Question about T-Mobile Dash Smartphone
My tmobile dash power button isnt working
So I have a tmobile dash and my power button is not working anymore but the phone is charging so its not broken is there any way I can turn my phone on without using the power button?
  • robsmore1111 May 01, 2009
    T-mobile dash power button won't work. Any ideas on how to power it up. Battery charge light shows green. Thanks! Rob
This is extreme, but my Dash phone is alive again. After pushing the power button HARD! for an hour, I broke the button, and pushed it inside the phone. I ripped the button out of the phone with a knife, and carved away the plastic so I could see the circuit board inside. (about a 1/4" x 1/4" hole). Looking in, there are 2 empty holes in the middle -the former mounting legs for the button. To the left are 2 leads (solder points), to the right there are 3 solder points. Using a screwdriver, I jumped (made a connection) with the 2 leads closest to the edge of the phone...ie: 1st solder joint to the left of the holes, and 1st solder joint to the right of the holes, and it powered up. I will cover the hole with black electrical tape. I build prototypes for architects for a living, so this is a successful solution.
Posted on Jun 25, 2009
My dash has no button and it charges so i know it works but i cant turn it on
Posted on Oct 22, 2009
TrimlineDale>>>>
omg!!! i had a t-mobile dash like 3 years ago but my power button fell in. No one knew how to fix it. The store wouldnt take it back or give me a new one because I didnt have insurance. Over the past 3 years Ive had about 4 different phones and non of them compared to the Dash. i randomly found my dash in my desk all dusty and decided to see if there was anyway to fix it. and out of luck i found your post! OMG! You saved my LIFE. I LOVE YOU! haha Now i could put away this stupid blackberry pearl I have and get back to my DASH!!! THANK YOU!
Posted on Sep 27, 2009
What if the solder point is busted?
Posted on Nov 10, 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 87 Answers
See if you can use a small object to push in the power button...it probably needs replacing.
Posted on Jun 02, 2009
My phone won't power up. It starts on the white
you have to do a master reboot onyour phone.the same thing happened to me. before u power up the phone hold the 2 white line buttons and then power the phone on without letting the buttons go.
Jun 09, 2009 | T-Mobile Dash Smartphone
My tmobile dash freezes every time i try to start.
Turn the handheld off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send” button is considered as the green phone button.
How to Hard Reset a T-Mobile Dash with operating system: 1. Select Start
2. Select Accessories
3. Clear Storage
4. Type in 1234
5. Select Yes
if this helps please rate the posting..thanks
Mar 02, 2009 | Cell Phones
My tmobile phone will not turn
try to plug in thew charger. if it indicates that it is charging then you most likely have a broken power switch. that is a common problem with this phone. if youcan get a local cellphone repair tech to service it, contact www.fixphonenow.com they can repair it.
Nov 15, 2008 | T-Mobile Dash Smartphone
Resetting my tmobile dash?
turn off phone, press and hold the 2 top soft buttons under the screen (not the larger ones with the phones on them). Press and release the power button while still holding the other 2. Wait a few seconds, when the screen changes you can release the 2 buttons. After a few minutes it will ask you to push the call button to reset. Make sure you have your contacts on the sim card, because all personal settings are erased.
Aug 28, 2008 | T-Mobile Dash Smartphone
Dash stuck on opening TMobile screen
The Windows Mobile installation may be corrupted.
The only way to fix that problem is by re-installing the windows software on the phone.
You can get the software for the T-mobile dash at the following link: http://www.t-mobile.com/wmupgrade/
Be warned that if you use this method most of the data on the phone will be lost, like text messages and etc. Your contacts should be fine as the are stored on the SIM Card and if you have been syncing your contacts with your PC then they should get loaded when you do the up
Jul 04, 2008 | T-Mobile Dash Smartphone
T-mobile dash
I tried using a the google mail java app on my tmobile dash. It froze up on me, and when i turned it back on it just stays at the "tmobile" splash screen. I have tried using the soft key and power button reset but it doesnt work. What's weird is that it wont power down unless I take the battery out. It powers on, shows the tmobile splash screen, then freezes. Is there any other way to reset it or is it totally bricked? I bought it new off craiglslist so tmobile wont replace it for me cause I'm using it unlocked on cingular.
Ok bro I know I am a bit too late to help you with this problem but someone else may benefit from these directions. I see most places online only have half advice about this very common problem with T-mobile Dash.
This is what you need to do, you have to do a hard reset exactly like "reviel" mention. Also like he said timing is essential but the trick is that you need to show some patience through the process.
Note: Please read the directions completely before doing anything for better results.
Step 1: Take your battery out and shut off your phone
Step 2: Press and hold the two soft key buttons.
Step 3: Press and hold the power button for exact two seconds, 1001, 1002 and release, but continue to hold the two soft key buttons.
Step 4: Within seconds a black screen with some text will come up asking you to confirm if you wanna delete everything; and right then you let go of your soft key buttons and press the green call button (also known as the "send key").
Step 5: You are done but not really, your job now is to find something else to do and leave your phone alone for at least 2 minutes. Eventually if you don't have a SIM in it, it will prompt you for it and you click the soft key to choose "OK"; also, it will ask you to confirm to restart and you click the soft key to chose "Done" for it.
Wait a minute for it boot up and overall it should do it.
May 31, 2008 | T-Mobile Dash Smartphone
Won't Boot Up, Alternates between Windows screen and TMobile screen
Master repoot the phone. You will loose all data, but you can recover the phone.
1. PRESS AND HOLD BOTH SOFT KEYS.
2. WHILE HOLDING DOWN SOFT KEYS, PRESS AND RELEASE THE POWER BUTTON, WAIT 3-5 SEC. (PHONE SHOULD POWER ITSELF ON BY DOING THIS)
3. RELEASE THE TWO KEYS SOFT KEYS.
4. WHEN SCREEN ON DASH LOOKS LIKE IT'S IN DOS FORMAT, PRESS SEND (GREEN ANSWER KEY)
May 16, 2008 | T-Mobile Dash Smartphone
Tmobile dash is getting me p'd off
Mine does the samething. I'm running 6.1 and have found the problem to be the system fails to read the sd card on boot. When I reset my memory I don't put the sd card in until the system has booted back to the start screen. Works fine everytime.
Apr 15, 2008 | T-Mobile Dash Smartphone
How do you fix a frozen dash
It's actually a pretty easy fix, but it may take a few tries before you get it right. Start by taking out Sim card and battery, after a few seconds, but the battery back in. Then hold down the 2 softkeys (with the dash's on them) together and press down on the power button for about 2 seconds. Let the power button go but not the softkeys. You should get a black screen that will instruct you to hit the Green "Go" button to restore factory settings. Once you do this the phone will reset itself. It will restart very slowly, so be patient.
Apr 14, 2008 | T-Mobile Dash Smartphone
T-Mobile Dash Smartphone Logo
1,461 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
