Disc tray has been locked and i cant find the manual to open it
  • 68 Answers
The problem is in side ther is a componnent it looks likrs a trsnsistor. a end senser its that what is creating, the problem,
Posted on Apr 23, 2009
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
Dvd door will not open
with the unit turned off press and hold "8", and then press "x" on the unit until "unlocked" appears on the screen.
This is from page 83 of the manual regarding tray lock feature.
Nov 18, 2007 | Televison & Video
Cant open my disc tray on my asus f551m
hi there,
On your Disc tray you can see small hole, just grab a pin or small pin to open it manually...
thanks
Apr 21, 2014 | ASUS Essentio Desktop with Intel Pentium...
Need phone number for tech support for sony BDP-S590
Cancel the Child Lock by following the instructions at the bottom of the first column of page 37 of this manual.
If you still need to contact Sony, start here, select your region of the world, and go from there.
Mar 10, 2013 | Televison & Video
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
Draw won,t open cant get my game out xbox360
If the tray does not open when you press the eject button, try to manually open it. To do this:
  1. Unplug your Xbox console from the power source.
  2. Locate the manual release button on your Xbox console.
    For most Xbox consoles, the manual release button is located in a small pinhole to the left of the eject button under the disc tray.
    For some Xbox consoles, the manual release button is located under the disc tray. It can be under the "O" or the "B" in the word "XBOX" that appears on the tray.
  3. Insert a straightened paper clip or other small tool in the hole at an angle to the left. Gently push the paper clip to try to press the manual release button and partially open the disc tray. This may take several tries. Typically, a thin paper clip works better than a thick paper clip.
    If you insert the paperclip in the hole and find an obstacle, this indicates that your Xbox console's manual release button is located in a different area of the console. Look under the "O" or the "B" in the word "XBOX" that appears on the tray. If this is the case, insert the paperclip under the "O" as outlined in step C. If you find an obstacle, insert the paperclip under the letter "B”. The manual release button is located in one of these three locations.
  4. After the disc tray partially opens, pull the tray with your fingers to fully open the tray.
Hope this will help u.
Sep 22, 2009 | Microsoft Premium System for Xbox 360
Xbox 360 3 red rings, cant open disc tray
their is a manual eject slot on the xbox under the faceplate, this page should tell you how to do it, but you do need to be persistant and give it a lil force. http://support.microsoft.com/kb/906935
Jun 29, 2009 | Microsoft Video Game Consoles & Games
Cant unlock my dvd player
I tried the child lock directions from the manual to no avail. I unplugged it from the power source and I was able to open the tray. Good luck.
Apr 02, 2009 | Sony DVP-NC665P/S Multi-disc DVD Player
Dvd tray is locked and i cant find the manual to unlock it.
Press the open button down for 5 sec and the dvd player will say unlock and then you can hit the open button and the tray will open. I just did this. IT WORKED YEAH!!!!
Jan 31, 2008 | Sanyo DVD-SL20 DVD Player
Televison & Video Logo
655 people viewed this question
Top Televison & Video Experts
