below.
Note to Windows Live Messenger users: There are multiple ways to execute the following steps depending on being signed in vs signed out of the messenger application, and which version of Windows Live Messenger is being used. To avoid confusion, please execute the following steps while signed out. We also recommend updating to the latest version of Windows Live Messenger.
1. Sign out of your account.
2. Launch the messenger application (make sure you are not signed in to your account).
3. Locate and click the "Help" drop down button towards the top right corner and select "Show the menu bar"
16480.gif 4. Now click the "Tools" option in the menu bar and select the “Audio and Video Setup” option.
5. Click “Next to begin the setup process.
6. In the “Speaker Setup” window, select the output device you would like to use with the messenger application. This step is specific to speakers or headphones. If your speakers or headphones are USB devices and connected to your computer, select the device by using the drop down menu provided. If your speakers or headphones are connected to your soundcard, the device listed will be the make or model of your soundcard device.
You can also set the desired volume level and click “Play Sound” for an audio sample. Click "Next" once you are comfortable with the your selected options.
7. In the “Microphone Setup” window, select your desired input device from the drop down menu provided.
3172_msnad04.jpg This selection will be specific to a microphone connected to your computer. If your Logitech video camera has a built-in microphone, this option will be presented as “Logitech Mic” with your camera model name in parentheses as shown above.
If you have an external USB microphone or headset device connected to your computer that hosts a microphone, select the devices name or model number in the drop down menu. If your external microphone or headset is connected to your soundcard, the device listed will be the make or model of your soundcard device. Once your device is selected, adjust the microphone volume level to your preference and click next.
Note: The microphone volume level may need to be tested in order to find a comfortable volume level. As a starting point, try setting the level midway and adjust when necessary by re-executing this procedure.
8. In the “Webcam Setup” window, select the video device you would like to use with messenger application. Once selected, you should see a display sample in the window provided. You can also click the “Options” button to make camera specific adjustments. Once completed, click the “Finish” button to apply your changes.
Once you have completed this process, the messenger application should now be configured to the correct audio input (microphone), audio output (speakers or headphones), and video device (webcam) to use when engaging in an audio and or video conversation.
his article covers how to configure a Logitech camera's audio and video settings to work with Skype 3.6 or above. trnsp.gif Answer This article applies to the following cameras:
All Logitech USB Webcams
This article applies to the following platforms:
Windows Vista
Windows XP
This article applies to the following 3rd party application:
Skype™ 3.6 or above
To set up Skype for video please be sure that your Logitech webcam is connected and working. This can be verifed by launching your QuickCam software and checking for a video stream withinin the QuickCapture video window. Once the webcam functionality is verified, please close the QuickCam application and follow the steps below.
  1. Launch Skype™ and click on "Tools" as shown in the figure below
    Fig 1
  2. When you click on "Tools" you will see a drop down list
    Fig 2
  3. Click on "Options" at the bottom of the drop-down list
    Fig 3
  4. A new screen appears. Click on the left side of the pane under "Video Settings"
    Fig 4
  5. Under the "Select webcam" drop down, please choose your Logitech camera, then click the "Save" button.
    Fig 5
  6. Click on "Tools" as shown in Fig 6 to get your Logitech Audio setup.
    Fig 6
  7. When you click on "Tools" you will see a drop down list
    Fig 7
  8. At the very bottom of the drop down list, please click on "Options"
    Fig 8
  9. When you click on "Options" you will see a new screen
    Fig 9
  10. On this new screen click on the left side of the pane under "Audio Settings"
    Fig 10
  11. You will now have the option to select your Logitech camera's Microphone as your main Audio source. Under the "Microphone" drop down, select the Logitech Microphone, and click "Save"
    Fig 11
  12. You should now be ready to use your Logitech webcam and microphone in a Skype video call.
Aug 11, 2008 | Logitech Quickcam Chat Webcam
H350 bluetooth headset can't connect to laptop any solution connect to a motorola bluetooth headset how do I get my Motorola H350 bluetooth earpiece to work with my laptop?
Do you have the Jabra bluetooth part that goes into your computer? You have to go to your phone settings under bluetooth and make it sync up. Your phone will sync, not your headset. You are trying to sync the wrong thing.
May 04, 2008 | HP Pavilion dv6000z Notebook
Logitec web cam
You will be required to run an audio setup wizard through the messenger application in order for MSN or Windows Live Messenger to recognize sound using a microphone and produce sound through speakers, headphones, or headsets.
The information in this article will describe the correct procedure to setup audio and video within the MSN or Windows Live Messenger application to achieve proper audio functionality.
trnsp.gif Answer The information in this article applies to the following 3rd party software
MSN Messenger 6.x
MSN Messenger 7.x
Windows 98
Windows ME
Windows 2000
Windows XP
Windows Vista
Jan 24, 2008 | Logitech Webcam
Logitech Cordless Internet Hnadset Phone on VISTA! for SKYPE
Handset shows DISCONNECTED.
On Logitech support page lookup document 6674 (search).
Boot computer with minimum og services and programs running.
Start Logitech handset program - this starts skype.
the handset will disconnect.
As soon I start the new LIVE MESSENGER BETA - the hanset disconnect.
Therefor I installed a msn messenger extension in Skype extras.
This gives me the opertunity to use msn messenger without using the LIVE MESSENGER PROGRAM - if I do - Logitech Handset will not work.
Sep 06, 2007 | Logitech Cordless Internet Handset Phone
Belkin F8T061 Consumer Headset Logo
271 people viewed this question
Top Belkin Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Belkin Radio Communication Expert? Answer questions, earn points and help others
