Question about Panasonic AG-DVX100B DV Digital Camcorder
My Panasonic DVX100B: Loading deck won't eject the cassette
It says: AUTO OFF - UNLOADING DECK. There is a sound as if the cassette were rewinding and a few seconds goes off but the deck won't pop up... Suggestions? Condensation?  PS I used three weeks ago and when I stored I did not notice there was a cassette in the deck. I will appreciated it!
Good day!
  • bwalsh61 May 11, 2010
    Should not use the camera in wet settings. Are you hitting the eject button and the cassette will not open up?
  • 126 Answers
Sorry but if so, the best you can do is to replace tape mechanism unit,there is no way to repair it is not so expensive part though.
Posted on Oct 14, 2009
How can I fix my 2002 Honda Civic cassette player from ejecting cassettes. I tried a cassette deck cleaner and that gets ejected the same.
The auto-eject feature is normally triggered by the tape reaching its end. This causes the tape to tighten and then activates a trip lever that starts the eject cycle. Most auto tape decks that are not auto-reverse eventually have this problem. It is not usually the deck's fault, but it is with the tapes themselves. After many plays the tapes get wound too tight on the reels and drag, causing the auto-ejection. This is especially true with the thinner, larger tapes found in the C-90 and C-120 varieties. Try taking the tapes to a regular tape player and then fast-forward them from one end to the other and them a full rewind as well to loosen the tape on the spindles and re-distribute the tension. Hopefully this will work.
Sep 25, 2015 | Audio Players & Recorders
How do I fix error F06 on my Panasonic NV-FJ620??
F06 means the mechanism is locking up after unloading. The cause of this can either be the carriage that the tape sits in, or the loading motor. It's important to check for damage on the carriage.
Incidentally I think this model uses a "K Deck Mechanism".
If you search the web for Panasonic K Deck you should find a PDF manual free.
In fact I have it on my blog site under service manuals.
http://therealchart.blogspot.co.uk/p/technical-help-tips.html
Sep 09, 2015 | Panasonic Televison & Video
VHS cassette accepts and ejects with kir..r...r sound. I have removed the power cord (Power OFF) and cassette was inserted halfway and then plugged the power cord (Power ON). At this time the VCR ejects...
First of I think you have a K-Deck mechanism. If you do a Google search for "Panasonic K-Deck" you should find the free information. If you can't you will need to E-Mail me.
This sounds like a a timing problem, perhaps caused by some damage to the Cassette Holder. The mode switch could be part of the problem too. They are quite tricky to set up to get the timing right, I do know the Cassette has to be inside the machine to set it up. The good news is that parts are easy to get hold of, so if any thing is damaged it can be replaced. Curry's partmaster is a good place for parts.
Oct 25, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I put a tape in and it keeps flipping sides without playing and pops out and says Error. It even does it with a CD-Cassette Adapter. Before the Cln came up and I pressed on the eject button and that...
Cassette decks have sensors on the reels which tells the deck when the tape is at the end. When the reel stops the deck switches the direction of the tape and sometimes the position of the head(depending on the deck design). Most common problem is the tape is hard to turn, or the deck won't turn it ( deck thinks it's at the end, click, still won't turn, click, won't turn, click) you should fast forward and/or rewind your tapes from start to finish once in a while to keep them lined up(narrow spool/less friction), you shouldn't have to but it works. BUT,...your problem sounds like a slipping or broken belt/or dirt causing the problem. Take the deck out to have a look and clean the capstans(rubber rollers)belts,heads with alcohol and a Q-tip while your at it. Dirt's usually the main culprit and if you do have some other problem, cleaning it is always a win/win (It will also sound better clean)
Sep 20, 2011 | 1995 Buick Regal
How can I eject a cassette from deck A it has taken the cassette and is not ejecting it nor is it playing it
The loading is not completing and so the mechanism will not release the forward eject of the cassettte to work. So please check on the belt and if this is worn then the loading will not work as it will slip and so will not complete the loading back to rest mode.
Jul 22, 2011 | Technics RS-TR575 Single Dual Cassette...
Hi F06 appear on screen;cant eject cassette
You have what's called a Panasonic K-Deck machine. That code means the Mechanism locks after unloading the tape. The cause of this could either be the 'carriage' where the tape fits, or the Load Motor. Plenty of free information on line just type "Panasonic K-Deck" into Google.
Jan 07, 2011 | Panasonic NV-SD235AM VCR
My Panasonic NV-HD660 VCR is not unloading/ejecting a video cassette, in fact turns off itself and shows error message HO2, please help!
Yes the most likely cause is the mode switch, you can spray it with Servisol Video 40 or replace it. But you will need the service manual for that. The good news I think your model uses a K-Deck, and there is plenty on-line about the Panasonic K-Deck.
Dec 02, 2010 | Panasonic NV-HD635AM VCR
Cassette deck won't open or play tapes
Take it to a Panasonic authorized service center. They'll fix it.
Apr 01, 2009 | Technics RS-TR575 Single Dual Cassette...
Tascam 102 mark 2 cassette
there is a mechanical problem in your tape deck. probably a losen rubber band. it clicks because the rubber is too lose to move the mechinal parts. so when you power off, it losen the whole machanical parts..it is very easy to replace..opend the deck and check it out..good luck
Apr 13, 2007 | Tascam 102 MKII Single Dual Cassette Deck
Panasonic AG-DVX100B DV Digital Camcorder Logo
288 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
