Question about Grilling
My grill lights with a lighter but the flame stays low and doesnt get any bigger it seems like something is stopping the flow of gs to the burners if anyone can help greatly appreciated
    Problem Solver:
  • 11 Answers
Its common for spiders to block the tubes take a look at this
Posted on Apr 23, 2009
  • jmt Apr 23, 2009
    Its common for spiders to block the tubes take a look at this.
Low gas to burner
turn off gas source, check gas line for possible blockage to that 3rd burner, sometimes when we cook food with liquid , such as sauces or soups , then tend to overflow and get into the burners and the gas lines causing a blocked gas line, where the lower half of gas line is filled with liquid,,,
Dec 28, 2013 | Barbeques Galore Turbo Classic 3-Burner...
I light the first burner and the flame doesnt seem as big as it should be, I light the second burner and the flame goes down slightly, I light the third burner and it goes out completely
clean all the burners and the orffices , check the gas is full if lpg ,check gas line is not blocked , if this natgas grill check connection is in tight and not loose giving small flow of gas.
Aug 28, 2011 | Grilling
How can i manually ignite the grill
What I do is remove the grates and flame guards and light the burners with a stick lighter then turn em on low and cover them with the flame guards then sit the grates back on there.
May 28, 2011 | Brinkmann Charmglow Stainless Steel LP...
Grill does not get hot enough. Which seem like low gas flow. One burner does not light
Yes, it is probably low gas flow. I assume you feel comfortable that there's a reasonable amount of gas in the tank.
Here's what you need to do. Turn OFF the LP Tank Valve and disconnect the hose from the tank. Wait 5 minutes. While you're waiting lift out the tank. Does it feel as heavy as it should? Or does it feel lighter than it should? If it feels lighter, you're either very low or have run out of gas.
In either case, here's what you need to do when you reinstall that tank or a new one. Attach the hose to the tank. Turn the tank valve On VERY, VERY SLOWLY ( I'm talking slow motion). Once the valve is fully open, light the burner that's farthest from the tank and turn it to the highest setting. Does the burner flame look correct? If it does, light the next burner and turn it to high and continue doing that until all the burners have been lighted. If the first burner flame doesn't look correct after you lit it. Turn the tank OFF and repeat what you did previously. If it still fails to produce the right flame heights, either the venturri valves on each burner are clogged or the regulator is locked up.. You will have to remove the burners to clean them. If that fails to solve your problem, buy a new grill hose and regulator. You can purchase it at either Lowe's or Home Depot or your local hardware store. Just be sure to take yours with you, so that you can get the right length and brass fitting size matches.
I'm sure this will solve your problem. Please be kind enough to let me know.
Happy Grilling
Rich
Mar 04, 2011 | Char-Broil Advantage 463453306
How do I light the grill manually
Get a butane grill lighter. Open the hood of your grill. Remove the cooking grates and one by one turn the burner to low. Light the butane grill lighter prior to turning the burner on and as you turn the burner to low touch the flame of the lighter to the burner. Leave all burners on low, until you replace the cooking grates. Be very very careful, as you don't want gas to buildup before each burner is lit.
Then contact Brinkman for replacement ignitors.
Jan 30, 2011 | Brinkmann ProSeries 810-6330-W Grill
When I turn the on the first burner will light and flame are OK, but lighting the next burner the flame goes down to a point that you can barely see the flame. It appears that the gas get reduce to have a...
sounds to me like your other burner isn't getting the same amount of gas flow. what you need to do is give your grille a good cleaning and check the lines for any leaks. you will always smell gas so it will be hard to tell by smell alone. Test your lines by wrapping them tight with foil or something removable and turn your grille on to see if the flame gets bigger.
Oct 04, 2010 | Grilling
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
Genesis s310 stainless grill. Does not fully light.
Regulator is not bad, as I stated before new valves are designed to reduce gas flow if valve is opened to fast. This is so if grill catches on fire, the tank will shut itself off, thus propane will stop flowing causing fire to extinguish itself.
Dec 28, 2009 | Weber Genesis E-310 Gas Grill
Poor gas flow. Burners will not stay lit. Gas
Try taking a large hammer or set of vice grips and banging pretty heftily on the tubes feeding the burners. These are usually build ups of Carbon. If not, then make sure your connections are good (sort of move them around to see if they are loose), and make sure your propane is not getting too close to empty (you can shake it around and feel/hear the propane).
Aug 10, 2009 | Amana 5939 Grill
Only enough gas flow for 1 of 3 burners
Shut off the tank and remove it from the grill. open all valves. close all valves. Reconnect tank to cooker and SLOWLY open the valve a hair. Then retry.Something in the dang newer safety tanks cause this phenom.
Mar 22, 2009 | Weber Genesis Silver B Grill
Grilling Logo
133 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
