1992 Isuzu Trooper Logo
r
robert salazar Posted on Oct 09, 2013
Engine cranks and tries to start but wont - 1992 Isuzu Trooper
dennis
Level 1:
Habit-Forming:
New Friend:
  • Contributor 45 Answers
  • Posted on Oct 18, 2013
dennis
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
45
Questions
Helped
9009
Points
91
I would first pour some gas in intake if it fires or runs a little could be fuel filter or fuel pump.if it don't fire pull a plug out and crank see if theres spark that's where id start
It turns over but it wont start
Engine cranks but won't start. Troubleshooting tips
www.samarins.com/diagnose/index2.html
In this guide, we are going to look into no-start problems when the car engine cranks,but won't start. If your engine won't crank at all, check the first part No-start: ...‎Why a car won't start - ‎Crankshaft position sensor - ‎Check Engine light
Engine cranks but won't start - YouTube
? 8:03
https://www.youtube.com/watch?v=1L4nB2NdA0U
May 16, 2014 - Uploaded by jimthecarguy
2003 Ford Taurus 3.0 liter 24 valve no start cranks OK.You will not ... Car will not start trouble shooting guide, wont crank, wont turn over, etc.
Problem 5: Engine Cranks But won't Start
Low voltage
does it crank fast, at 250 spec RPM?
no year, no joy, all cars have a year,
and and engine option (displacement size???)
my wild guess, is it wont crank or cranks dead slow.
right?
and the battery is DISCHARGED. right,
use jumper start cables. start now?
that be first.
wont crank
cranks perfectly but wont start ?(check for spark, x number of cyl)
spark good, try test fuel
test fuel works for 3seconds and stalls,. then fueling problem , ask.
1999 vt v6 commodore wont crank
Ok let's see, engine won't crank or want start. No crank means the engine won't turn over. No start means engine is cranking but won't run. If it will not turn over check your fuses,switch, battery cables,battery. You can get someone to hit the starter with a hammer while you try to turn it over in case the starter stopped in a flat spot.
2answers
Volvo 2005 EC210 BLC Engine Crank but no start .display shows code 140SID and 250 9
It can be faulty fuel pump or clogged fuel filter or its issue with starter or battery or may be problem with sensors.There are few possibilities that can cause these problem,there are few help links provided related to these issue. Click the link below and refer the troubleshooting procedure to solve the problem:-----
Engine cranks but will not start? http://technoanswers.blogspot.in/2012/02/engine-cranks-but-will-not-start.html
-------- Landcruiser prado won't start http://technoanswers.blogspot.com/2012/10/landcruiser-prado-wont-start.html ------- 2007 ford expedition engine cranks but wont start http://technoanswers.blogspot.com/2012/10/2007-ford-expedition-engine-cranks-but.html
: Engine Cranking Fast but not Firing up? http://whatisbyme.blogspot.in/2012/05/1999-lexus-gs300-engine-cranking-fast.html
1997 Oldsmobile Cutlass Ciera: The Engine cranks but not start? http://schematicsdiagram.blogspot.in/2012/04/1997-oldsmobile-cutlass-ciera-engine.html
Mazda MPV cranks but will not start? http://technoanswers.blogspot.com/2012/01/mazda-mpv-cranks-but-will-not-start.html
-------- MAZDA MPV WILL CRANK BUT NOT TURN OVER TO START? http://technoanswers.blogspot.com/2012/01/mazda-mpv-will-crank-but-not-turn-over.html
--------- Vehicle Cranks Fast but Won't Start http://whoisbyme.blogspot.in/2012/07/vehicle-cranks-fast-but-wont-start.html
How to test Crankshaft Position Sensor? http://fordrepairhelp.blogspot.in/2012/03/how-to-test-ford-focus-crankshaft.html
These details will help,keep updated for more help.
Turns over but wont crank...horrible screeching noise
To clarify, if the engine cranks or turns over but won't start, look for a stuck pulley on the engine. You may be hearing the belt slipping on that pulley. Take the belt off and try turning each pulley - also try starting the engine with the belt off.
My escort overheated so added water then i tried to start the car but it wont start, its cranks but it wont start
need add add antifreeze half antifreeze and water to raise coolant boiling point. replace thermostat and radiator pressure cap.wait until engine cool then try starting it up.depends on how long you drove car when engine over heated.if you turn off engine soon as it over heated no harm done.if you kept on driving and engine die of lack of cooling, and car wont crank you could have blown head gasket warped or cracked cylinder head.
3answers
Engine crank but wont start
have u checked to see if theres any gas in the fuel tank
4answers
Car shakes when trying to start and doesn't turn over
  1. hold gas pedal to floor while trying to start. do not pump pedal.
  2. holding pedal to floor is how you start a flooded f.i. engine
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you an Isuzu Expert? Answer questions, earn points and help others
