Hi rinster_26,
changing the ice dispenser, checking the pump at the bottom-back of the refrigerator - both should work.Check the water in the pipes going up the refrigerator.
Please check the water pipe as it leads to the under the kitchen sink
.It should be tapped in to the sing water line with an under sing spike.It has a turn stile on it that acts as a valve. It is most likelyshaped like a small metal sliver or spike. This should be open to allowwater to fill the line.
Some models do have a motor that helps circulate the water. If itlooses its prime or gets an airlock in the line, the water will notcirculate. This is because it is a low pressure pump.
Does your model have a water filter. The filter sometimes needs tobe changed because it gets clogged occassionally, depending on yourhardness of water.
ALSO does your model have a coil of tubing in the lower right hand of the refrigerator that is designed to keep water cold?
This can also become kinked, have an airlock or develope ice.
Do you have the owners manual for your refrigerator?
Let me paste one for whirlpool. More likely, the working is same for most of the refrigerators.
http://www.whirlpool.com/assets/pdfs/literature/Use and Care Guide - XXXXXXX.pdf
If this does not work when you click on it, simple copy it and paste it into the address bar.
There is a washer valve on the ice maker, however you said youreplaced the ice maker. This makes me believe something else may bewrong. I belive you do have a filter on the ice maker on the freezerside. However you will need to check out this manual thourghly to seewhat you might discover.
it is difficult to diagnose what is wrong here without being able to work directly with the refrigerator.
The trouble shooting guide mentions all the things I have already mentioned to you.
These manuals are ment to be for multiple models, so do not worrythat all the accessoreies represnted in this manual does not match yourmachine precisely.The X refers to anoption that your machine does not have. So do not worry, the icemakerstill operates the same.
Any further help, let me know.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied,
John, i think the problem lies in the main circuit board of the machine. Based on the things you have said, it all comes down to the main board. If the main board is working properly, the lights must be reacting to the buttons once pushed. Try fixing this board.
Thanks for using FixYa - If you need further clarification about your question - please use the "continue with this expert" option so we are connected in the future.
The ice maker and the water dispenser is on the same pump, check the pump that pumps the water in and see if you hear it pumping water if not the pump has gone out and yor going to need another one. I hope this helps you thanks for using FIXYA.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Yes afer analysing the issue and the solution its proved that the problem with ice dispenser or auger would be taken care of as well.
Thanks
Have a nice day.
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
I also have a problem with ice dispenser or auger would this be taken care of as well.
Sorry, one more thing, the fountain area where you switch from water to ice and push the button for either is not working, the flapper does not open and does not light up any of the lights over the buttons. Thanks R. Gonzalez
will oder part and see what happens. Thanks
Replaced valve same problem .....
Will replace foutain board.
