Question about Sony DSR-1800 DV/Mini DV VCR
Sony DSR-1800 Lost Lock
When playing either a MiniDV or DVCAM tape for about five to eight minutes, servo lock is lost, the servo light goes off, and the green channel condition light goes off. Playback servo lock can be restored for a few minutes if the DSR-1800 power is shut off for two to three minutes, and then turned on again. Using a Sony head cleaning tape does not solve the problem.
  • 53 Answers
Ths is the problem with the Tension or tape part .u need to do and adjustment on tension
Posted on Jan 14, 2009
    Champion:
  • 221 Answers
Check the condition of the pinch roller. a bad pinch roller can cause this problem - a tape plays for several minutes, then has problems. what happens is the tape slowly moves up or down on the roller instead of traveling in a straight path. this is caused by the roller becoming worn or glazed and not being able to provide traction to pull the tape through.
Posted on Sep 25, 2007
SOURCE:
Error 91-455 show in sony dsr-1800p dvcam get a service manualfor this model. pleas.
Error 91:455 i means: Communication error between servo main and servo sub microprocessors.Dose it take the tape in?if can tell me more.mail me in [email protected]
Nov 26, 2010 | Sony DSR-1800 DV/Mini DV VCR
Sony 570 dvcam error message 91-143 can you help
Microcomputer and its periphery device error
1: CASSETTE IN
4: Capstan motor/capstan FG
2: Detected speed error
It looks like a bad capstan motor.
Dec 15, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
DSR-11 will not record in DV SP mode.
dear, u need to change the memory cell of ur dsr-11 ,
Jul 29, 2009 | Sony DSR-11 DV / Mini DV VCR
While playing a tape, there is no sound, and video on the left 20% of the screen freezes with varying amounts of video that appears in small slowly changing rectangles from earlier frames. Video on the...
Two possibilities, either player needs tape path adjustment or requires drum (video head) replacement.
Above said solution requires expertise and Sony trained tech will do this job with proper tools.
Thanks.
Jul 08, 2009 | Sony DSR-1800 DV/Mini DV VCR
DSR 1800 Video freezes on left side of screen and no sound.
left side image freeze indicates that the tape supply guide needs adjustment. best done by a technician with proper test equipment.
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
Apr 10, 2009 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-1800
these errors mean the folowing:
02-291: failed to complete winding a tape.
02-275: detected T reel FG during threading.
02-696: Detected abnormal detectiion of S and T reel rotation during play and Rec.
The second and third faults indicate a fault with the board containing the driver for the reel motors. Unless you have the service manual i suggest you buy and replace the board.
It is the DR-428 board.
good luck
Luwangula
Apr 08, 2009 | Sony DSR-1800 DV/Mini DV VCR
DSR-1800 Lost Lock
This error 07.042 means Detected the abnormal capstan speed.here what u have to do go to maintanence menu.and check the capstan speed
Sep 28, 2007 | Sony DSR-1800 DV/Mini DV VCR
Sony DSR-1800 DV/Mini DV VCR Logo
187 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
