Question about Kenmore 62109 Microwave Oven
My microwave want heat up it has been getting moisture all in it when it was cooking clock works turntable works light works it does not heat up it smells like it is a defect
  • 3,037 Answers
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
Went pop 20 seconds into cooking clock still works turntable stills moves won't heat
Remove the cover and look for a blown fuse. If found, replace the high voltage diode and the 'stirrer' (a fan like device that is inside the sheet metal wave guide near the area where the microwave energy enters the cooking cavity).
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Microwave will not heat
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Microwave Ovens
GE Microwave won't heat or cook - one year old
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
GE Spacemaker JVM1533WD turntable sometimes works, mostly doesn't
The part with the three rollers that holds your turntable needs to be replaced if you want it to turn. That plastic and those rollers get cooked over time like everything else. The microwave is designed to basically cook with the moisture in anything placed inside the microwave. Those rollers have probably become warped enough so they don't roll properly when heated and that is why they do work somewhat after a night of nonuse. You may be able to find one at a local repair shop for almost nothing. Those parts are pretty generic. Even at a garage sale or flea market. Other than buying from a local dealer you can go on the internet at www.mwoparts.com and get any part for the microwave. Good luck and God bless you.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Buzzing, Still Heats, but Turntable And Fan Not Working
This is not safe. If the fan is not running, the magnetron will quickly overheat and be destroyed. We answered this in more depth in the other place you asked it.
Feb 24, 2007 | GE JVM1441 Microwave Oven
Kenmore 62109 Microwave Oven Logo
57 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
