White screen of death
When i start my computer it works fine but then i got a white screen how can i fix this?
  • 3,866 Answers
Video card issues, replace video card and restart.
Posted on Apr 23, 2009
My HP DV5 1159se was working fine last night and then this morning I go to turn it on as usual and a blank white screen comes up. The start tones are the same and I could even type my password in to log on...
If the inverter board or the back light behind the screen were bad your display would be blank, "but windows would be visible barely" the white screen indicates a bad LCD and must be changed. It is also possible the video cable from the motherboard to the screen has come loose and will need to be reseated back into place to fix it.
Mar 23, 2011 | HP Pavilion dv5-1159se Laptop
My samsung 19 widescreen got white screen after 2 years can I fix this some how? / Johan
Hi! using analog it seems to work for now but sometimes it blinkes white on the screen,it seems to work better when I have had the screen on, for some hours then it seems to work fine.. But I dont know for how long..
samsung 19 wide.
/ Johan
Oct 21, 2009 | Samsung T190 19" Widescreen LCD Monitor
New computer won't start up stuck in auto adjustment mode
You can ask the computer tech what he did to fix you computer and post that info here.
Or, check out this tutorial on starting in Safe Mode to find and fix problems.
May 02, 2009 | Computers & Internet
My computer is stuck on the startup screen
Does it have the options for starting in safe mode, but no matter what, it reboots?
If so, use a winxp cd ( asuming you have winxp installed) and boot from cd like your going to install windows. When it loads it should have an option screen thats blue with white text.
Select R for repair. it will close and go to the command prompt. Then type in ( chkdsk C: /P ) exactly.
Let it run the repair and when done, type: Exit or just reboot, remove disk and let it boot normally. when that screen comes up with white text saying to select boot option, just pick, Start windows normally.
It should then work fine and go into windows.
If this fixes it, then some how your boot files got erased and the repair fixed them. This happens alot with Dell computers. Its random and usually happens after installing something. So remember how to do this in case it happens again,
Good Luck
Dec 01, 2008 | Computers & Internet
White screen.
If you are using a usb hub, connect the lifecam directly to one of the usb ports on your computer.
Apr 19, 2017 | Microsoft LifeCam VX-6000 (68C-00001)...
Motorola RAZR V3x Whiye screen problem
I have managed to fix the problem by doing a software update.
I stumbled across the solution..........I had the phone connected to the computer when I started it in the 'boot loader' screen as opposed to just turning it on. This time the computer recognised the phone was connected and through the motorola software update program I was able to update the software and the phone now works fine.
BTW I did lose all my address book, messages etc.
To start in the boot loader screen hold down the * + # + pwr keys all at once.
Jul 29, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Screen becoming blue and flickering white
I fixed this same problem using a registry scanner. Here's a link to a good free one:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hope this helps.
Jul 17, 2008 | HP Pavilion TX1000Z Notebook PC
Proview PL926Wbi LCD Monitor White Screen
I found in the refuse, a Gateway FPD 1520, 15" LCD monitor that started off losing the screen half-way, losing sync, etc. The "mechanical agitation" method was applied and remedied the problem. Awhile ago, it went to a white screen (or, as it was back in the day- a clean raster). I opened it up and found that the ribbon cable on the left was loose. I applied a series of layers of adhesive-backed foam (the kind you stop drafts in your home with) until it was greater than the height of the metal enclosure to put pressure on the unbehaving connector. It does seem a bit loose and this will keep it snug. Maybe hot glue or other adhesive if it wiggles loose again. Seems to have solved the problem at the moment.
Oct 15, 2007 | Proview PL926WBi 19" LCD Monitor
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
