Magnum S9 Base CB Radio
Problem for Magnum S9 Base CB Radio
Red ant light
By ghartle on Sep 24, 2007
I recently bought a new cobra 29 nw ltd classic. Calibrated fine, swr is good, red ant light comes on when I key the mike. Receives good, transmits good. I drive a Kenworth T2000, company installed new ants, is it a possible wiring problem in the cab, what will happen if i operate it with the red light coming on? Thanx
Clarification Request
Posted by jrt1977 on Mar 24, 2009
The 18' coax has been proven incorrect and not true. To achieve near perfect SWR calibration, a 9' cable can also be used achieving the same results as the 18' coax, because of 9 being half of 18. Unfortunately its a very long explanation, but with the knowledge that you both seem to have you can understand the varibles involved and can see why the logic makes sense. If not please do a search on the web and then try it yourself like I did, and its correct. 9' yeilds the same result as 18'.
Same Problem
Jan 07, 2009
-   my antenna light is lighting. i have a mirror mount mounted to my toolbox on my 91 nissan d21 hard body. but at the same time my coax is brand new and not pinched nor does it have a bare spot in the cable at all. it is also connected tightly on both the cb and antenna ends. i have also calibrated the swr like i was told to do and it still lights.
-   d21 hardbody
Best Solution
posted on Sep 24, 2007
Helpful)
Dixie Outlaw
Rank: Master
Rating: 84%, 24 votes
Well to start with the swr meters on judt about all cb radios are just for reference and do NOT reflect the actual swr reading in your antenna system.If the red antenna warning light is coming on then I would bet you do have a high swr reading. Also the factory coax in big rigs of any make are CRAP!!. I would suggest that you install a new length of coax and it needs to be exactly 18 feet long as this is any antenna manufacturers recommended length. I dont know what year modle KW you drive but I do know from experience the 2007 models do not have a good ground system in them, at least the ones I have worked on. You may also need to ground your antenna brackets to the chassis with a peice of wire, and be sure where you ground it to all the paint must be removed and be bare metal at the point where you run the ground wire to as this will give a positive contact point with the ground. You can install the coax and the gruond yourself more than likely because its not to complicated but you do need to let a cb shop check your swr and set it if needed because he will have a much better swr meter than what is in the radio. The cost for the swr check and set should run somewhere around $ 15- $20.
If your charged more than that you are getteing ripped off by the cb shop. If you have any futher question you can email me at outlaws_cb_shop@yahoo.com and I will be glad to answer any questions you might have.
Was this helpful?
Yes
No
Solution #2
posted on Mar 30, 2009
Not Rated)
frank673644
Rank: Apprentice
Rating: 0%, 0 votes
The red light always comes on while mic is keyed. It is designed to do that. It will blink on and off while mic is keyed if there is a SWR problem. This is explaned in operaters manual.
Was this helpful?
Yes
No
Solution #3
posted on Feb 09, 2009
Not Rated)
tparsenault
Rank: Wiz
Rating: 82%, 106 votes
You probably do not have a problem at all if the radio has been"tuned up" by clipping the limiter diode. It isn't an uncommon thing to happen if the light just flashes while your modulating, that is probably whats happening.
Double T
Was this helpful?
Yes
No
Popular Solutions for Magnum S9 Base CB Radio
Questions and Unsolved Problems for Magnum S9 Base CB Radio
Do you recommend Magnum S9 Base CB Radio?
Answer
Answer
no volunm control
Answer
lost radio code please help!!!!!!!!!!!!! its renault tuner list model no 22dc259/62p prod no... (More)
Answer
Im installing a west marine vhf500sc on my tugboat. I have all the power, ground, and antenna hooked... (More)
Answer
I have a Renault Megan Scenic 03 reg and i need the 4 digit radio code can anyone help??
Answer
come si elimina il rumore di sottofondo ciao
Describe your CB Radios problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CB Radio Experts
Top Audio & Video Equipment Repairmen
in Baltimore, MD
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
