Question about Acer AL1716B 17" LCD Monitor
Acer Monitor AL1716
Unplugged computer, when I connected it and booted up, my monitor was terrible colors, and I cannot fix it. please help.
    President:
  • Acer Master
  • 2,022 Answers
Pls fix the vga data cable properly it is bettre remove it and fix it agin and tight the screw also. bye
Posted on Sep 24, 2007
Throw it away and buy a new one
Posted on Nov 04, 2007
SOURCE:
Samsung Monitor
Hi, Have you tried leaving it unplugged for about 30 min then switch the monitor on before you boot your comp up,
Let me know what happens ok
May 03, 2008 | Computers & Internet
What should be White is Gray
It may be one of the backlight CCFLs is not coming on fully. It may be the tube itself or it is warning in a way of a pending future failure. Replacing tubes is not terribly difficult if you order them from the monitor manufacturer, but they can be more expensive than you want to pay.
Checking for other fault is easy. Look for stressed electrolytic caps on the power board section. They will be bulged in many cases or leaking out a black or dark brown substance.
The other thing to look for is bad solder joints. Reflow some solder into any soldered connection that looks like it could gap from the wire. The flow should transition seamlessly between the copper trace and the component lead.
Dec 29, 2011 | HP 2159M Monitor
I have a Soyo Monitor MTNIDYLM2286 monitor. It was working fine for 1 year. 4 months ago it lost red and blue color so I replaced the laptop computer connection cord and the color came back. I was away ...
You know if it pops back and forth this could be an indication that the video card on your PC may not be doing well. The way to really make sure is plug your monitor into another working computer and see if you have the same issue if not and the monitor works fine you may want to replace the video card for your computer. Monitors are a dime a dozen these days especially CRTs that would be how I would approach this issue. Do not invest in a repair unless it is a flat screen monitor if you are going to pay for a repair at least do it for a flat monitor I have about 23 of them in my garage giving them away they are around. Thanks for using FixYa! John
Apr 02, 2011 | Computers & Internet
I lost the color blue. Is that a monitor problem, driver problem, or some kind of graphics software problem? And, how do I fix it? This occurred after I unplugged and moved the computer into another...
It may just be the cable, or the connector that attaches to the monitor or pc.
This monitor also had a similar problem, it was connected with a dvi to vga adaptor on another computer. I plugged it straight into the vga socket on this computer and it works fine.
If that is no help, you may need a new monitor
Aug 03, 2010 | HP w2207 Monitor
19" star logic MJ9BBK suddenly changed color
First check the connections to make sure they are tight,next go to desktop settings and make sure the external monitor has the same color configuration.
Sep 03, 2009 | Star Logic 17" LCD Monitor
Display changes color randomly
This would usually indicate a bad VGA or DVI cable since you have connected it to another computer with the same results... or it could be that the internal circuit is going bad.
Try using a different cable first. If that fixes the problem, then the cable is at fault, otherwise try cleaning the connector on the monitor with a small paper-clip or toothbrush and isopropyl alcohol while it is unplugged from power in case there is just a fouled pin hole in the cable jack.
Most likely the green signal (of the Red/Green/Blue [RGB] colors) is being interrupted on its way to the monitor.
Sep 20, 2017 | Sceptre X20WC (Black) LCD Monitor
Monitor is blueish
If the Blueish problem appears try play around with the VGA cord and see if the Colors comes back, if not, try hiting the monitor to see if the lines and color problem comes bcak to normal. If not your monitor's circuit board needs some dry solder, it could be the cold solder problem. Cheers.
Jan 21, 2009 | LG Studioworks 700S 17" CRT Monitor
Acer Al1912 monitor
You can try adjusting your color and tint on your monitor and also adjust the resolution with your computer. To make sure it is not a problem with your video card, take and use a known good monitor (borrow one from a friend, family member, co-worker, etc) and connect it to your computer system. If the system boots up fine and there is no problems, then your monitor is going bad and you will need to replace it, because it is not worth fixing financially. If you plug it to a known good monitor and it is still doing the same thing, then your video card is bad and you will need to replace that. You can see the symptoms and this same procedure in my profile under tips. I hope this helps and please let me know if you need further assistance.
If you would not mind please rate my help, I would really appreciate it. Thanks.
Jul 04, 2008 | Acer AL1912 19" LCD Monitor
Open Questions:
-\&;-COMCAST Customer Care Phone Number #{+ I8OO-828-O294 } AB .U.S.A This Comcast USA phone number is ranked #2 out of 2 because 7,728 Comcast USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Comcast USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Comcast USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Comcast USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Comcast USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Comcast USA Calling Comcast USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Comcast USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Comcast USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Comcast USA's phone numbers against each other. Contacting Comcast USA in General While I8OO8280294 is Comcast USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Comcast USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Comcast USA.
Oct 16, 2019 | Best Computers & Internet
Amazon Best pHoNe NUmber #{+1-85O-8I2-4OO9 how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.
Oct 16, 2019 | Amazon Computers & Internet
-\&;-XFINITY Customer Care Phone Number #{+ I8OO-828-O294 } AB .U.S.A This Xfinity USA phone number is ranked #2 out of 2 because 7,728 Xfinity USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Xfinity USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Xfinity USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Xfinity USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Xfinity USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Xfinity USA Calling Xfinity USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Xfinity USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Xfinity USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Xfinity USA's phone numbers against each other. Contacting Xfinity USA in General While I8OO8280294 is Xfinity USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Xfinity USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Xfinity USA.
See all Acer AL1716B 17" LCD Monitor Questions
Acer AL1716B 17" LCD Monitor Logo
158 people viewed this question
Ekse
Alun Cox
