Question about Car Audio & Video
ROUTING OF FAN BELT ON PULLIES
I need to replace the fan belt on a '91 chrysler imperial (3.3L V6, built 9-90). the old belt's off, i need to know how to route the new belt pls.
  • BOB Apr 23, 2009
    GOD BLESS YOU AND THANK YOU!!! YOU SAVED THE DAY FOR ME! :o) TYVM, ROBERT
  • 655 Answers
Hello hawgshuggs,
The best place I've found for serpentine belt routing diagrams is the Gates Rubber web site. Here's a link to the specific page for your '91 Imperial with 3.3V6 engine. It shows 2 belts and you'll need to know which one is yours. Click on the little camera icon to the left to view and/or print out the routing diagram.
http://www.gates.com/part_locator/index.cfm?location_id=3598
Hope this helps. If it does, please rate as "FixYa".
Posted on Apr 23, 2009
Fan belt broke I bought a new one but I don't know how it goes its a serpentine belt for 1992 Chrysler imperial 3.
Usually there is a diagram under your hood but in case the sticker is gone here is a diagram. This is for a 1992 Chrysler Imperial 3.3L V-6
Aug 16, 2015 | Chrysler Cars & Trucks
Timing belt tensioner 2lt v6 galant where is? want to replace front crank seal need to de-tention belt
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
Feb 19, 2012 | Cars & Trucks
I need serpentine belt routing for 91 gmc 4.3 with a c
Below is the master help link provided to go through belt routing diagram:---Timing belt,drive belt,serpentine belt,accessory belt,fan belt,engine belt routing diagrams for all types of car models?
Click the link below :----http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help.Thanks.
Jan 29, 2012 | 1991 GMC K1500
98 concorde 2.7 engine is eating drive belts and lower pulley wobbles. i suspect the pulley problem is reason for belt eating. i am looking for diagram of routing can not find. any other info i can get...
Yes you are correct the pulley is bad. More that likley the tensioner pulley id the issue. I reccomend changing all of the pullies. You should have a belt diagram under hoon on top of fan shroud. If not try owners manual. Google has some helpful sights also. Last resort you could go to your local parts store sometimes they can get a diagram from there sytem.
May 16, 2011 | 2000 Chrysler Concorde
What's the belt diagram for 92 Chrysler imperial
Hello.
Here you are as asked for.
Thank you for using FixYa.
Mar 21, 2011 | 1992 Chrysler Imperial
How to replace a serpentine belt on a 91 chrysler imperial?
Locate the "belt-tensioner" Remove the old belt by pulling the belt-tensioner to remove the pressure on the belt. Reinstall a new belt. If needed, the belt pattern can be found on the frame next to your radiator (a sticker with a belt pattern)
Jan 09, 2011 | 1992 Chrysler Imperial
How to replace serpentine belt on a car
1. Make a drawing of the routing of the existing belt before you take it off, or there may be one on the fan shroud or nearby. 2. Locate the spring loaded tensioner. It will be a pully that is not connected to any other component. 3. You will need a long braker bar (most likely half inch drive). On the spring loaded tensioner you will find a place (a cut out square) to insert the braker bar. (Note, no socket is needed, just the braker bar itself) This is a secure way to leverage the tensioner 4. Using the braker bar, move the tensioner to release tension on belt. 5. Slide old belt off pulleys, and move around fan. 6. Install new belt with same method, making sure the routing is correct.
Oct 31, 2010 | 1997 Chrysler Sebring
Serpentine belt diagram for a 3,3l dodge dynasty with ac
For the 1991 DODGE DYNASTY - V6 3.3L 201ci GAS FI N R , review this informacion:
Belt Routing Diagram
- Multiple Accessory, w/o A.C. (Mfg. After 2/27/91)
- Multiple Accessory, w/A.C. (Mfg. After 2/27/91)
- Multiple Accessory, w/o A.C. (Mfg. Before 2/27/91)
- Multiple Accessory, w/A.C. (Mfg. Before 2/27/91)
Remove the serpentine belt by using a breakover bar, rachet or serpentine belt removal tool with the correct size socket for the pulley mounting bolt. Rotate tensioner arm to release tension. Remove the belt.
Hope helped with this (remember rated this help) Good luck.
Nov 12, 2009 | 1991 Dodge Dynasty
BMW 840 CI fitting new fan belt
Most have a diagram somewhere under hood.
Aug 28, 2008 | 1996 BMW 8 Series
Car Audio & Video Logo
1,102 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
