Question about Necchi 4575 Mechanical Sewing Machine
Spool of thread doesn't fit spool pin
I've had this machine a few years but have just tried to use it. My Singer needs repair. Anyway the spools of thread that I have do not fit all way on the pin. The pin is flared at the bottom. The owner's manual doesn't mention anything unique regarding the spool pin or thread to be used. I tied to get an explanation at a fabric store but they don't believe it. Hopefully this is something simple. I believe I'm threading the machine properly. Since the spool doesn't go to the base of the pin, the thread breaks after a few stitches.
  • 1388 Answers
SOURCE: I am hemming blue jeans. The top stitch looks
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really .....actually .....need adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do is,
and eventually, you do get a "feel" for the correct tension and then it happens quite a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Best Wishes
Bargain Box in Australia
Posted on Oct 04, 2009
  • 1116 Answers
SOURCE: my daughter said it locked up after reverse stitch
The race is not in place or the needle may be bent.
Posted on Feb 22, 2010
SOURCE: The bobbin thread breaks
if upper thread is breaking
1. needle in backward
2.upper tension to tight-check manual for proper setting
3.needle maybe bent-try rolling needle on flat surface to see if it's bent & if so replace
4.thread may hang on bobbin case-check area for lent or fragments of old threads
5. knotty or cheap thread-always use good quality thread
if lower thread is breaking
1.the most probable cause of lower thread breaking is an inproperly wound bobbin
2.bent bobbin
3.lint built up in case
4. thread catching on a spring or latch
Posted on Jul 29, 2010
  • 16 Answers
SOURCE: why does the shuttle hook grab the spool thread
The shuttle hook is suppose to hook the needle (spool) thread and loops it around the bobbin case to form the lock stitch. Is it possible that something was adjusted without proper clearances as to allow the thread looping around the bobbin case to do so without catching up where it should pass through freely?
Posted on Nov 13, 2010
  • 2510 Answers
SOURCE: I have two problems the
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Posted on Feb 24, 2011
Looking for a cotton thread spool pin for a vintage singer treadle sewing machine number 15-30
Jan 07, 2018 | Singer Sewing Machines
Can't figure out how to fill the bobbin
hi Beverly.
you have not said what make and model.
but try this.
Always wind the bobbin before threading the machine and needle.
  1. Place spool of thread on spool pin.
  2. Slide spool pin holder/cap firmly over rim of spool to prevent thread from tangling.
  3. Push bobbin winder pin to far left if it is not already there.
More items...
Winding a Bobbin ' Singer Sewing
or try this.
How to fill bobbin for sewing machine
How do you fill a bobbin on a Brother sewing machine? Use only the included bobbin or bobbins of the same type (part code: SA156, SFB (XA5539-151)).
  1. Turn on the sewing machine, and open the top cover.
  2. Place the bobbin on the bobbin winder shaft so that the spring on the shaft fits into the. ...
  3. Remove the spool cap that is inserted onto the spool pin.
More items...
How do I wind the bobbin? ' Brother Search for: How do you fill a bobbin on a Brother sewing machine?
or you could go and look at this link to see if it helps you out some more.
igniter button for SUNJOY PH018PSS Google Search
Nov 21, 2017 | Sewing Machines
How to remove broken horizontal spool pin of Singer Sewing machine model 6550 and replace with new spool pin?
It appears to be just "hooked" on according to the photo, and you can get the replacement part for $4.00 using this link:
However, before you go to all that trouble, you can also just use the auxiliary spool pin used for twin needle sewing which came with your machine but can be purchased from the same site for about the same price.
I don't use either -- I just put the spool in a cup behind the machine and thread from there. See? One way or another, you're back in business!
Jul 06, 2017 | Singer Sewing Machines
I have a singer featherweight 11 117 model and the spool pin snapped. Where can I get a replacement?
First of all, it's likely at this point that you think your machine is unusable without it, but you're wrong. I have four Singer high-end sewing and embroidery machines, and it has been years since I used their spool pins.
Simply put a coffee cup or--my favorite--a lidless pint Mason Jar at the back of your sewing machine towards the right (away from the fabric side), bend the thread (don't wind the thread) around the remains of the spool pin to use it as a thread guide, and then thread the way you usually do, and you are in business!
Now, to address the replacement issue, there are several places where you can order a new one. Do a search on eBay for "Singer Featherweight Spool Pin" and a number of listings will come up. Don't put in your model number in the search box. If you see that a dealer is featuring one for a Featherweight, but not for your model, don't hesitate to use the "Ask a Question" option in a listing; these are generally quite knowledgeable dealers who can order one for you. Also Jenny's Sewing Studio and Sewing Parts Online either have them in stock or can order them for you. It appears that they are quite inexpensive too!
Aug 04, 2014 | Singer Featherweight II 117
Singer sewingmachine how to stop thread from breaking on the top
Thread breakage is often caused by a burr on the needle. Whenever i have a problem with thread breakage, I unthread the machine, replace the needle, and rethread.
Sometimes thread will wrap around the spool pin, so I use the upright spool pin or use a mug or water glass to hold the spool upright behind the machine.
Jul 19, 2014 | Singer Sewing Machines
Replacement parts
You will need a parts list, and unfortunately, the Singer site doesn't list one. However, I would point out that there are two machines complete on eBay right now for $20.00.
However, there IS an alternative. Many experienced sewers don't use the spool pin anyway--we put the thread in a cup in the back of the machine and feed it in from there.
Jul 02, 2014 | Singer Tiny Tailor TT700
Sewing machine design
It sounds like the spool cap is broken or defective. It should fit snugly on the spool pin. If it is constantly falling off, then try finding a replacement. The horizontal spool pin design helps the machine pull the thread off the spool because the thread spool does not need to spin. The added pressure of spinning a thread spool contributes to tension issues (especially if you are using large thread spools that are so common now days).
On new machines, frequently the thread cutter is on the back of the presser foot lifter.
The thread guide above the needle is usually threaded from the left side because the thread tends to be pulled toward the right.
Unfortunately, what you are experiencing are pretty much common functions with most newer sewing machines, so even changing machines may not result in any greater degree of satisfaction.
Mar 31, 2017 | Singer Sewing Machines
I cannot get the tension to set correctly on my Singer 6268 sewing machine. For instance, I'm using red thread on top spool and white in the bobbin. Suddenly, as it always does, the thread is loos
I have solved my tension problems by going to they have solutions to many, many problems you have with your sewing machine. Hope this helps. jdokos95
Aug 01, 2012 | Sewing Machines
How to thread twin needle on singer
Look in your attachments for the secondary spool pin. Then you'll thread both upper threads as normal.
Jul 30, 2012 | Singer Sewing Machines
My Activa 130 makes a clacking sound when I sew. It is 10 years old. What do you think is wrong? Can I repair this or do I need to take it to be serviced?
I would take it to a Bernina repairman, nice machine and well worth getting it serviced by a qualified technician.
I presume that you've tried the obvious things like a new needle and checking the bobbin case is in correctly.
Sep 03, 2011 | Bernina Activa 130
Necchi 4575 Mechanical Sewing Machine Logo
29 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
