Question about Tissot T-Touch T33759851
Problem of sychronisation between T and T2
I would like to add 2 minutes to T2.
The problem I experience is that for T, the time displayed is correct (let's say 10.10 for example) and on another time zone, the time shall 8.10
However, on my watch, it says 8.08 and not 8.10.
If I try to change time T, T2 is always 2 minutes late, and if I try to change T2, it goes directly to the next quarter.
I want to add one minutes (or 2), not 15
Anyone has an idea ?
3 Suggested Answers
  • 2334 Answers
SOURCE: the digital time and the analog time are not synchronized
Here is complete manual for your watch:
If you are not successful with this, maybe it's time to change the battery?
Read manual carefully and you will find out how to recognize: I'ts time to change the battery.
Rate me, please.
Posted on Apr 04, 2009
  • 2501 Answers
SOURCE: Hello, I have a Tissot Veloci-T
The list of problems is impressive and if you still have the proof of purchase, it should go back to Tissot for repair or replacement. It shouldn't matter where you bought it, so long as you can prove that it is within the warranty period.
(It sounds as though it has been dropped onto a hard surface)
If you haven't got any proof of purchase, then you will have to pay for any repairs.
Posted on May 09, 2011
How to set the time in titan zoop c3001pv04
I am sorry but the time cannot be changed. But there is another option in which you can not see the date. Press mode button or the bottom left button until display shows T2 in the bottom left side. Press Reset button or the upper left button. Thus will make the hours number blink. Set the time using ST/STP button or the upper right button. To set the minutes, press Reset button or upper left button and the minutes number will blink and set it using the ST/STP button or the upper right button.
Dec 02, 2014 | Watches
How to set time on roots squadron ry2168
1- Press and hold RESET and LIGHT together, be patient
2- With ST/STP change the digit blinking
3- With MODE choose hr, min, date....
4- Once done press RESET.
NOTE: To set T2, display T2 before doing the above steps.
Mar 09, 2014 | Watches
I can't set the time on my Adidas ADP6016 digital watch
There is two times possible in this watch ADP6016.
• Those times are named T1 and T2.
• IMPORTANT: When your displayed time is T2, you CAN NOT set the time but just set the offset of T2 relative to T1.
• You can see which time is displayed by looking for a very little T1 or T2 written just above the seconds
• To swap the displayed time from T2 to T1 (or contrary), you have to long press the start/stop button (top right white button)
• When your displayed time is T1, you CAN set the time with the solution given by soulgirljen
just before this one
Aug 29, 2012 | Adidas Digital Watch Adp6016
Have Rado 193. am trying to sync analog and digital time. Manual says turning crown slowly adjusts minutes. Does not - only hours change
You can adjust the analogue hands without changing the digital ONLY when you have set the watch to 24hr fornat. Do this by going to the second Timezone screen (T2) and pressing the crown once briefly. If A or P appears, the time display is in 12-hour mode. If no letter appears, the time display is in 24-hour mode. To change mode, press crown briefly a second time.
Now go to the basic display where no digital info is shown. Pull the crown out. Now slow turning will adjust the minutes and fast turning the hours, but only of the hands. Therefore you can synchronize the two. After they show the same time, press the crown back in and adjust both times together using the crown as normal on the standard "Time" digital screen
Dec 28, 2010 | Rado Maxi R21347712 wristwatch
The digital and hands display different times on my Tissot Touch
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
Dec 07, 2009 | Tissot T-Touch T33759851
Diesel DZ7069 watch - how do I set the correct date/time?
ok ,here it is .
Instructions To Set The Time On The Diesel DZ7071 Watch
Ok the first and most important thing to know about this watch is that it has an unusual timezone function (unusual to me at least). This allows the watch to display two different times. Time 1 (or T1) is the primary time (the time of the place where you spend most of your time!). The time can only be adjusted whilst the watch is in the T1 mode (T1 should be displayed in the bottom left corner of the screen). Holding down the top right button for one or two seconds will temporarily replace the current T1 time with the T2 time. Holding down this same button for several seconds will toggle the current time mode to T2 and the watch will continue to function in the second time zone until you toggle it back to T1.
The second most important thing to know is that you can only set the time whilst in the T1 mode. When in T1 mode hold down the top left button until the watch enters the settings menu (it should say "Light" at the top of the screen) now use the bottom left button to toggle through the settings menu until you get to the time settings. I think this part of the process if sufficiently straight forward so I'm not going to go into more details here, all I'll add is that once you have the watch set to the desired time mode 12h/24h time and date you just need to press the top left button to save the settings and return to the main time screen.
To set a secondary timezone time you have to first toggle the watch to the secondary time zone mode (hold the top right button for several seconds and the T1 indicator should change to T2 (and the watch will now be displaying the time that is currently set for the secondary timezone). This time is based on the primary time by simply telling the watch a number of whole hours ahead or behind the primary time. To adjust this hold down the top left button for several seconds, the watch will then say "offset" now use the buttons on the right to add or subtract hours from the primary time. Once set press the top left button again to return to the main time screen. Finally hold down the top right button for several seconds once more to return the watch to the T1 mode.
May 14, 2009 | Diesel Digital Dz7069 watch
Can't set columbia CL-5009. Display is on T2, want T1
Try holding the st/st button while on time display
Mar 11, 2009 | Columbia All Sport Digital watch
Breitling Aerospace -setting T2
Here is a link for all settings:
Sep 07, 2008 | Breitling Aerospace 455 Wrist Watch
Setting watch
Alright, so the actual solution probably revolves around the fact you are stuck on "T2" time mode. This is found by a symbol that reads either "T1" or "T2" directly above the seconds. So first make sure you are in "T1" by holding the ST/SP button first, then holding the SET button second and simultaneously. After holding both for a couple seconds, the mode will switch from either T1 to T2 or T2 to T1. Once you get the T1 to be selected, you can then press and hold the SET button. Once that is held long enough, a menu will pop up saying "Chime" as the first display. Press the Mode button to start displaying the other features, such as hour, minute, second, month, date, etc. To make changes within a selection use the ST/SP and RESET as up and down changes. When you are all done and back to the Chime feature, you can press SET to exit out of the menu.
As a side note, the T2 function is based off your T1 time, so if you are in a different time zone, you can offset the time by however many hours you off from the T1 time - but the key is to get the T1 time set first.
Hope this helps.
Nov 12, 2007 | Columbia All Sport Digital watch
Tissot T-Touch T33759851 Logo
125 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
