Question about Refrigerators
Hoshizaki ice machine
I have a Hoshizaki ice machine and the control board has a small burn mark. the machine does not go into safety, it keeps water coming as it begins to freeze to cubes. I turn the machine off because of the fact that the circuit board seems to over heat. Any suggestions as to the cause of this? Shouldnt the machine shut itself off rather than allowing itself to continue its harvest and burn?
  • 3 more comments
  • dinopantelid Apr 23, 2009
    Any idea where I can get a cheap control board? this machine is really old, with the economy the way it is Id like to take my chances and try to replace it rather than buy new. Ebay? do i need the exact same control board?
    Thanks very much.
    Sorry.. again!
    Where would I find the model number of my machine/and or the circuit board model? the closest thing I found to a model number was on the panel. this is what it reads "This unit has a control product e control board part number " 2 A0836-01 "
    Maybe this ice machine doesnt have OEM panels :( This is all I found!
    Thank-you my friend. You have been the most helpful ice machine specialist i've ever dealt with!
    If you find a minute and can see where this part is on either site. I cant seem to locate a part search for 2A0836-01
    President:
  • 1,902 Answers
The machine will continue to run water all the time while in harvest mode. The control board blew, and just needs to be replaced. Controls boards can fry without any other signs of anything else being bad. Hoshizaki ice machines dont have a over heat relay that shuts it down upon oerheating if it is the control board
Posted on Apr 23, 2009
  • 1 more comment
  • Jeremy Reddick
    Jeremy Reddick Apr 23, 2009
    ebay or Hoshizaki.com. They are easy to replace themselves as long as you do not get any wires crossed. Yes you need a OEM part for the Hoshizaki, unless you can find the same volts, amp, fuse, connections and everything else the EXACT same. Better to just go OEM or you can try and see if Johnstone Controls has a board that matches. Johnstonecontrols.com
  • Jeremy Reddick
    That is what you need. On the inside of the front panel there is a model and serial number in there
  • Jeremy Reddick
    That is ok. That is the part number that you are looking for in Johnstone Controls or Hoshizaki
How to reset Hoshizaki ice maker ?
If you just want to reset it because it is making a beeping sound, there is a small white button on the control board. just press it while the power is on. If you want more than that, please supply more info.
May 25, 2014 | Hoshizaki Freezer Commercial Ice Machines...
How to reset hoshizaki ice machine
small white button on control board. press once to stop beeping. Very small but it is labeled and very hard to see.
Feb 09, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Where is the reset for a hoshizaki km800mre
most all machines by Hoshi, the reset button is on the control board. take your time and look at it as it is labeled but is very small.
May 29, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine beep 3 times, what is it stand for?
in the freeze cycle too long. Most common is the water valve leaking through. Second thing to check is for a stuck float switch.
Oct 18, 2010 | Hoshizaki Freezer Commercial Ice Machines...
I have a hoshizaki km-250bwf and it the comprsser
Check the control board for a "output" test switch.
If it is "ON",turn it off.
Nov 19, 2009 | Hoshizaki Freezer Commercial Ice Machines...
KM-500MAH water keeps cycling thru when in ice making mode.
if this is a water cooled machine, the head pressure flow controller need to be replace/adjusted.
Jul 12, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Please Heal
starving for water. clean or replace water filter or adjust water float assembly that determines how big cubes are. probably not getting abundant water during timed fill sequence. no water equals little ice.
Sep 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Ice Machine Model KM-500MAF
(Quated From Hoshizaki Technical Bulletin)
An alarm code of 3 beeps
every 3 seconds means that the control board has shut
down on the 60 minute freeze cycle back up timer.
The “E” control board has a 60 minute timer that starts at
the beginning of the freeze cycle. If the float switch fails
to open and start the next harvest within 60 minutes, the
board will automatically start the harvest cycle. If this
occurs in two consecutive cycles, the control board will
shut the unit down on the manual reset, freeze cycle
back- up timer. The yellow fault LED marked “60 min.”
will illuminate. This safety is designed to help prevent a
freeze up of the evaporator.
Once you have identified the 60 minute alarm, there are
several things to check. Reset the alarm by depressing
the white reset button to the right of the fault LED’s.
This must be done with the power “ON”. Now check the
float switch to see if it is stuck in the up position. A stuck
float can occur if scale is present on the reed switch
shaft inside the housing. To check it, drain the water
reservoir, unplug the black float switch connector (K5)
from the control board and check it with an ohm meter
for a closed switch (zero ohms). If the float switch is
sticking, clean it with ice machine cleaner or replace it as
necessary.
An inlet water valve which is slowly leaking by during the
freeze cycle can cause a 60 minute alarm. If the inlet
water valve is stuck wide open, it is unlikely that any ice
will form on the evaporator. Check for a slow leak by
allowing the unit to cycle into the freeze cycle and
disconnecting the hose at the outlet of the water valve. If
water leaks by during the freeze cycle, the water valve
diaphragm is likely damaged or the small diaphragm bleed
port is clogged with scale. Clean the bleed port or replace
the diaphragm or entire water valve as necessary.
(I Recommend to get a refrigeration tech for this part).
Another possibility is a refrigeration system problem. You
should use normal refrigeration diagnosis procedures to
check for one of these problems. If the thermostatic
expansion valve is not feeding properly or the refrigerant
charge is low, the evaporator will not form ice as it should
and a long freeze cycle will occur. This could also be the
result of the hot gas valve not closing completely during
the freeze cycle or if the compressor valves are weak or
inefficient. An inefficient compressor however, will
usually show up first on the KM model through a longer
than normal harvest cycle. This is because of cooler
than normal discharge gas. Use proper refrigeration
practices to repair a refrigeration system problem.
While these are not the only reasons for a 60 minute
freeze cycle, they are the most common and should be
checked to resolve a 3 beep/yellow fault LED alarm.
Feb 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Refrigerators Logo
155 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
