Cyclic loading issue
My PVR9300t is constantly cycling through a loading sequences for Application 4.35, it loads then stall then restarts I have access to the menu for 2-3 secs and then it cycles again how do I stop this Help please
Turn off at mains, then take wall ariel out. With ariel out go to system (Pin number is 0000) unless reset and reinstall SW. Then reformat the entire disk. No guarentees but it worked for me, Only pain was I lost all the recorded programs in the format...
Posted on Jun 07, 2009
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
Timer runs constantly. Runs cycle then shuts off and shortly later restaRTS.
Posted under GE 15069 countdown timer.
Unknown if this is new timer that is wired wrong or if load has interference, or existing timer that stopped working.
If new timer, then check wiring: This timer is for single-pole application only and requires neutral wire.
http://waterheatertimer.org/GE-timers-and-manuals.html#15067
Then check for line interference by moving timer to different Load, for example ordinary incandescent light bulb.
Make sure slide switch is set to Timer.
Slide switch works as ordinary on-off switch, so see if slide switch works correctly.
If timer stopped working:
Feel timer if it is warm to touch indicating overload or internal timer short.
Timer is rated for 1/2 HP at 120Volts. Check nameplate on motor for HP.
Check for short in line by temporarily replacing timer with on-off switch, and check wire nut connections.
Move timer to different Load, for example ordinary incandescent light bulb.
If timer has gone bad, then return it to Home Depot and swap for different timer.
If load interference is problem, then buy mechanical spring-type countdown timer like Intermatic FD60
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Aug 03, 2011 | GE 60minute Automatic ShutOff Timer Switch...
Ever since cafeworld apparently runs faster mine is running 10 times slower. To do anything there is about a 2min delay when I click on anything.
Hi!!
To optimize your Facebook experience, please download the most up-to-date version of your Internet browser. For more information on upgrading your browser, follow the instructions listed here.
In addition, please try the following steps to troubleshoot the issue you're experiencing:
  1. Click out of the application (e.g., click Profile or Inbox at the top of any Facebook page), and then re-open the application.
  2. Refresh the page (Ctrl + R on PCs; Cmd + R on Macs).
If the above steps did not resolve the issue, please contact the developer of the application through their Profile Page if:
  1. The application hangs during the loading screen.
  2. The application loads, but is really slow.
  3. The application loads, but will constantly be out of sync.
If the issue you're experiencing is happening with multiple applications and with Facebook Platform in general, please report it to us here.
Lastly, if you are seeing an "Offline mode" or timed out error in your browser as if they're not connected to the Internet when you try to access you third-party application, you may be experiencing connectivity issues. We'd recommend that you talk directly to your network provider in regards to this issue.
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 26, 2011 | Zynga Cafe World
Slow on facebook
Mar 16, 2011 | Facebook Apps
I can't get farmville on my homepage anymore
Can you log in to Facebook? DId you had the problem recently.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 17, 2010 | Facebook Social Network
During normal cycle agitation is a constant stop/start
Yes, the timer mechanism should be replaced asap. the timer has a motor that is responsible for the rotation of the device. This motor is damaged, in return, not allowing the normal cycle to initiate and transfer sequential information to the motor properly.
Replacing the timer will correct this issue.
Aug 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Problem about navigator
Generallly this error refers to
The SD card is not inserted or not being read.
or when interrupted by poping out on load or operation. reinserting it and restarting usually rectifies the problem. If its constant the card reader is damaged
Jun 29, 2009 | GPS
Low idle stalls out
Here is the most common cause of surges and stalls at stops and low erratic idle speed and rough idle, it is the idle speed control air-bypass valve and throttle valve (IAC for short), they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Mar 13, 2009 | 1989 Audi 200
I have had two or three instances where certain blu-ray movies would not load. The screen would be in a perpetual "loading" mode, but will never finish the sequence. I thought it was a bad movie, so I...
You may need to check for updates for your particular blu-ray player from the manufacturer's website... many companies are sending out patches you need to download to play more current movies... check it out, that may be all you need...
Dec 29, 2008 | Sony BDP-S301 Player
Can't load Windows, constant restarts.
There could be several issues, but random restarts can be difficult to debug. For now, I'd start with the easiest and that is a memory check.
Visit www.memtest86.com and download the free bootable floppy or CD (burn the ISO file with free ImgBurn utility if you have no ISO burning application).
Boot the problem system with the floppy or CD and the memory test should start automatically. Let it run over night and see if errors are reported.
Dec 19, 2007 | ASUS P5P800 SE Motherboard
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
