Question about Pyle PLA985R Car Audio Amplifier
PLEASE HELP with PYLE PLUS GXA-280A
I am trying to hook up a PYLE Plus GXA-280a dual channel 400 watt (max) amplifer. I am hooking it up on the high input. The ground is hot? There is literally power going to the ground therefor i am unable to continue with my installation. I just took it out of my truck and it was working fine. I installed it there too. When the 12v and the REM are hooked up, the ground is hot. What can be my problem...SOMEONE PLEASE HELP!!!!
  • 631 Answers
If the ground terminal is connected to a ground wire, the ground wire isn't connected to a good ground.
Posted on Sep 24, 2007
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
My pyle 2200 1400 watt 2 channel amp wont get power..... why!!!!!
did you check the remote turn on wire connection at the back of stereo?
Jan 15, 2012 | Pyle Car Audio & Video
2003 Cadillac DTS w/Bose, has rear sub & adding Pyle dual 10 sub
two channel will do with the same power power rating of your speakers ex. your speaker is 500 watts per piece so you need to buy a 500 watts per channel amplifier
May 16, 2010 | Pyle PLHB10 Car Subwoofer
I have a pyle blue wave 12inch 800w subwoofer for a car hook up?
that just means it is dual channel.
if you have a stereo amp just run the left wire to one terminal and the right wire to the other terminal.
if your amp is mono run the wires to the first terminal and then from there to the second set of terminals.
PLEASE NOTE that by doing that you are bridging the speaker if the speaker was 4ohms to start with you just dropped it to 2 ohms so make sure your amp can handle that.
Dec 24, 2009 | Pyle 12" Molded Blue Cone High Power...
Where can I get wiring diagram?
www.pyleaudio.com/manuals/PLMRA220-420.pdf
Jul 22, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
Help
one wire to pos to amp plus to speaker one. now secound speker use neg. to neg. on amp. now take a speaker wire and hook up the remaining neg. post. on the spekers. This will run them in seris like my 4000watt rms amp at a 2 ohm load. Make sur your speakers can handel the rms load of amp. If not they will blow.
Jul 19, 2008 | Car Audio & Video
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
What is wrong with my system
wiring may not be the problem but try connecting each coil to separate channel and make sure polarities are correct.
Aug 08, 2007 | Pyle PLA2200 Car Audio Amplifier
Pyle PLA985R Car Audio Amplifier Logo
233 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
