To start with, here's the list of parts diagram along with part numbers: http://www.adss.net/documents/parts/5220S_5230S_5260X_PARTS_SHREDDER.pdf
And you can contact GBC here:
http://www.gbc-shredder.com/gbc_5220s_shredder.htm
SOURCE: Hello, I have a GBC Shredmaster 6120S
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol.
If neither of these help your paper feed sensor or your pc board has gone bad and you will have to contact your manufacturer for further parts availability.
SOURCE: GBC SHREDMASTER 4220S
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
